Post new topic Reply to topic  [ 106 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
Development Plan
 Post subject: Development Plan
PostPosted: Thu Nov 06, 2008 1:01 am
It's 55cm, as -5cm movement is part of the proposal.
Previously they could move 50, shoot, then jump back 10 when assaulted for 60cm of movement. That is actually reduced to 55.
PostPosted: Thu Nov 06, 2008 3:13 am
Can someone please answer my question?
Ignoring their speed for the moment, how is moving back 15cm after moving to within 30cm of the enemy any better than jumping back 10cm with jet packs when an engagement is decalred?
You're still out of range to engage....
PostPosted: Thu Nov 06, 2008 3:25 am
It encourages the use of the 15cm ranged guns, can't happen several times in a turn and allows other formations other than the one shot at a chance to engage.
Most importantly, it forces the Tau player to decide which direction to move in before he knows where the enemy is going to be engaging from.
PostPosted: Thu Nov 06, 2008 4:10 am
I disagree in general. The moment I read the proposal I was immediately looking at a 30cm range for the 2 other weapons each with a 30cm+ range. I still couldn't be engaged. I'd use MW in a gamble/all-or-nothing attack only.
can't happen several times in a turn .
Then why not just change Jetpacks to say "only the first engagement declaration in a turn" or something to that effect?
Are you saying people never set up other formations to do this??? If you are, then they are shooting themselves in the foot. Really, if you can't manoeuvre your forces to set up an engagment on Crisis suits then there's something wrong. Air assault as the only way to engage them well is a falacy. It really is.
I think this is falacy too. Seriously 10cm jump back is bugger all in terms of facing two formations. Giving them 15cm jump back doesn't really make any difference to your reasoning here as I automatically know that I will jump back 15cm before they can engage. I'll simply move to within 30cm get my 8 shots and back off out of engagement range.
This proposal adds nothing to Jetpacks. It's a red herring.
PostPosted: Thu Nov 06, 2008 4:29 am
Having playtested it several times I can say with certainty that it's a lot less annoying to play against.
PostPosted: Thu Nov 06, 2008 7:38 am
I still mean to do proper replys to these threads and they are half done but sadly work is intervening. Something that should change with the jump packs is the amount of rules questions they generate. It seems every time I use them another query comes up.
PostPosted: Thu Nov 06, 2008 1:19 pm
I second this... having playtested it around a dozen times, this version of the 'can't catch me!' Special Rule is less annoying, and disrupts the flow of play less too.
It also allows the conventional 'Move first unit into Support range, then engage with second unit on a Retain' tactic, which the current Jetpackers are nigh-immune to.
PostPosted: Thu Nov 06, 2008 1:26 pm
Even though I don't fully agree with that E&C and zombos proposal, I admit it does sound better than current rule.
Rats Keep Running...
Dark Eldar Dracon
PostPosted: Thu Nov 06, 2008 10:01 pm
Sorry, but I still fail to see how this is any better than current rules and totally disagree with your nigh-immune comment. If you can't get into engagement range with a 10cm jump back, then you won't get into range with a 15cm post-firing jump back as the suits are further away than they would have been before. You can't engage with the support formation(as it moved first into support range) OR the Assault formation as the suits will be too far away. As Hena puts it, it's a bogus argument.
To assault suits you have to have incorporated the 10cm jump back into your movement equation for engagement. If you're doing anything else you will not engage the suits. It's that simple. A 15cm move back makes it even more difficult.
Can you give a playtest example?
BTW shouldn't this discussion be in Aspect:Units??
PostPosted: Fri Nov 07, 2008 10:53 am
Just a quick chip in to support Dobbsy.
I am also confused as to why the 15cm move after shooting rule is better than jetpacks.
Using E&C's example of moving support up and then engaging. I place the support on the other side of the Tau to then prevent them from jumping back out of engage range. Job done, no?
PostPosted: Fri Nov 07, 2008 12:45 pm
I have to admit that this is how I do it... when I play against the Tau (which is rare these days).
PostPosted: Fri Nov 07, 2008 4:48 pm
What about to give them simply 25cm move with Jumppacks (or Skimmer without PopUp).
Nothing else? No special rule.
Really. The way Tau Jetpacks and Jumppacks work in Wh40k doesn't justify something special to differentiate them in Epic (other that Jetpack units doesn't double the Movement of Infantry units as Jumppacks do which represents that Jetpack units in Wh40k are in fact slower than Jumppack units).
Good armour is all what they need to represent that they can zip in and out of cover during shooting while other Infantr has to remain stationary to fire heavy weapons. And they already have a 3+ save which is good enough.
