Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 96 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
It is time to let "5 Aces" go...
 Post subject: It is time to let "5 Aces" go...
PostPosted: Thu Feb 09, 2006 5:46 pm
Could you incidentally outline for me at least what the core design was originally?
As far as I understand from glancing in the forgeworld books it is a fighter bomber with the same armour and speed as a barracuda but twice the damage capacity and far bigger guns, designed for WE hunting. (I'll ignore the forgeworld comparison tot he maruader as out epic one sucks.) Appart from the fighter bomber bit and removing some of the weaponry (replacing it with the markerlight missiles on the basic one and simply droping the missiles on the varient) is the above not a pretty good match?
40K is the core design - not epic. The neuter reference is from that core design. I'm not saying that the balancing wasn't necessary, but I'm saying a further reduction in stats only gets it farther from core design intentions - and yes, its already neutered from its glory in 40k.
In 40K - the core design, the AX-1-0's range surpasses that of a leman russ. In Epic, it's reduced to 45cm. The proposed would have it reduced to 30cm - even less.
In 40K- the core design, the plane fires a large instant marine killing blast or a TK(d3) shot where by it can blow up a shadow sword, a  baneblade, or a warhound with no shields up - in a single hit. In epic, it simply cannot deliver this result despite Epic representing a 10 minute turn and 40K representing a 10 second - 1 minute turn. Furthermore, the proposed is to take it to 1 shot in E:A and completely remove the fact that it can indeed effect multiple targets in a 10 second interval with a single shot - not to mention what it could do over a 10 minute interval in E:A.
In 40K- the core design, the AX-1-0 is a well armored super heavy fighter- bomber with speeds surpassing any Imperial bomber and being on par with the barracuda. Its admired for its manouvrability and the air castes ability to navigate the craft in G's impossible for an imperial pilot with the best technology to work within. In E:A, the AX-1-0 is a bomber (not a fighter bomber) and does nothing more than a Maurader does in movement. The proposed it to make its armor weaker yet, and maintain bomber status.
In 40K- the core design, the AX-1-0 has a Targetting Array - which means this plane hits on a 3+ instead of a 4+. Since the main weapons are twin linked in 40K, its allowed to reroll any misses to hit with the main gun. It usually hits and is fairly reliable! In the E:A, after getting a lot closer to its target than design would have it, it currently has 2 shots at 4+ to represent its net effectiveness in a 10 times the time by comparison to 40K. The proposition is to make it have less shots and maintain its lessor chance to hit.
In 40k - the core design, has a network marker light enhancing the plane's ability to hit with its on board seeker missles. Seeker Missles have unlimited 40K tabletop range and also have a S8. So they are very effective at busting armor without the plane even being seen if a markerlight is in range (the horror!) They hit the target on a 2+ after the network markerlight (or any other marker light in the army) has marked a target. Furthermore, all or some of the missles may be fired in a single 40K game turn. In Epic, the plane can fire a single missle and it hits on a 6+ unless there's a marker nearby where at best it gets to a 5+. Furthermore, the plane has no marker light on board in E:A. Finally, the planes missles are limited to 45cm in E:A - and the proposed is to have all weapons reduced to 30cm.
Yes - for this Tau fan, I feel neutered adequately represents the current state of the AX-1-0 from core design (40K) regardless of how effective it was, currently is, or will be in the future of E:A.
You made mention to Mauraders in Epic. IMHO, they have the same problem that Thunderbolts do in Epic... 'they are behind the times'. Although they've never reflected core design from their E:A representation, that was OK as they were the standard and no planes stood to appose. Then other lists made their planes closer to Core Design in effectiveness - ergo, behind the times.
Rob
PostPosted: Thu Feb 09, 2006 6:33 pm
Quote (Tactica @ 09 Feb. 2006 (16:46))
Looking at this download (nauty I know) it says 10 10 10 for its amour. I don't understand 40k stats but it says 10 10 10 for the barracuda as well.
Do you know what else that is called :)
Nope, missiles still 45cm, I like the idea personally of such support weapons encouraging brave use of markerlight units.
Planes don't translate directly over well, in part because they aren't a core part of 40k and people have mixed views on how well they work (everyone can shoot the plane or something as well there, I admit to being a bit vague).
Then people wish to have all the weapons on it have the same effect as the ground based versions - ignoring the fact being air carried does change how a weapon performs.
Go on then, everyone else can have the last word otherwise it will never stop again :)
PostPosted: Thu Feb 09, 2006 7:08 pm
Okay, before everybody gets real excited or gets their knickers in a wad, I would like to state for the record:
I would not be in favor of Option #1, but I think the second has promise. I would be willing to accept the +6 save and what that would do to the stats, but I want to see the Lt. Rail cannon variant at 45 cms.
How would you cost that? Also, am I understanding your costs correctly? As posted, 325 for a two ship element?
Honda
I said that the second option had promise. I also said that the 30 cm range for the Railcannon wasn't acceptable and then asked what the estimation for the cost at 45 cm range would be?
I think the middle ground could (my emphasis) could occur between reducing the save and leaving the range as is, not reducing it. If that is not enough to get the other side to the table to talk points, then I'll remove the offer and let CS roll the dice as to the outcome.
Part of successful negotiations is realizing when a compromise is possible.
Honda
"Remember Taros? We do"
- 23rd Elysian Drop Regiment
PostPosted: Thu Feb 09, 2006 7:40 pm
Sorry if you thought I was just ignoring your point, just realised by reading back I missed your 'how would you cost that' (the 45cm gun) bit.
Bearing in mind +1 intercepts may be introduced (and since I always take fighter cover), well, the current costing first.
The 30cm one is costed to get 1 1/2 superheavies during the game assuming 1 turn lost activation and a plane shot down over a 3 turn game. So better results if you work with them, worse if turn 1 you attack flak city, and do the same turn 3.
At 45cm I'd assume you wouldn't lose the plane as quickly, as now you are dodging a lot of the flak, so would price it as killing 2 superheavies in three turns as you still have to deal with interceptors, blast markers etc - about 400 points for 2.
Note no WE around and the plane is hard to make use of. Even with sniping thats few kills of note. Even if you want to switch to Leman Russ or similar hunting you are going to knock out 4-5 over 3 turns if you fly every turn and thats good, but it ain't what you are paying for the plane.
Note I still dislike the 45cm range as with many armies you can't touch, it means you have to take fighters to deal with it, and they will probably die doing so due to the amount of flak you can take as back up. Also even with +1 to hit only large Fighter bomber swarms (6 planes) or eldar can take one plane down with a CAP action, and only Eldar avoid the 2 return flak shots from the planes.
And its all up to CS anyway at the end of the day :)
PostPosted: Thu Feb 09, 2006 9:01 pm
Quote (The_Real_Chris @ 09 Feb. 2006 (11:33))
TRC,
quote=Tactica,09 Feb. 2006 (16:46)]In 40K- the core design, the AX-1-0 is a well armored super heavy fighter- bomber with speeds surpassing any Imperial bomber and being on par with the barracuda.
Looking at this download (nauty I know) it says 10 10 10 for its amour. I don't understand 40k stats but it says 10 10 10 for the barracuda as well.[/quote]
In 40K - superheavy armor at 10/10/10 means better armor than vehicle armor at 10/10/10. Reason: Superheavy and Vehicle are defined terms with rules behind them.
Example, they have different damage charts in 40K. A superheavy can actually repair damage if things go well.
The nature of E:A's game development whether we like it or not - jervis approved it, its in writing, see swordwind?
[quote]Finally, the planes missles are limited to 45cm in E:A - and the proposed is to have all weapons reduced to 30cm.
Interestingly enough, GW would challenge your interpretation in that
1. Barracuda was directly mentioned and defined in the previous Tau codex as being an air superiority fighter.
2. The Skyray (AA vehicle) is in the new Tau Empires codex as a base vehicle and main tank with AA option.
3. battle reports in White Dwarf are starting to include planes in batreps.
Some might say GW appears to be moving to embrace aircraft in core design despite your opinion.
[quote]and people have mixed views on how well they work (everyone can shoot the plane or something as well there, I admit to being a bit vague).
LOL - I get the feeling you argue for the sake of conversation sometimes. :/
Make a series of rules for craft which some armies have a lot of access too and others don't have much access too - I don't care what it is... you will get "people that have mixed views on how well they work."
Your statement here is not only vague, it's also irrelivant.
Fact is - Aircraft work in 40K better than the way they work in Epic by the following factual measures my friend...
1. In 40K, there's an answer for dealing with aircraft period. Even *IF* the general did not have the forsight to take an appropriate amount of flak or AA counter measures. - problem in epic, not 40K.
2. In 40K, there's an answer for AA moving rediculously - and firing at aircraft - problem in epic, not 40K.
3. In 40K, there's an answer for aircraft having the same weaponry, ranges, stats, and damage as ground formations with the same skills and weapons - problem in epic, not in 40K.
If you would like me to extrapolate on the above 3 points...
Typical ground formation ranges in 40K are reduced range by 12" when/if they attempt to fire at aircraft.
For perspective:(and if memory serves on all ranges)
Tau Railgun = 108" range normally would go to 96" range.
IG Battlecannon = 72" range normally would go to 60" range
Chaos Lascannon = 48" range normally would go to 36" range.
Marine Bolter = 24" range normally would go to 12" range.
IG Laspistol = 12" range normally would go to 0" range.
Algorithm for firing in 40K
Static "7" - your unit's Ballistic Skill(BS) = roll to hit
BS for IG is 3, BS for marine is 4
Example:
7-3 = 4+ to hit (IG).
7-4 = 3+ to hit (Marine).
If you have an AA mounted weapon, you CANNOT move and fire your weapon. On the other hand, you don't don't suffer from a 'to hit' penalty when firing at aircraft either.
Also, Any ground formation in range, after reduction(s), can opt to fire at the aircraft (if its within range). The caveat, In 40K - you don't get to premeasure. Said ground formation also needs a 6 to hit the aircraft. AA mount vehicles hit aircraft just as easy as they would hit ground formations - so they have a significant bonus when it comes to firing at AA.
In 40K, once you've hit, you then roll a d6 and add your strength of weapon to determine if you've glanced or penetrated armor. (a level of damage you might say)
Once glanced or penetrated, you roll on either a glance or penetrating hit chart to determine the result of the hit.
Basically on a glancing hit, it takes a 6 to blow the plane up (unless you imobilize it - which many armies have auxilary damage control systems to eliviate).
Basically on a penetrating hit, a 4+ on the chart will blow it up.
Superheavies have more resilency as they have glancing and penetrating superheavy charts. They don't have immobilization, just speed reductions and what not. They also have a catastrophic damage chart - which one result is - Fire Control Repair: Superheavy gains one hit back!
As if... LOL...  :alien:
Rob
PostPosted: Thu Feb 09, 2006 9:07 pm
Quote (Hena @ 09 Feb. 2006 (11:05))
I would have no problem with overly good plane. 4+ RA, with 45cm TK(d3) * 2 at 3+ main guns. Just make sure the cost is 600 then per plane :D.
Hena,
I realize your comments were in jest.
Note though, *IF* CS applies one of his recent comments to playtest, we might just have something that does cost 600 points for the AX-1-0, it will be far better than the stats you quote though for that price. (see 2x Moray - Manta! for equivilent firepower range)
I believe CS said something about the AX-1-0 being akin to a A reverent or reaver not to long ago if he had his way? (something like that!)
Rob
PostPosted: Thu Feb 09, 2006 9:18 pm
Swordwind (Eldar) planes I thought had weapons different to their 40k counterparts.
Well, the last time I played 40k was 9? years ago so I just can't comment on the system, but one thing I can't help but laugh about - Battlecannon hit aircraft? :) (I'm trying to envisage a Panzer 4 shooting at a Typhoon.)
At least I know not to bother with 40k again! :)
PostPosted: Thu Feb 09, 2006 10:15 pm
[quote="The_Real_Chris,09 Feb. 2006 (14:18)"][/quote]
TRC,
Don't know for sure, but doesn't go back to - I said the AX-1-0 was neutered in E:A, although perhaps justified... and you countered. (Why I'll never know). Regardless of other list precidents - the aforementioned point still remains.
I suppose you missed the rest - about how 40K deals with aircraft better... anyway...
I didn't want to get into all the rules... I only gave what was needed to prove my point.
First, Battlecannons are not only for Leman Russ.
Second, the Thunderhawk Superheavy Aircraft has a Battlecannon you'll recall.
Furthermore, anything that utilizes a blast marker (large or small) cannot fire at aircraft in 40K.
In order to achieve an exception, the weapon system must have an Anti-Aircraft mount. To date, Battle cannons are not mounted on Anti-Aircraft mounts unless you are using a VDR vehicle (Vehicle Design Rules) which require opponent's permission.
So no, Battlecannons cannot typically fire at fliers in 40K either TRC.
BTW: Zoanthropes aren't very good at AA in 40K. No AA mount.
Guess the guys in the 40K dev figured that one out too... not to bad of a aircraft system after all in 40K, eh? Looks like 40K is a better precident for Aircraft rules than Epic is by your measure.
Your commentary will be missed. Safe travels and God speed
Cheers, :cool:
Rob
PostPosted: Thu Feb 09, 2006 11:50 pm
Quote (Tactica @ 09 Feb. 2006 (20:15))
They haven't been AA in Epic until recently either. Design choice seems to be a case of 'hey this army has no AA - better give them something!!'
PostPosted: Fri Feb 10, 2006 2:50 am
Tactica
(Just to prove I'm still here ?:p ) - I think you are arguing (reasonably convincingly) that the air rules mechanisms in 40K are somewhat different from those in E:A. If this is the case, it does not seem logical to cite 40K air rules as a basis for supporting the TS stats in EA (with regards the 45cms range for example) - you can't have it both ways.
You also seem to be suggesting that you prefer aspects of the 40K system over that in EA - is that true? I would like to know, as I am trying to find ways of improving the EA air rules, and am open to suggestions
Finally, keep it up guys - we can get to P18 yet to fulfill Honda's dream / nightmare :laugh: (well I had to see if I could have the last word anyway)
Ginger
PostPosted: Fri Feb 10, 2006 7:41 am
Quote (Ginger @ 09 Feb. 2006 (19:50))
Tactica
(Just to prove I'm still here  :p )
LOL :)
No question, different game.
That was not the point of my post or my intention. Let me give you a quick summary which leads us up to the post you are commenting on.
TRC was on one of his AX-1-0 rampages.... Dobbsy got frustrated as we've heard everything from further reduce the armor, increase the points, reduce the range, eliminate TK, take it to one shot... etc... I agreed with Dobbsy.. the suggestions are becoming absurd for us Tau fans - considering what the plan is really meant to be in core design.
The AX-1-0 is already quite neutered. That statement was something I made many pages ago. TRC didn't like that statement, specifically I said the AX-1-0 is neutered from core design... In that same post, I also said that it does need to be dumbed down from core design to align with E:A... (i.e. v4.3.3 seems adequate statistically).
TRC then challengest hat the AX-1-0 has been neutered from Core design...
So although I'm not tryng to get the plane to be any better than what it is, and I'm not lobbying anything, I'm just responding to TRC's challenge. He's wrong, the plane is dumbed down from core design.
I then presented how the AX-1-0 was indeed neutered as he asked.
He didn't respond once the info was provided.
He chose to only comment about armor 10/10/10... so I futher had to explain that one point to him...
He then digressed and made the claim that 40K aircraft rules were inferrior to E:A. He then used that as a basis for his argument that we cannot take 40K planes and convert them over to E:A. Further trying to defend some stance rather than backing off his original challenge.
So I further had to tell him how he was wrong - again. 40K air rules work quite well.
He then wanted to pick out one thing... battlecannons out of my example to try and comment on.
I then had to explain that I didn't give him all the details, just enough to prove my point. I further explained how Aircraft rules in 40K cover that as well... he didn't respond.
All the while - all of this is irrelivent. The AX-1-0 is neutered in E:A from core design... whether TRC likes it or not - its fact. It was intentionally done for balance. Us Tau players only want to give so much. Its going to get to the point to where it's not a SHT or Titan hunter pretty soon. Yes, it has the capability to waste multiple marines with one blast marker shot too in 40k... its fully deserving of the current profile. Maybe the points are quite right, but its most definitely deserving of the current profile - and then some.
My point is NOT to say that it needs MORE than v4.3.3... Not at all in fact. Although points may be an issue, statistically the plane is working quite well IMHO in its current dumbed down fashion. Many of us just don't want to see it get worse.
We definitely don't want to a reduction based upon flawed logic. I was only responding to TRC to clarify the flawed logic and erroneous claims.
At any rate, I do agree that the TS AX-1-0 cannot be what it is in 40K. I make no claim that it should be. Hopefully that is clear.
I love both games. They both have similarities, and Epic is a derivative of 40K whether Epic fans want to hear that or not. Without 40K, there'd be no epic.
Its true that 40K does things better than epic. The inverse can also be said. In this particular case, 40K deals with fliers much better - that's true.
Well, don't want to bore the group to tears. To understand the 40K flier rules, you have to understand the base game. That would take some time. I'd recomend some off line research on the topic Ginger.
Ginger
I'm about done with the whole AX-1-0 topic - regardless of what CS desides. Defending core design at nauseum is silly and taxing. It typically only serves to educate the challengers of the list, not the fans IMHO.
It takes a terrible amount of time and enjoyment out of this process for me.
Rob
PostPosted: Fri Feb 10, 2006 8:48 am
@Tactica,
very well done. It also reflects to the point that most of the Fans are (IMHO) sick of this revolving without consensus. For me , I will now wait CS?s decision , as in summa sumarum 27 Pages of Discussion are enough , isn?t it?
Cheers!
Steele
Quid pro Quo
PostPosted: Fri Feb 10, 2006 10:24 am
In fairness to TRC, I don't think I've seen a suggestion of his that involved making the TS have a non-TK main weapon. In fact, I think I recall that his last suggested design made it a TK(Dx) weapon, which fulfills the design criteria much more effectively than 2 x TK(1). I thnik he'd also boosted the accuracy back to a 3+, from the 4+ it is at the minute (to reflect the twin-linked nature of the railcannon, a core element of the design that the current stats ignore).
Going back to your objections, the cost per plane wasn't increased - in fact, there was a marginal decrease (by my maths, as 2 * 175 comes out at 350pts, compared to the suggested cost of 325) - though, admittedly, the cost to field any at all would increase. Yes, he dropped the armour (why, out of interest, did you phrase it as further reducing the armour? It wasn't like he suggested dropping any DC, though a TS to Marauder comparision would promote that view), and yes, he cut the range (something I can see the logic behind, and would probably agree with, on the condition that playtesting was performed), but even your AC has admitted they're to good for their cost as they are now.
Honda even managed to succesfully press for a rough cost assuming Chris' stats but with 45cm LRC range (or that was my interpretation of it). THis does involve a per-plane increase in cost, but keeps this (apparently) vital part of the design - why not playtest it with that statline?
As a penultimate point when dealing with this quote - I'm not a fan of changing the "design paradigm" of in-the-box lists to feature a greater emphasis on air - this, to me, goes against how Epic should be, which feels like it should have aerospace assest as a dusting on the top, not a core component of the list. Of course, some might say the same about WE-heavy lists such as AMTL or OGBM, so I guess we'll have to see. AS a gut reaction, though, I'd argue its an unwise move.
WRT the AA Battlecannon comment, TRC admitted he knew nothing about the current 40k system, let alone the Air rules - as you hadn't mentioned that Blast weapons couldnae target aircraft, how unreasonable was it, really, for him to make the AA Battlecannon comment? Not overly. I must admit that I'm not a fan of the air rules for 40k - they feel tacked on the the core system to me, to an even greater extent than the air rules in Epic.
The forgotten Champion - AMTL, baby!
Dysartes.com - Resources for the Modern Wargamer - Last updated: December 2004 - Next Update: In Progress
Sentinels are just young titans that haven't grown up yet!
