Tau version 5.1
 Post subject: Tau version 5.1
PostPosted: Wed Mar 25, 2009 12:02 am
Here is version 5.1 of the Tau army list:
EA Tau - Version 5.1
Honda
"Remember Taros? We do"
- 23rd Elysian Drop Regiment
PostPosted: Wed Mar 25, 2009 12:27 am
If you can get the pdf below 150k, you can post it directly to the boards... cut a page or two of "collector's models", since they're not needed to playtest the list, and you should be good to go!
PostPosted: Wed Mar 25, 2009 3:56 am
Honda! You teaser!!  :vD
PostPosted: Wed Mar 25, 2009 2:40 pm
Might I also suggest tagging this thread with a [NEW!] tag when you've posted the new version?
PostPosted: Fri Mar 27, 2009 3:21 am
:_(  :_(  :_(
Any news on the file?
PostPosted: Fri Mar 27, 2009 6:02 pm
Any chance of the file this weekend?
PostPosted: Fri Mar 27, 2009 6:05 pm
My apologies. Version 5.1 is now available.
PostPosted: Fri Mar 27, 2009 6:16 pm
Is it intended that a double Scorpionfish Support Group have access to two leader abilites: through the "Supreme Commander" and the "Control Node" upgrades?
PostPosted: Fri Mar 27, 2009 11:20 pm
Honestly? No. However, this gives different routes to this Leader ability and it is established that only one instance of issue of Leader applies at any point, so I dont think that this is a huge problem.
PostPosted: Sat Mar 28, 2009 1:07 am
Actually if they each have leader both instances will count. It's only leader twice on a since model that doesn't count.
PostPosted: Sat Jun 13, 2009 5:47 pm
Hello!
Is it intentational that Stealth support group has only Gun drones as upgrades!?!
So no Stealth upgrade?!
Oh and do Ethereal upgrade add to Cadre size or adds to 1 unit?
Thanks!
PostPosted: Sat Jun 13, 2009 11:47 pm
Hi. Yes, it is intentional that the Stealth formations dont allow Stealth as an upgrade. If they did, you could take three more groups and have a large formation. The idea behind the Stealth support group is that the are small and fragile. The idea is that you shouldnt be able to outfit a Stealth group with loads of hard hitting units.
The Ethereal is a Character, and so the single figure is added to an existing stand and it doesnt increase the number of stands in the formation.
PostPosted: Sun Jun 14, 2009 10:29 am
Damn! I tought they vere intentionaly left out, had to be sure...
Are there any standard points value for the sniper/hvy drones?
PostPosted: Sun Jun 14, 2009 9:45 pm
:vD  I guess that you are a fan of the larger formations, then.
Heavy Drones last appeared in version 4.4.3, where they were an upgrade to normal Drones. Up to four units of Drones could be upgrades to Heavy Drones for 50 points.
Sniper Drones last appeared in version 4.4.2. At a cost of 25 points you add a Sniper Drone stand.
