Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
Please weclome the new Kabal of Pain's Way....
 Post subject: Re: Please weclome the new Kabal of Pain's Way....
PostPosted: Sun Jan 22, 2017 12:46 pm
kyussinchains wrote:
use quote tags in your posts like in the code example below, it's literally that easy
Code:
 [quote] quoted text goes here [/quote]
or the quote button, i have been using it for years and I have never had problem with it.
Regards
Greg
PostPosted: Sun Jan 22, 2017 6:00 pm
To quote someone else, go to their note in the thread and hit the 'quote' button at the foot of that text box (or the top of the text box when you are already replying). If you use the 'quote' tool above the text box, it will put the text in a quote box without attributing it to anyone.
Note, by using the quote button in someone else's text, you will get to see the special characters used in their text, and thus some other tricks.
PostPosted: Mon Jan 23, 2017 8:13 am
Thanks PFE200 I will give it a try.
Ginger I tried the method you mentioned, and it did not work. Hence Why I cut and pasted.
PostPosted: Wed Feb 01, 2017 1:08 pm
Jim I will be looking at testing the new Dark Eldar 2.0 list I was given at CanCon. I will likely only be playing Epic one Sunday every month, and might be going to play against the Newcastle Legion lads when Chris from Richmond goes there. I will try to get as many different types of opponents as I can, and look at different configurations of forces for the list. I think a mix of 1000 point minigeddons, and 3000 points games will let me test the list and its nuances.
I believe you tend to try and dominate the list with 1+ activation formations where possible. I will give some feedback, and see how the list plays out, and provide recommendations.
