Hammerhead variants (Ionhead and Fusionhead) - Use cases
 Post subject: Hammerhead variants (Ionhead and Fusionhead) - Use cases
PostPosted: Sat Jan 15, 2011 6:05 pm
Do you use it? If so - how, and in what lists? Mixes in units anyone?
I personally feel that Fusionhead offers some other ground force solution of MW lack, but 30cm is a bit harsh. maybe mix-in with regulars?
 Post subject: Re: Hammerhead variants (Ionhead and Fusionhead) - Use cases
PostPosted: Sat Jan 15, 2011 7:01 pm
nope. i use 6 fusionheads in one. making quick attacks at 30cm with pop up and crossfiring recon formations and markerlights makes it ugly for reinforced armour formations.
PostPosted: Sat Jan 15, 2011 7:13 pm
2Dobbsy: what's your list besides fusion hammers?
PostPosted: Sat Jan 15, 2011 7:26 pm
Fusion heads definitely have a role in an aggressive list, but ion heads are pretty much useless.
PostPosted: Sat Jan 15, 2011 8:18 pm
I'm personally thinking about this:
hammers 6 300
hammers 6 300
hammers 6 300
stealth 250
8FW+ethereal+gun drone 325
hammers 6 300
crises+shaso 350
manta 675
hero 200
and using 2 of the 4 hammer formations as fusionhammers.
PostPosted: Sat Jan 15, 2011 10:18 pm
Ions are a lost cause, there really isn't any use for them that the rail or other units fill with the latter having other advantages.
PostPosted: Sat Jan 15, 2011 10:21 pm
why no one mentioned it before list was frozen, then?
PostPosted: Sun Jan 16, 2011 12:44 am
It was mentioned often but no one came up with a good solution which also fits the fluff of the weapon.
PostPosted: Sun Jan 16, 2011 2:38 am
link, if you please?
with basing on tabletop 40k I can only think of making them cheaper, as ionhead is cheaper then hammerhead in 40k - but this can be problematic in tau situation(small fms) - maybe work it out making it "4 rail/fusionhammers or 6 ionhammers for 200. and 6/9 for 300"
without total basing I'd suggest 2x maybe. as what I felt looking at ionhead was mainly "more shots of slightly less potency"
PostPosted: Sun Jan 16, 2011 3:29 am
Yep, the Ion issue has been brought up over and over again for years, but noone's come up with a decent solution. Honestly, they're just worth less points.
PostPosted: Sun Jan 16, 2011 3:52 pm
Ion heads perform great as long range AP platforms - something the tau now lack after losing the stingray. they're a helpful addition to Fire Warrior formations
PostPosted: Sun Jan 16, 2011 10:47 pm
I was very in favour of giving them +1 AP from their current stat, as I thought it would balance it.
But I never have any good ideas. :-)
PostPosted: Mon Jan 17, 2011 5:29 pm
Fusionhead is fine as it gives you access to some range MW attacks and is a good close support tank, the problem with the Ionhead is not thats its completely rubbish - you wont instantly lose every game you play just becaise you take a formation of 4 Ionheads for 200 pts or add two as an upgrade to a formation for 100pts. Its just in the context of the list where you have so many great AP weapons available, the Railcannon version is just much more useful as a support option.
