TK weapons and deflector/void shields
 Post subject: TK weapons and deflector/void shields
PostPosted: Tue Feb 28, 2006 7:05 am
I've been trying (and failing) to find the answer (to confirm my thoughts)in various sections of the rules about how you apply TK weapons to WEs with shields.
If you fire a TK(d3) at a Warlord do you roll to hit once then apply d3 damage to the shields e.g if you roll 3 damage, do you knock out 3 shields? Or do you only knock out one shield with the single hit?  I assume it's 3 shields.
I'm wondering if Deflector Shields have damage applied in the same way as Warlords. Or is it different that you only get the deflector save once, so if you fail you get hit by all 3 shots? Or do you get a save for all 3 shots?
I'm a little confused here.
PostPosted: Tue Feb 28, 2006 8:53 am
Void shield wise lose as many void shields as points of damage done.
PostPosted: Tue Feb 28, 2006 7:20 pm
And the deflector saves once for each TK hit.  The Eldar holofield is the one that saves once for all or nothing.
PostPosted: Tue Feb 28, 2006 8:23 pm
Tactica to TRC and Cw.
Rob
PostPosted: Tue Feb 28, 2006 10:50 pm
Thanks guys
