Post new topic Reply to topic  [ 79 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
Eldar Titan Pulsars
 Post subject: Eldar Titan Pulsars
PostPosted: Tue Sep 28, 2010 5:47 pm
Since we're in an Eldar mood lately...
Conventional wisdow says that the the Titan Pulsar weapons on the Phantom and Warlock Titans aren't as good an option as the Power Fist.
Change MW3+ to MW2+ ?
 Post subject: Re: Eldar Titan Pulsars
PostPosted: Tue Sep 28, 2010 5:56 pm
A counter suggestion might be to reduce the number of shooting attacks that the Pfist has.
Doing that has the benefit of opening up a role for a new arm weapon to be named later in the ETC list (a high rate of fire AT/AP weapon).
PostPosted: Tue Sep 28, 2010 5:58 pm
There are plenty of old weapon arms in the background/older versions of Epic, no need to go inventing new ones.
PostPosted: Tue Sep 28, 2010 6:47 pm
[drama]Is five enough? Never! When the Germans bombed Pearl Harbor, was that enough? Of course not!
I mean, it's not like I'm suggesting anything crazy here, like allowing phantoms to have access to seven different weapons. I'm not completely out of my mind. No no, six will be plenty.[/drama]
Seriously, though, most of the existing phantom arm weapons are geared toward killing WEs, with considerable overlap. Assuming everyone is onboard with the tremor cannon being a BP weapon, that still leaves a niche for a gun with stats similar to the AMTL's turbolasers/vulcan megabolter/gattling blaster.
Right now, the Pfist is the closest thing to that, and it also carries with it all those hardcore assault abilities. So, I was just suggesting that, maybe, it doesn't need to have as many abilities as it has.
That, of course, assumes that a twin-pulsar Phantom is actually worth the 750 pts.
PostPosted: Tue Sep 28, 2010 6:55 pm
Conventional wisdom seems to suggest it's not.
PostPosted: Tue Sep 28, 2010 10:41 pm
If I remember correctly, in SM/TL, the pulsar has 2 modes : one concentrated (to smash the WE) and one dispersed (to take down armoured vehicles).
So, what about these :
Titan Pulsar : 75cm, 2xMA3+, TK(1) OR 75cm, 6xAP3+/AT3+ ?
or
Titan Pulsar : 75cm, 2xMA3+, TK(1) OR 75cm, 3BP, MA ?
... well, the titan pulsar just lacks pulsing things ... 2xMA2+, TK(1) sounds just like 2 death rays, not pulsing death rays.
PostPosted: Tue Sep 28, 2010 11:20 pm
In Wh40k the Pulsar is a 60" Strength D, Ap 2 weapon with two 5" Template shots.
Revenant Titans, Scorpion SHGTs and Vampire Raiders are all armed with this.
Perhabs the Phantom Titan is armed with the same weapons but we will only know for sure until we can see it in Imperial Armour 11.
EDIT: Looked up the TL/SM2nd Pulsar in "Epic Renegades". There you roll to hitonce if you shoto at a single target. If youhit the target will be hit D6 times. Eachhit can be saved separately.
If firing at a group of targets you use the barrage template instead and rollto hit for every model under the template.
The TL/SM2nd Pulsar has a one attackdice 2+ to hit and a -2 armour modifier.
PostPosted: Sat Oct 02, 2010 1:18 am
Maybe just up the the TK value of each shot to TK (D3) per hit ?
PostPosted: Thu Dec 16, 2010 9:42 pm
I don't know if this is the right place to ask, but here I go. I just aquired some epic eldar stuff and looking through the new epic lists on here none of the weapons have pulse anymore. Is that an over sight? Or did they lose the Pulse ability?
Thanks in advance.
PostPosted: Thu Dec 16, 2010 9:50 pm
Based on the most recent official rules update, the pulse rule was removed, and all previous pulse weapons were given 2x number of shots.
PostPosted: Thu Dec 16, 2010 10:18 pm
I vote leave as is.
PostPosted: Thu Dec 16, 2010 11:20 pm
Ok, I just wanted to make sure. Thanks a bunch, sorry if I step on any toes for asking the question here.
PostPosted: Fri Dec 17, 2010 1:06 am
Dobbsy wrote:
I vote leave as is.
+1
I see the Powerfist as being the more unbalanced (read overpowered) option.
Conventional wisdom would seem to say, that the option that is an automatic selection, is the one with the problem.
Just call me Steve.
NetEA Rules Chair
NetEA FAQ
Some of my Armies.
My Hobby site.
PostPosted: Fri Dec 17, 2010 11:22 am
Do i recall that the powerfist also gives extra FF attacks? If so then those should go.
I like the idea of giving the pulsar two firing modes as in days of yore.
For reference I did come 6th at my first ever UK tourney running a phantom with twin pulsars :-)
MoK's Painting Blog
Now Showing:
PostPosted: Fri Dec 17, 2010 2:30 pm
My "official" recommendation, as NetEA Eldar Champion, would be to try the Titan Pulsars at 3 x MW3+ as an initial test and report back.
A dual firing mode could be interesting, but I'd rather take a smaller step first.
