Post new topic Reply to topic  [ 287 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 20  Next
Aspect: Tau Units
 Post subject: Aspect: Tau Units
PostPosted: Thu Oct 23, 2008 11:13 pm
IF the Manta becomes a bomber (like the SMLC and Vampire), then a 45cm main gun is OK (and is identical to what's on the AX10, coincidentally).  The turn the Manta's on the ground will be a little funny (since the Rails SHOULD reach 105cm/90cm for the Ions), but aircraft need to have shorter ranges than the same weapon on a ground-mount for balance.
Fluff/PSB Justification:  due to the speed of the aircraft, by the time the weapon has a lock and the pilot fires, the craft is much closer to the target than the same weapon on a ground vehicle.  Also, Aircraft weapons are on a fixed mount, and cannot elevate, which reduces their range compared to a ground-mount when the aircraft is on the ground.
PostPosted: Fri Oct 24, 2008 12:13 am
Quote: (Evil and Chaos @ 23 Oct. 2008, 23:31 )
Also, FW only gave 8x 360 burst cannons in their E:A stats, since only half of the BCs can fire at any given target.
That's something I like; Half the 16 guns can fire down so you get 8x AP shots, and half can fire up, so you get 8x AA shots... elegant.
Look at the model of the Manta. It has 10 Burst Cannon turrets on the underside but only 6 Burst Cannon turrets on the top.
So it should have 10 AP shots and 6 AA shots.
PostPosted: Fri Oct 24, 2008 12:14 am
Or you can be all abstract and stuff and use 8x shots. :)
PostPosted: Fri Oct 24, 2008 12:15 am
Whatever you guys prefer. I prefer wysiwyg :D
PostPosted: Fri Oct 24, 2008 12:28 am
10 AP shots is overkill, and difficult to phrase on the datafax. 8+8 works better, or 4+4 twin linked if 8 is proved too many.
PostPosted: Fri Oct 24, 2008 1:07 am
10 30cm(or 15cm regardless of being Long-Barelled?) AP5+ shots and 6 15cm AA6+ shots i would say.
Per habs with shots split in half for a left and right fire arc respectively.
PostPosted: Fri Oct 24, 2008 3:27 am
Much too fiddly. And the AA attacks are coming from the same weapons, yet would need different weapon names in the datafax? Ugly.
8+8 is a nice, simple way of doing it, and as close as damnit to correct when you consider fire-arcs (all 10 won't be able to fire at one target). It's what FW went with. Either that or the current 4+4, I'm not enormously bothered either way.
Certainly 15cm range - it's a plane, and they usually have reduced firing range.
PostPosted: Fri Oct 24, 2008 9:04 am
Quote: (Hena @ 24 Oct. 2008, 13:34 )
If Manta was an aircraft, I certainly wouldn't buy it anymore. I think that's horribly bad idea overall.
Agreed.
As I said in another post, How can you have such an expensive unit, not even turn up on the board if you fail it's activation?
Just not a playable option.
Just call me Steve.
NetEA Rules Chair
NetEA FAQ
Some of my Armies.
My Hobby site.
PostPosted: Fri Oct 24, 2008 11:50 am
And as has been said, it would be comparable to a Marine Landing Craft, and far from thinking those are a bad option, people think they're awesome.
PostPosted: Fri Oct 24, 2008 3:24 pm
You wouldn't even playtest it? I'm just looking to see if the idea is even feasible to make it a bomber, and you yourself often say that without playtest evidence nothing can be proven.
PostPosted: Fri Oct 24, 2008 7:58 pm
The SMLC and Thunderhawk are also both spacecraft.
PostPosted: Fri Oct 24, 2008 8:00 pm
If it only hovers over the battlefield, then it wouldn't be able to hit ground targets with it's Heavy Railguns and Ion Cannons because they are fixed so that they only fire straigt forward.
Only the Lb Pulse Cannons mounts can rotate to point to the ground.
