Tau Jet Packs
 Post subject: Tau Jet Packs
PostPosted: Fri May 05, 2006 3:48 am
Hello people,
? I got a quick question. I've had the pleasure of playing against the Tau army list this past weekend. During one of the assaults against a Tau formation, the combat result was tied, and the assault continued another round. This raised the question of whether or not the Tau formation could use their Jet Packs to again 'fall back' 10cm. We decided to allow it for the game we were playing until we could get a 'real' answer, but it opened a whole slew of other questions.
? So, the question is: Can Tau units use their Jet Packs to 'fall back' during the 2nd and later rounds of a continued assault?
? If the answer is yes, this opens the oportunity for Tau units to distance themselves from enemy support formations (something nobody else is able to do), to get closer to Tau supporting formations (again, something nobody else is able to do), remove themselves completely from the 15cm assault range (if the enemy chooses not to counter-assault) leading to rounds of assault with no attacks whatsoever, and causes confusion as to whether the Tau should Fall Back first or the attacker should Counter-Attack first. If this has never come up before, I urge you to rule that the Tau Jet Pack 'fall back' move only be allowed in the first round of an assault just for simplicty sake (so a multitude of other rules and clarifications aren't needed to handle all of the odd situations caused by this rule).
? Thanks for the help,
? Justin Case
PostPosted: Fri May 05, 2006 6:27 am
Quote (JustinCase @ 05 May 2006 (03:48))
I've read the rule like that; the third and fourth sentences in the rules specifically lists the cases where the Fall Back move can be made:
The units may move 10cm in any direction immediately
after the enemy formation has declared an engage or air
assault action against their formation (note that falling
back happens before a charge or air assault is made, not
after charge moves as with counter-charges).
Note that this jet pack move comes immediately after
the assault declaration, and so in some cases will not
be able toprevent close combat attacks.
However, a clarification could help.
PostPosted: Fri May 05, 2006 7:20 am
I always read the first sentence and took it for granted it's only when you DECLARE those actions not when you advance the combat to a decider. Doesn't that sentence clarify it? You don't declare an engage action in a subsequent round, do you?
PostPosted: Fri May 05, 2006 11:13 am
Indeed. This should only work when an assault is declared (after that point, the engagement has become chaotic and any retreating forces are likely to get a knife in their back).
I will clarify this in the next version. Thanks.
PostPosted: Fri May 12, 2006 12:07 am
I'm rather curious. At exactly which point do you declare an air-assault? Do you move your aircraft into position, THEN declare it (having prior just decided a bombing-run) or do you declare it at the time you activate the formation? It likely isn't an important difference most of the time, but it'd be interesting to know exactly when the Tau get to run away (For instance, if they get to run away before the aircraft moves, it can still land in melee with them or land and send units into melee with them. If they move AFTER it does then they can almost always gaurantee that the enemy can't reach them for melee unless they're jump-packs).
PostPosted: Fri May 12, 2006 12:42 am
I don't have the book handy - so, in general terms and my own verbiage...
Its an action option for aircraft activation, which is declared prior to initiative test die being rolled.
Aircraft may take one of three activation actions:
CAP
Intercept
Air Assault
Rob
PostPosted: Fri May 12, 2006 1:44 pm
I would agree with that... but I always played that the Tau make their 'enlightened withdrawal' move after the assault move of the aircraft.
PostPosted: Fri May 12, 2006 5:01 pm
Quote (Tactica @ 12 May 2006 (00:42))
CAP
Intercept
Air Assault
You forgot Ground Attack.   :cool:
