Tigersharks mit der dronen
 Post subject: Tigersharks mit der dronen
PostPosted: Thu Oct 01, 2009 3:01 pm
Assuming that the standard TS will be carrying drones again, how should this work? What are the mechanisms that are needed to support this, what should the TS entry look like?
Thanx!
Honda
"Remember Taros? We do"
- 23rd Elysian Drop Regiment
PostPosted: Thu Oct 01, 2009 3:07 pm
Thanx!
Unit stats and carriage mechanisms have been worked out for the E series of proposals, and I think they're acceptable.
PostPosted: Thu Oct 01, 2009 3:23 pm
Should carry 3 units of drones, so a full squadron split over a wing of 2 tigersharks.
Notes section would need
Transport (3 drones), all Tigersharks in the formation count as one unit for the purposes of transporting a drone formation. The Tigershark may not land or conduct an assault as part of a ground attack, however the drones may disembark at the end of a ground attack approach move and fire with the tigersharks as normal.
Said better and shorter by someone please.
PostPosted: Thu Oct 01, 2009 3:30 pm
As it is in E1.09.
Said better and shorter.
I agree that's a better arrangement of the text in E1.09
PostPosted: Thu Oct 01, 2009 10:41 pm
Well, I don't like the mechanism of splitting a formation across the squadron, (i.e. 3 fms on two aircraft). What happens when one a/c gets shot down?
So either one each or two per aircraft.
Thoughts?
Honda
PostPosted: Thu Oct 01, 2009 10:43 pm
Each Tigershark is carrying 3 Drone units.
The drone formation therefore loses 3 drones, recieves 3 BM's, has 3 units remaining, and breaks.
Simples.
Splitting them across two aircraft is fine.
PostPosted: Thu Oct 01, 2009 11:56 pm
Do you buy the drones separately or are they part of the TS purchase price?
PostPosted: Fri Oct 02, 2009 12:02 am
In the E series they are seperate purchases.
PostPosted: Fri Oct 02, 2009 3:52 am
The same as any other formation split across air or ground transports? Well bar marines in a thwak transport squadron as they don't break unless 2 out of three transports go down.
Would certainly mess up that insertion that turn, which is a good thing.
You mean units? The advantage of a 6 strong formation is its anti pop, the advantage of being across two transports is a disadvantage acting as a slight break on aggressive deployment.
