Post new topic Reply to topic  [ 113 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8  Next
TAU WIP 4.2 - Here - See Link in post
 Post subject: TAU WIP 4.2 - Here - See Link in post
PostPosted: Fri Nov 18, 2005 7:22 pm
Quote (Tactica @ 18 Nov. 2005 (17:19))
Asaura,
Thank you for your comments.
CS,
Thank you.
[edit] clean up my response.
Tactica,
Sorry about that. I didn't have a case for that kind of "accusation". I'll stand by the "you're doing a good job" bit and retract the other thing about poor form. Again, I'm sorry.
PostPosted: Fri Nov 18, 2005 7:35 pm
Asaura,
and well met. No worries. Thank you for your follow-up.
Rob
PostPosted: Sat Nov 19, 2005 9:26 pm
Tactica, you have me listed twice in the credits section, as I am Gary Carney...
That's it for now!
(nice handling of the Spacecraft Tracer bit, putting it into the ML+GM rules!)
Gary
v7.3 pdf
PostPosted: Sat Nov 19, 2005 9:34 pm
Except you missed Slow and Steady for the Custodian...
Gary
v7.3 pdf
PostPosted: Sun Nov 20, 2005 2:58 am
Gary,
I'll fix name and Custodian slow and steady in next revision.
I'll work on that.
cheers,
Rob
PostPosted: Mon Nov 21, 2005 1:45 am
Gary,
4.2.6 is up. Fixes your requests, changes Skyray to something for folks to test to see if that does the trick as per that thread on Skyray.
Again, not meant as a replacement of CS work people. The WIP is just a list for folks to continue testing with that they've developed and works for something people can use while CS gets his hands around the various clean up items and remaining decisions in his 4.3.1 list.
As long as people are still using it and CS doesn't mind, I'll keep updating it.
Thanks for the feedback I've received, enjoy and Cheers for the Greater Good,
Rob
PostPosted: Mon Nov 21, 2005 1:47 am
I've just been skimming through the Tau list and stumbled across the XV 88 stats... There's a typo that says "twinn-linked", but what actually made me care was that it said "2x twin-linked railgun" for a broadside. Shouldn't it be just one twin-linked railgun? Guess it wouldn't really change the stats, so it's basically just a question of fluff and / or having the same weapons as in 40K.
PostPosted: Mon Nov 21, 2005 2:14 am
There are 2 Broadside suits to each stand!
(Look in the design notes for basing Tau infantry, it's just before the specail rules in the pdf)
Gary
v7.3 pdf
PostPosted: Mon Nov 21, 2005 2:17 am
snotgun,
"Twinn" issue resolved. see main post for link
also, 2x reflects the fact that there's 2-3 broadsides per stand.
the plasma was never changed to 2x for lack of need from playtest results thus far.
cheers,
Rob
PostPosted: Mon Nov 21, 2005 2:22 am
I'd rather it had the SMS, but that's another story!
Gary
v7.3 pdf
PostPosted: Mon Nov 21, 2005 2:24 am
Heh, I even thought about that before, but I rejected the idea because the twin-linked Plasma Rifle on the same broadside wasn't noted as 2x etc.
/edit
@tactica: ah, thanks for the explanation... :)
PostPosted: Mon Nov 21, 2005 3:00 am
Quote (Nerroth @ 21 Nov. 2005 (01:22))
Gary
Gary,
As you've probably noticed, there's been several to ask for this. The way its been considered so far is like the crisis
2x Twin-linked Broadside Railguns
Twin-linked Plasma Rifle
Smart Missile Systems
However, its never really been playtested to the best of my knowledge.
Rob
PostPosted: Mon Nov 21, 2005 11:29 am
I asked this a while back:  SMS and Plasma Rifles have essentially the same stats (30cm AP4) so it's just a naming thang.
Orde
"I'm smelling a whole lot of 'if' coming off this plan."
Tau Army List Archive
PostPosted: Mon Nov 21, 2005 5:02 pm
Orde,
Exactly, so unless the unit needs an additional shot at 30cm or an ignore cover shot, its basically in there.
From a weapons perspective, the unit appears to be working - or at least i've not heard games where there are issues with them not dealing enough damage to AP targets and such is requested. The army tends to have neough AP shots.
So unless there's significant demand for AP on the broadsides, personally, I don't see any reason to change it. If we want to change the name of the weapon to SMS and Plasma Rifles, we can, but its an asthetics change if anything.
Rob
PostPosted: Tue Nov 22, 2005 12:25 am
Well, I wasn't expecting to actually stir debate on the issue...
If the change is made to SMS, it should include Ignore Cover - but drop the Plasma Rifles altogether.
That's if you want to change it at all.
(I wouldn't mind seeing the XV81, XV84 and XV89 upgrades for Shas'els, with the R'myr suit for a Shas'o - though the latter could be modelled more or less as it stands, not sure whether the flechette dispensers woud be much benefit in CC in Epic. Then again, they could force First Strike units to strike simultaneously, or some such...)
Plus I hope FW make Epic scale models for them! Hey, if they can do O'shovah, why not?
Gary
v7.3 pdf
cron
