Post new topic Reply to topic  [ 76 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Aspect: List Structure and Options
 Post subject: Aspect: List Structure and Options
PostPosted: Mon Dec 22, 2008 2:50 am
Hammerhead Cadres
I understand the calls to relegate the HH to a Support formation. However, these were specifically added as a core cadre because it made the force extrememly fragile, and a little one-dimensional with most Tau armies being essentially infantry forces and no way to get around or make the force your own. I am aware of the danger of an all-skimmer Tau force (negating the problem of low close combat by being a skimmer) and would like this solved, but if there is a way to do this while keeping the HH as a core Cadre I would prefer this. In addition, the HH are about the only unit that is a reasonable financial cost.
CS- I don't think you can keep them core and balance them too. The support formation myself and I think Hena both propose, still let's the Tau take up to 6 Hammerheads as a single support formation. The only difference is that it's not core. This means it doesn't preclude you from taking a large HH formation (even 3!) to avoid fragility, just that you can't choose to make your entire army out of "all-skimming" HHs. Much more balanced IMO.
We have to be aware that people will not want to play Tau if they have to buy loads of expensive infantry, and that less players helps no-one
2 packs of FWs is far from "loads of expensive infantry". If they want they can stock up on Crisis suits which are far better price-wise. If people don't want to play a game because its expensive they're in the wrong hobby. It's apparent from the get-go that Tau are not your averagely priced army to buy.
Besides, there are plenty options for proxies out there. Heck, most people would most likely be proxying already.... It shouldn't be a major concern of yours to balance the list based on cost mate. Table top wargaming isn't based on this principle in anyy major way IMO. Sure it's nice but it shouldn't be a focus.
PostPosted: Mon Dec 22, 2008 2:57 am
Quote: (Chroma @ 19 Dec. 2008, 14:02 )
Quote: (Lion in the Stars @ 19 Dec. 2008, 20:59 )
Aircraft are only onboard for their activation, so all adding MLs to Tigersharks (and AX10) does is give them the ability to engage with GMs without needing support on the ground.  It's not like a ML-equipped aircraft is sticking around and lighting everything within 30cm like the ML Sentry Turrets did.
Actually, aircraft aren't removed from the table until the End Phase, so, yes, planes could be used as "Sentry Turret"-like models, since they could be placed *anywhere* desired.
It's a common house rule to disengage with them immediately to prevent an enemy "flak rush" which many don't find plausible.
Ah, I'd been playing them like air in Flames of War (show up, get flakked, attack, and leave as a single activation).  Now your opposition makes sense.
Shmitty, we're trying to do some serious housecleaning on the special rules right now.  I think the list is completely playable, but it's likely to undergo some significant changes yet.  The biggest issue is getting the army to not play like a long-range gunline (which isn't fun to play against), and fix the "point-and-click" issues with the Moray and Scorpfish.
PostPosted: Mon Dec 22, 2008 8:30 am
Quote: (Hena @ 22 Dec. 2008, 13:07 )
Scorpionfish isn't a point and click unit.
And neither is a shorter ranged Moray...
Just call me Steve.
NetEA Rules Chair
NetEA FAQ
Some of my Armies.
My Hobby site.
PostPosted: Mon Dec 22, 2008 9:24 pm
Or a Moray following the tried-and-true rules for popped-up skimmers. :)
PostPosted: Wed Jan 07, 2009 1:39 pm
Sure. I will put together an updated force list.
PostPosted: Wed Jan 07, 2009 7:02 pm
2. No SC upgrade on scorpionfish
What is the issue with this? What imbalance does it introduce into the list?
Honda
"Remember Taros? We do"
- 23rd Elysian Drop Regiment
PostPosted: Wed Jan 07, 2009 8:54 pm
Two things. Current SC upgrade is way too cheap since you get a free Shield with it. Secondly it really allow all Vehicle force. Without this it would force at least some Crisis suits in the list. Basic idea is similar to IG where Mech Infantry is forced upon you if you wish to have SC.
1. If the cost is not appropriate, then it should be adjusted.
2. There should be nothing wrong with taking an all armor force if it doesn't cause a list imbalance. There is nothing in Tau fluff that I am aware of that states that you have to take infantry unless one is directly modeling the list from the 40K codex. If that is true, then it should be stated up front with the list vision.
Again, what play imbalance to the list is this causing?
Honda
PostPosted: Wed Jan 07, 2009 9:01 pm
Can I just ask the reverse question, Honda?
Why do you feel the Tau need more than one option for a Supreme Commander?  Is there any reference to Shas'O not leading from within a Crisis Suit anywhere?
PostPosted: Wed Jan 07, 2009 9:16 pm
An Ethereal in a Manta as Supreme Commander would make more sense than a non-Crisis suit Shas'O.
PostPosted: Wed Jan 07, 2009 10:14 pm
Chroma,
Yes, it is fine to ask the question.  :cool:
Does it have to be there? Maybe not, it is a characterful differentiator in the list, but again it's not the magic bullet.
My point, though was this: We have been arguing incessantly on personal preferences vs. addressing issues and units that cause the list to be imbalanced. This particular formation has been in the list for quite awhile and at least in my exposure to opponents (which I freely admit is not the entire community), no one has ever said, "That unit, that one right there makes the list broke". So in an effort to identify what the big rocks are, I'm trying to find out, what is the beef with the unit? Does it imbalance the list?
That is what I am trying to find out. If as Hena has proposed, it is costed too cheaply, then let's focus on that issue, but not throw out the baby with the bath water.
Honda
PostPosted: Thu Jan 08, 2009 12:28 am
As BlackLegion stated, Manta's can control the battle field operations (ie Supreme Commander)- from the Tau 40K Codex.
We don't have a problem with Scorpionfish/SC upgrade at all but if there was a change, I'd like to see the Manta have a SC option.
It would almost always be the BTS unit so it would cause an interesting dilema.
Just call me Steve.
NetEA Rules Chair
NetEA FAQ
Some of my Armies.
My Hobby site.
