Post new topic Reply to topic  [ 209 posts ]  Go to page 1, 2, 3, 4, 5 ... 14  Next
Tau beefs, discussion
 Post subject: Tau beefs, discussion
PostPosted: Wed Sep 17, 2008 8:45 am
I've been thinking about the idea of giving GM's the Indirect Fire ability and I have to say it's growing on me (note this is not to give Tau Barrage Point weapons).
This would allow Scorpionfish and Stingrays (PLEASE don't keep on about removing them... :disagree: ) etc to Sustain fire from behind cover and only give them +1 to hit (from Sustain action) rather than +2 (extra +1 from enemy being lit-up by turrets). Of course there are other units in the Tau armoury that have Markerlights for the +1 (Pathfinders, Tetras etc).
Of course the Tau GM's don't need the doubling of their range as other Indirect Fire BP weapons receive from the ability.
IF ALL Tau Guided Missiles were given Indirect Fire I could possibly support the removal of Markerlight Sentry Turrets (as long as ALL GM weapons don't get a range reduction).
I think that Drones (both types) should be kept in their present form but only be allowed as upgrades to other formations (ie not a formation in their own right). I can see what TRC (and others) are saying about the ability to spam the board with these cheap useful units.
How are drones used by the Tau? It seems to me that they are there to protect more valuable units. Making them upgrades to do this keeps them doing their job and cuts down on possible abuses.
Just call me Steve.
NetEA Rules Chair
NetEA FAQ
Some of my Armies.
My Hobby site.
PostPosted: Wed Sep 17, 2008 10:10 am
To be honest Hena, I really like the Guided missile rule and I agree I think it may remove some of the character, but in the pursuit of a more balanced list it may be necessary to alter the way Tau play to a slight degree - I discuss Scarik's/my view about the Indirect fire idea here :
http://www.tacticalwargames.net/forums....;st=15#
And funnily enough Onyx put up a pretty much similar idea which I hadn't even read so we may be onto something if three people can see it as a positive, at least... fingers crossed. Onyx's idea about Pathfinders etc still having MLs could be a fair trade off and focus the pathfinders even more (heck they may even get more use in lists). I think it could really solve a few issues people have. It's great to have a character for an army but if it's causing too many issues of balance then perhaps an adjustment is required. I think we could nut out a decent compromise about this idea. We prety much have already if others would agree to its trial. :)
I think it really could bring some balance to the force... Sorry I had to throw that one in it was just begging to be used  :vD
I'm surprised by Jstr's remarks regarding the crisis suits. In a positive way of course! If his group can come around to the rule then we may be able to keep it and not worry about Hit n Run.  :agree:  We can debate one less rule which i think is very positive.
On the Drone discussion I think we could really keep both types by just putting a higher cost on the stand alone drones. They have pretty good stats to cost them around 125-150 points really. Their fluff could just contain a sentence about how they are programmed for differing tasks when in stand alone formations. etc etc
PostPosted: Wed Sep 17, 2008 10:59 am
Just to clarify, I'm not advocating the removal of the Guided Missile rule, just an addition to it that allows GM's to fire indirectly (with no range modifications).
I like the guided missile rules aswell but if you're gonna remove turrets ( :sigh: ) then some adjustment is needed.
Just call me Steve.
NetEA Rules Chair
NetEA FAQ
Some of my Armies.
My Hobby site.
PostPosted: Wed Sep 17, 2008 11:40 am
When I have played against Tau with list of Guided Missiles they did not have turrets and they worked just fine.
PostPosted: Wed Sep 17, 2008 1:05 pm
Which was before the stingray change? Or after. Otherwise if you had loaded up on pre change 'rays you must have being doing something wrong not to dominate.
Replacing the GM rule with indirect is interesting. Makes things more predicatable, but really AT gm's in older list iterations were fine. AP gms wreck the list still if you want it to be including stuff like infantry. If you don't then they are fine as well.
GM's should be there to boost Tau long range (75cm) fire to IG standards I feel, to provide a boost to infantry formations (represented by their transports) and to link aircraft in with the ground forces in a suitably high tech way. They shouldn't replace anything or be the cornerstone of the army.
Quote: (Hena @ 17 Sep. 2008, 05:38 )
Airpower: Too good: Needs to be cut back a bit, maybe drop one weapon line from each?
Agree on this. One might consider dropping AA from ion cannons as well?
Well some people may have noticed my airpower musings over the years :)
I reckon the best set of aircraft stats would be (after much debate, testing, experience etc etc).
2-3 Barracuda Superiority Fighters, 75 points each
Fighter-bomber
Save 6+
Seeker Missile Battery, 45cm, AT6+ Guided Missiles
Ion Cannon, 30cm, AP4+/AT4+/AA5+, Fixed Forward Arc
Burst Cannons, 15cm, AP4+/AA6+
2 Tiger Shark Strike Craft, 200 points
Bomber
Save 4+
2 x Seeker Missile Batteries, 45cm, AT6+ Guided Missiles
Twin-linked Ion Cannons, 30cm, AP3+/AT3+/AA4+, Fixed Forward Arc
Notes: Transport (may carry three of the following units: Gun Drones, Heavy Drones, Turrets); the Tiger Shark cannot land (and hence not conduct an assault or embark troops) but can disembark Drones in the normal way after its approach move is completed.
I would suggest these things come with a compulsory load of drones. Maybe make it the only way to get independent drone formations? If (and its a big if) its too weak then up main gun range to 45, but this will make it nigh impossible to hit with flak. I would prefer a different option. But the above was fine int he limit flights I've given it.
2 Tiger Shark AX-1-0, 275 points
Bomber
Save 4+
Twin-linked Heavy Railcannon, 45cm, MW3+ Titan Killer (D3), Fixed Forward Arc
Burst Cannons15cmAP4+/AA6+
They are in a flight of two to stop 'spaming' They could be singles but would have to cost proportionally more.
I've upped the main gun range as everyone complains about having to think to avoid flak. That could well make them too powerful. Only way to see is after a year of tourneys does everyone get a flight of these first. Upped the points slightly due to worries about gun and because with the tau to high is better than too low at this stage :) Plus means you can't get 4 flights at 3000.
PostPosted: Wed Sep 17, 2008 1:42 pm
Quote: (Hena @ 17 Sep. 2008, 13:24 )
That is still too powerful for the cost. Compare that to Thunderbolt and see that Thunderbolt loses in practically all situations except in intercept and CAP (note that it's still better defended due to 360 degree of AA defence) and still is equal cost? Make that a Fighter and 100 points a pop.
I would say they are equal.
Fluff wise thunderbolts have the edge in speed and experience, barracuda in manoeuvrability (which in dogfighting terms gives the thunderbolt a big advantage).
Both fighter bombers and save 6 (so both dogfight at 90 degrees and ground attack at 45)
Then its
TBolt
30cm AT4+ FF
30cm AP5+/AT6+/AA5+ (4+) FF
15cm AP4+/AA5+ (4+) FF
Best case AT - AT4+ AT6+, AP4+
Best case AP - AT4+ AP5+, AP4+
'Cuda
45cm AT6+ (5+)
30cm AP4+/AT4+/AA5+ (4+) FF
15cm AP4+/AA6+ (5+)
Best case AT - AT5+, AT4+, AP4+
Best case AP - AT5+, AP4+, AP4+
'Cuda has the edge in ground attack (and defensive flak, and the thunderbolt in dogfight.
200 for 2 for the above is somewhat to much.
PostPosted: Wed Sep 17, 2008 2:03 pm
I don't mind those aircraft stats. you may have won me on this one.
PostPosted: Wed Sep 17, 2008 2:15 pm
Is the barracuda 25 points better per plane with those minimal differences though, Hena? I don't think so personally. And we can't have exactly the same stats on every plane to have exactly the same points. We have to have some divergence for fluff and fun's sake. Making them 50 points more for a formation for this minimal difference is overkill IMO. Nitpicking something this small will mean we take forever to get things done.
PostPosted: Wed Sep 17, 2008 2:24 pm
Quote: (Hena @ 17 Sep. 2008, 15:06 )
Edit: Although if I have to bend here one could go with 175 for pair and +1 for 75 points?
That seems quite reasonable!  :agree:
