DE Raider minis
 Post subject: DE Raider minis
PostPosted: Sat Aug 05, 2006 1:22 am
Not sure others haven't thought about this already but you could use the old mk1 wave serpents as Raider minis. They could do with a little converting but the shape is almost there....
What are ppl's thoughts?
epic collector - check the eldar grav tank section if you're unsure
Just lose the top sail bit and it's a flat deck type thing...
PostPosted: Sat Aug 05, 2006 2:51 am
I don't have alot of familiarity w/ BFG, but it seems like alot of the Eldar and DE ships would make servicable AV or WE.  If they just weren't so darned pricey!
Understand this: that skag and his floozy...they're gonna die
PostPosted: Mon Aug 14, 2006 3:17 pm
Dobbsy, I had the same exact thought and acquired about two dozen of the buggers.  I am currently working on the Necrons but the Dark Eldar will be my next project.
A little glue here, a little plasticard there, and don't forget the tops of the Vypers will be perfect for the conversions as well. :;):
