Post new topic Reply to topic  [ 248 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 17  Next
[Units] Banshees and Overwatch
 Post subject: [Units] Banshees and Overwatch
PostPosted: Thu Jul 16, 2009 7:45 pm
Quote: (Lord Inquisitor @ 16 Jul. 2009, 19:38 )
Quote: (clausewitz @ 16 Jul. 2009, 13:32 )
Sorry Chroma, I don't mean to seem pedantic but that doesn't make sense to me.
If a unit within a list recieves a power boost, how does that not also give a (however small) power boost to the army containing that unit?
Blah
Sorry?
PostPosted: Thu Jul 16, 2009 7:48 pm
Quote: (clausewitz @ 16 Jul. 2009, 19:43 )
so front to back?)
Yes, but the defender gets to assign the hits where units are are "equally close", e.g., in base contact.
So, if you're in base contact with four enemy units, one with a character, and score three hits, your opponent will (probably) assign those hits to non-character units.
PostPosted: Thu Jul 16, 2009 7:54 pm
So just to be clear..
If 2 Banshees were in base to base contact with 2 tactical marines, one with a chaplain and 2 scorpions were in contact with 2 other tactical marines.  And both Banshees hit, it would be legal to allocate both those hits to non-character tactical marines?
PostPosted: Thu Jul 16, 2009 7:58 pm
Quote: (stompzilla @ 16 Jul. 2009, 19:21 )
I will be testing Banshees at CC4+ MWFS, with no other changes.  If this proves too much i will then test CC 4+ FS Lance.
I really don't think Banshee's sv should be increased.  Eldar have always been a glass hammer, represented by immense hitting power, quick movemet and low saves.  The trick to getting Banshees to work IMO is to pick your targets well and stack the odds so you are able to kill as many enemy as possible before they can strike back.  In this list i'll be using the Banshees and dragons to hunt down elite enemy units before they can cause me problems and hope to cause a hole into which the rest of the army can pour through the enemy lines.
Stompzilla, I am also not entirely sold on increasing the save for the reasons you state. However it has always rankled that other units got increased armour to reflect their agility while Banshees did not. But hey, that is what testing is all about  :smile:
CC4+FSMW certainly will pack a punch, and may well be OTT with Infiltrate etc because we have to consider maniacs like me using pure Banshee formations :laugh:
However, I am much less sure about Lance as that is specifically an Anti-armour weapon and steps on the Shining Spears role. As an alternative, could I suggest considering CC3+ and CC2+.
Chroma, I still intend to try these options on Tuesday, opponents permitting of course.
PostPosted: Thu Jul 16, 2009 7:59 pm
As the rules stand, yes, since all the Tacticals are in 'base contact', so they are all eligible targets... it doesn't matter which unit is in base with which to determine that eligibility.
One of the reasons for giving the Banshees sniper was to mitigate a bit of that, to allow them to "assassinate" in addition to lowering the enemy's armour value.
PostPosted: Thu Jul 16, 2009 8:13 pm
Exactly so. Indeed it allows the opponent to kill both marines in contact with the scorpions thus reducing their combat potential as well. It is one of the peculiarities of the E:A mechanics in this particular respect. And furthermore, because the First Strike round is separated from the normal round, the defender potentially gets to use the same tactic when allocating hits from the Scorpions as well (though it also means that any FF hits will get allocated to anything in B-B first; including the character if it survived the Banshee attack)
Sniper allows you to allocate the hits but is potentially too powerfull, hence the suggestion of Infiltrate to allow just the Banshees to contact only those units that they want to attack - effectively 'sniping' the characters
PostPosted: Thu Jul 16, 2009 8:17 pm
Quote: (Ginger @ 16 Jul. 2009, 20:13 )
Exactly so. It is one of the peculiarities of the E:A mechanics in this particular respect. And furthermore, because the First Strike round is separated from the normal round, the defender gets to use the same tactic when allocating hits from the Scorpions as well!
The *brutal* thing in this regard is that if the Banshees have killed the units basing the Scorpions during their first strike attacks, the Scorpions can now only make fire fight attacks!
PostPosted: Thu Jul 16, 2009 8:21 pm
just added that too  :whistle:
PostPosted: Thu Jul 16, 2009 8:23 pm
Could one of you guys point me to where the "base contact means same distance from the enemy" concept comes from?
PostPosted: Thu Jul 16, 2009 9:07 pm
Base Contact = 0.0cm from enemy.
Not in Base Contact > 0.0cm from enemy.
Hit allocation is based on nearest enemy to nearest target. In the case of ties, defender chooses.
Morgan Vening
PostPosted: Thu Jul 16, 2009 9:59 pm
Thanks.  I was hoping for which part of the rulebook to look this stuff up.
For example the "if its a tie defender chooses" where is that?
PostPosted: Thu Jul 16, 2009 10:17 pm
From the rulebook, emphasis added:
1.9.6 Allocate Hits & Make Saving Throws
You must allocate hits inflicted on your formation against
targets that are within range and line of fire of the enemy. Hits
are allocated ‘from the front to the back’ of a formation.
The owner of the formation is the individual who assigns hits to it.
PostPosted: Thu Jul 16, 2009 10:21 pm
Thanks Chroma.
I'll step down and leave the rest of the Banshee discussion to continue.
PostPosted: Thu Jul 16, 2009 11:48 pm
Ginger:  I'm not talking about combining it nwith infiltrate or anything else.  Just 4+ MWFS.
Lord Inquisitor definately has my reasoning nailed on the head.  While CC 4+MW is quite good, it's no more good than FF 4+ MW and a shooting attack.  IMO this is the simplest change that has the least variables to juggle and will do the trick of making Banshees attractive and giving them a niche.
Of course the proof will be in the pudding and i will post some playtest results when i manage to get some games in over the next couple of weeks.
PostPosted: Fri Jul 17, 2009 12:47 am
Likewise I hope to test various combinations next Tuesday.
CC4+MWFS is certainly worth testing, but my concern is that MW makes it a bit too generalist IMHO, where I understood the intent was an anti-infantry specialist role. The other issue is just how to use this version of Banshee. Basically in this form it would seem that they can only run up to the outside of the enemy formation and hack away. Obviously adding Infiltrate allows more specific attacks to be mounted.
Could you explain how you see Banshees being used, and more importantly how many you would use in a formation and why
