Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 86 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Most significant implication of Codex: Tau Empire
 Post subject: Most significant implication of Codex: Tau Empire
PostPosted: Tue May 02, 2006 6:48 am
Quote (Xisor @ 01 May 2006 (21:19))
Xisor
Variables - Good idea, harder to balance (not to say it shouldn't be tried).
Firewarriors as core - You certainly ensure there are a lot more firewarriors around! Do you think though that its very similar to marines? I.e. The core marine unit is the Tactical marine, going to every battle etc etc. Okay he does most of the time in Epic too but thats because hes a good deal. They still have seperate Pred, Land raider etc formations even though these guys are in direct support in the fluff and only occasionally is a Land raider squadron mentioned (with no mention of pred or vindie squadrons).
And what, you don't like all Hammerhead formations? :)
The problem with this is that formations based on infantry get shredded by things like Leman Russ companies. Many a time my heavy tanks have let rip at a mech or infantry formation at 30cm. Really there is nothing left (plus you get to throw 40 different coloured dice and left a psycological scar on the opponent).
The best thing to job a Russ formation (other than cheap TK planes :) ) is another armour formation. You need speed to intercept the tanks, you need weapons to scrap them and you need AV armour to reduce incoming fire and give you a chance of saving if you've made a mistake setting up the attack.
4 Hammerheads, 4 Swordfish and 2 Skyray for 700 points have a grand chance against 10 Russ and a Hydra (though probably a Russ company plus Hydra and 3 more russ is more common vs 8 Hammerheads 4 Swordfish and 2 Skyray). With the chance for co-ordinated fire from another formation (the old pathfinder double, mark, sustain sustain) or and great mobility allowing pop ups and better chance of cross fires they are ready to rock and roll. Add in Firewarriors instead of tanks the AT firepower drops and the Russ have a target to use their heavy bolters on.
Surely based on their mastery of modern tactics the Tau would tell the infantry to go and secure the nearby town, then mass their armour and ambush the tanks?
PostPosted: Tue May 02, 2006 7:13 am
Quote (The_Real_Chris @ 02 May 2006 (06:48))
TRC,
There's a reason Hammerheads have a range of 75cm.  :p
On a more serious note: That's a perfectly valid point. However, Tau must surely have better ways of getting the job done. Matching the Imperium 1 for 1 doesn't seem the Tau 'way'.
A couple of formations sitting a good 50cm back trading railgun shots[from their broadsides and hammerheads] seems feasible. That is: 8 Fire Warriors +  2 Broadsides + 2 Hammerheads[475pts a piece] in v4.4 would become a Cadre more suited to, as I proposed: 4 FW + 4 Broadsides + Swordfish. Put a couple of these things down in a 'rough' style to the army and you'll have a force that is essentially a rival of your Leman Russ'. Great AP fire in close, exceptional AT fire at range.
Obviously for such a thing the costs would go down due to the 'exposed' nature of such formations[as you note: vulnerable to AP/AT rather than just one].
As an aside, to accurately represent the 'core' of a Cadre[on thinking] it'd require:
1 Crisis Unit
2 Fire Warrior Units
Anyhow, I'm dead-beat tired just now, and likely not making any sense!
I'll be back soon...
Xisor
"Number 6 calls to you
The Cylon Detector beckons
Your girlfriend is a toaster"
PostPosted: Tue May 02, 2006 12:48 pm
OK. Let me see if I understand this correctly. The proposition is that there is a core Cadre, and upgrades are added to this. In addition, Contingents (as they now stand) are scrapped. This would mean that the Tau player then tailors each Cadre, based on the core, for a specific task.
Xisor: Is this correct, in a simple form?
If so, the main problem that I can see here is that it would erase the armoured formations (in your example, the core Cadre is four FW and a Crisis - w/Dfish).
Again, we have a balance decision between background/40K, and EA playbility. By removing the option of a purely armoured Cadre (which, by the way, was the last Cadre to be added and was done so out of a requirement within the list), we restrict the way that the Tau list will actually play on the field. As an opponent, you would know that every Tau Cadre will have four FW units with Dfish, and you force the Tau player to use the list that way.
I am certainly open to 'theming' the Cadres, in fact one change in the last version of the list was to remove many of those 'any upgrade' comments and be more sepcific about it, but I do think that an armoured Cadre is an important and flexible addition.
From what I can see, 'downsizing' the core Cadre size (particularly in the case of the FWs) and restricting the upgrades/Contingent would achieve the suggested result.
However, I do feel that some Contingents are required, for example the Piranha, perhaps the Pathfinders...
PostPosted: Tue May 02, 2006 1:57 pm
Ok, I've stayed out of this thread and just caught up and was quite surprised at the direction this has taken. A couple of comments:
1. Just because we are empowered to change, does not mean that we should change, just for changes sake. One reason for wholesale change in a list is if it just doesn't work or like the Tyranids, doesn't fit design guidelines.
Xisor: Are you proposing that the current Tau list does not meet any of those conditions?
2. I'm struggling to see where the new proposal improves the "play" of the current list. In fact I see it taking us back to earlier versions which we have spent many months moving away from. I personally did not like the state of those earlier lists because they literally codified weaknesses and inflexibility into a force. As CS pointed out, one of the reasons the AMHC was introduced to the list was to address an area of weakness that the Tau were facing against armored opponents. TRC also made similar comments.
3. Fluff is a guideline. It should be used to provide a framework for development. Basing all of our work on specific fluff text is unworkable. After all, quite a bit of fluff describes events that are unworkable from a games mechanism perspective IF the overall goal is to provide a balanced game system. If you ever referred back to WD 300 (US version) GW posted a copy of what they called "Movie" Marines. In those rules (which were a lark), they showed you what abilities SM's would really have to have to fit the fluff and even then they were toned down. They were also unplayable within the context of the existing 40K fluff. So be very cautious about hanging your hat (Texas term ?:/ ) on fluff.
So in the end, this is a somewhat interesting exercise, but I really question the value. Perhaps you could take this effort and develop a Sept specific list and drive the development from that angle.
My two yen...
Honda
"Remember Taros? We do"
- 23rd Elysian Drop Regiment
PostPosted: Tue May 02, 2006 3:13 pm
For once, Tactica and I actually agree on translating 40K stuff to Epic, including background material.
Someone alert the media! :p
Xisor:  There is no need to make an organizational element according to the background a single EA formation.  Even forces that are intended to operate in close proximity and might be portrayed as part of the same "unit" (common military parlance, not EA term) need not necessarily be in the same formation.
Basically, even if a Shas-whatever is supposed to be the leader of every cadre/contingent that does not mean he orders them all to work in his immediate area under his immediate supervision and command.  Now, I haven't seen IA3, but in all the stuff I have read there doesn't seem to be anything that would prohibit a Shas-el from saying "you guys go hide behind those buildings over there and pick off targets of opportunity until we call in fire."
Aside from that, it seems simply a matter of changing the army list terminology to fit the background material better.
PostPosted: Tue May 02, 2006 3:17 pm
Quote (Honda @ 02 May 2006 (13:57))
Folks,
First off, it's not a sept specific issue. The terms in the codex indicate this is the case for *every* Tau formation with only minor and obscure exceptions.
Secondly: As the problems concisely listed by CS demonstrate, a Tau force without dedicated armoured formations is a weak list. A weak list such that it is not a productive list.
However, to detail the more *acceptable* comrpomise:
My current 'standing' proposal that I genuinely think is a workable proposal is as follows
1- Superficially rename the current components Army becomes Contingent or Battle, Cadre becomes a 'Core' Cadre and Contnigent becomes a Cadre Specialisation
2- Stipulate, superficially again, that a Cadre as organised by the Shas of the Tau Empire consists of one Cadre Core and up to two specialisations, each being a seperate formation
3- Make upgrades more suited to minor variations. It shouldn't be *too* restrictive per three formations.
4- Take a look at the compositions of each individual formations. In this manner I mean that they should be viable formations to make up an Epic Army. This is where I feel I put most people off in my 'all in one' suggestion. Splitting it into a possible three smaller formations seems the best idea.
5- Between the three 'component' formations[core+ 0-2 specialisations] there should be a possibility to both represent and account for player choice & game viability *AND* to help stay close to the fluff. That is, to represent a Cadre you have a Crisis commander *somewhere*. In the same form, a small portion of firewarriors should always be available. That is, the should perhaps be an option that *fills* the Cadre's the size by providing the 'minimum' that always makes a cadre[2 FW + Crisis Commander], but it doesn't cost you if you simply leave them back at base.
6- My main concern about an ''Armoured Mobile Hunter Cadre" is that you simply wouldn't get an all-hammerhead cadre. That said, by my new proposal[which sticks closely to the current list options] accounts for the possibility of an AMHC that consists of two 'divisions', one being the actual 'all hammerhead/AV formation', the other being the rest of the Cadre. This is in a similar manner to the current list format, but the specific options and formatting would be closer to the one I propose in the Cadre.pdf. The difference from that document is that it can consist of up to three constituent formations, not a single 'all in one' formation.
Again, if that makes sens.
{Apologies for question dodging, but I think I'm more concise if I put my altered position as one rather than account for what I said before!}
Xisor
PostPosted: Tue May 02, 2006 3:51 pm
Quote (nealhunt @ 02 May 2006 (09:13))
Xisor: ?There is no need to make an organizational element according to the background a single EA formation. ?Even forces that are intended to operate in close proximity and might be portrayed as part of the same "unit" (common military parlance, not EA term) need not necessarily be in the same formation.
Basically, even if a Shas-whatever is supposed to be the leader of every cadre/contingent that does not mean he orders them all to work in his immediate area under his immediate supervision and command. ?Now, I haven't seen IA3, but in all the stuff I have read there doesn't seem to be anything that would prohibit a Shas-el from saying "you guys go hide behind those buildings over there and pick off targets of opportunity until we call in fire."
I'll second Everything NH has said here. We do actually agree 100% here.
Which... maybe a first Neal. :)
Rob
PostPosted: Tue May 02, 2006 4:01 pm
Changes..
Cadre->Core Cadre
Contingent->Cadre Specialisation
Ok its a superficial change but... those new names are just not "nice", they dont sound good.  Obviously thats just my opinion but they both use the word cadre, which opens up possibiliies of confusion.  And Cadre Specialisation is just too unwieldy and doesn't sound very Tau-ish to me.  Besides these words are the English translation of whatever language the Imperium uses translation of Tau-ese.  How important is it that those "translations" are correct?  I'd say its more important that the names we use are not confusing and sounds good and Tau-ish.
Since we already have a one cadre allows two contingents rule this concept would appear to have been present all along.
The Tau list is already quite flexible in its upgrade choices.  That said I am sure that if there are suggestions for alternatives we could consider them.  Example?
The "all in one" idea most definately put people off. :)
Three smaller formations.. again it seems like we already have this.  Or is it just the size of those formations that is at issue?
Going to disagree with this.  I have mentioned before that it is simply not viable for a large army to be commanded by a single person on the ground (Crisis Commander).  Thus in EA the Tau need further command options that are not represented in 40k. [And it's not surprising that those commanders are not mentioned in a 40k codex.  Otherwise I would imagine 40k players would complain that there were no rules and models for these commanders.  Don't mention them in the codex and the 40k people avoid those awkward questions.  Besides I bet there is no mention of Morays, Scorpionfish, Stingrays etc]
Surely a result of the scales involved.  In 40k there is no need for an AMHC, so there isn't one.  Just because the fluff in C:TE is written to support the material presented in it does not mean that we should be tied to it in EA.  Basically we are picking up where C:TE left off and taking things from there.
[RL analogy (that may or may not help): when learning physics at school I was first taught that the universe was made of "these things".  I learnt that and moved on.  Then the next year I was taught that in fact that wasn't quite true, "these things" were actually a bit more complex and in fact the closer you looked the more complex in became.  But the point of teaching it the first way was to make it easier to understand the basics before moving on.  I envisage the information in C:TE in the same way.  For the purposes of 40k the information is fine, and if you only play 40k then thats all you need to know.  But in EA we deal with a greater scope and thus there differences.]
PostPosted: Tue May 02, 2006 4:26 pm
ON a random note the Tau codex (or at least the old one) does mention some non-40k units and battle strategies (the big UFO's the fighters etc).
PostPosted: Tue May 02, 2006 4:27 pm
Xisor,
IA3 supports an armored mobile mech - which translate into well as a AMHC in E:A Tau. The AMHC also fills a necessary role in the list. Its a proven element of the list in E:A.
I completely disagree with the interpretation and premis of the argument's basis for change after re-reading the Tau Empire Codex pages in question.
Its true that from smallest group of individual fighting troops to larger elements that the arrangement goes from:
1. ?Mission Groups (smaller Teams)
2. ?Teams (larger Mission Groups)
3. ?Cadres (multiple Teams)
4. ?Contingents (multiple Cadres)
5. ?Coalition (multiple Contingents)
6. ?Battle (multiple Coalitions)
7. ?Command (Multiple Battles)
8. ?Coalition (repeated term, but means entire Empire Force)
etc...
However, Xisor - you've branded where an E:A formation demarkation is or is not in your posted definitions. I think your demarkations are wrong.
Second, the Codex uses Terms like unit and formation - but they do not use them in the context of E:A at all. So you cannot directly link what a 40K terminology uses in a general sense to a specific definition in another game system.
Also, you seem to rely on the following in your argument for change:
The Cadre is a standing formation, and includes a number of infantry and vehicles units within it, including battlesuits and Hammerhead tanks.
You assume this text is an absolute.
First a Cadre could be represented in E:A by multiple functioning elements on the field. SO we could say a Cadre is our current AMHC + Crisis Cadre + a Stealth Contingent + PF contingent. There - Cadre broken up to do multiple things. The same pages Tau empire codex talks about the cadre elements doing different things, each element acting on its own according to a time, calculated plan. It talks about pathfinders signalling targets, FW and kroot acting like lures for the rest of the formation Etc...
Also, as a second point - The quoted text is NOT necessarily read as an E:A Formation. What the 40K codex means by "Formation" and what E:A means by "Formation" are two completely different things. The 40K codex could just as easily said "fighting force" instead of "formation".
Third, absolute definitive of what may ONLY go into a Cadre. Its not a composition list - its a descriptive to mean that Tau use combined arms in their engagements.
Moving on with the book's quoted text...
In this regard, the Tau are very different to the Imperium in the orginisation of their military, for the different 'arms' are fully integrated at the tactical level and are considered in all respects part of the same unit."
Same thing here... "unit" does not mean E:A unit. "unit" does not even mean "Team". Its a generic term. Otherwise, we'd have hammerheads, crisis, and broadsides all glued to the same stand as a single "unit."
This is why you take guidance at a high levle from franchise core development, but you do NOT apply the nuts and bolts from one system to another.
Moving on...
A Cadre keeps a large stock of equipment and vehicles, allowing it to operate in a variety of roles.
Which makes perfect sense in E:A if you do not assume that a cadre is a single E:A FORMATION.
Let's say it this way - A group of E:A Formations, )(which is a subset of the E:A Army but more than a single activation in E:A), keeps a large stock of equipment and vehicles, allowing them to operate in a variety of roles.
See - works beautifully without changing a darn thing!
By fielding an equal amount of Devilfish-mounted Fire Warrior teams and Hammerhead tanks for example, the Cadre may operate as an armoured unit.
Right - combined arms, they may effectively operate as an armored unit - but they are not the same armored unit. Again - do not look at "unit" as an E:A unit. This is 40K codex text. Its true that Tau may combine several different things to a cause to achieve an objective, and we represent that well in E:A. See Coordinated Fire. It does not mean that several different E:A UNIT TYPES have to be merged into a single E:A FORMATION for a single ACTIVATION. That's just silly and is absolutely NOT what this text is saying. This text is saying that Tau align their efforts to maximize strengths as it fits to their strategies.
By fielding Fire Warrior teams on foot as support for specialised Stealth and Pathfinder teams for example, the Cadre becomes an infiltration force.
Here you go - a group of units working in concert to solve a recon mission's needs. It even references the different elements as a force. We all know from 40K that Stealths teleport in and that the pathfinders deploy well ahead of the rest of the force. In working in concert, they solve a tactical problem of infiltrating and disrupting the enemy's plans - that's true. It doesn't say that a general description of "Cadre" must all be the same "E:A activation" as a single E:A Formation in E:A. That's just your application of interpretation. You are equating E:A Formation with what the Tau Empires codex is calling a Cadre. This is not a desirable interpretation nor is it even necessary.
Outside of name changes to align our efforts better with the general Tau org structure I note above, I see no reason to trash the work we have - the list is very Tau. Its very reflective of how a Tau force might fight on a field - even with our self imposed abstractions from the E:A Tau 40K codex ?which include but are not limited to Markerlight effect, stealth fields and FF potential of the list.
Xisor,
At this point, I would fully suggest you develop your own Sept and see what you can do with that effort. I would encourage it in fact.
I'm definitely not on board with changing the main Tau list though. I think what we have is working quite well and solidifying towards change. Thanks for the discussion though. Its definitely given me the opportunity to dig back into the design fluff and further solidify my position on the backgrounds. I'm very happy with the vision JJ presented, JG modified, and now CS continues to pursue with further refinement. I'm convinced we are definitely on the right path in E:A for the main Tau list.
Rob
PostPosted: Tue May 02, 2006 4:52 pm
Tactica,
My point of view is such that the changes I propose are irrelevant for a specific sept list. I have repeatedly stated that the reason this is, IMO, a problem at all is because it appears to apply to the entire Tau Empire, Shas or not
The majority of that I have already dealt with in my posts. That is why I've been making multiple proposals. I'm not tied down to one idea.
For example, perviously I have:
1- Regonised the disparity in terms specific to E:A and those used by the fluff. I have already recognised that formation in the context of the quotes and formation in the context of E:A are two every different things.
2- The results from pages 22-23 seem roughly clear:
Team - The basic unit. Your 'squad' in regards to infantry. In epic terms, these are represented roughly by 1-2 stands of Infantry.
Cadre - A collection of units. E:A formations would be subdivisions or full cadres.
Contingent - A collection of Cadres.
Battle - A collection Contingents, only a temporary force raised to take a specific objective.
Command - The control of an entire locale of control.
Coalition - The entire disposition of a force at a world, system or sept level. The controlling portion that oversees cooperation between all castes and auxilliaries.
My move of late has been thus[as demonstrated by my latest proposals]:
Units- ~1/2 E:A units
Cadres- ~ 1 'core' and 0-2 'Specialisations'. Clausewitz, they are WIP names, I fully recognise their lack of appeal audibly. However, if the fluff for E:A is simply handwaved as different from that of 40k and BFG: why bother?
Contingents- As I propose that each Cadre when used in E:A is represented roughly by a collection of formations, thus the feel of a typical E:A army will be a Contingent. Usually between 3 & 6 'Cadres'
Battle- A big load of Cadres, a collection of contingents. In List terms this is a very big army. Quite simple.
The Rest- Insignificant at this point.
Anyhow, I'll detail more later when I can illustrate myself someone better.
Xisor
PostPosted: Tue May 02, 2006 5:08 pm
Hena,
Tau fundamentals include but are not limited to, :
- Greater Good(GG) = the well being of the Tau Race
- War is a right reserved for advancing the GG
- Assimilation over decimation where adversaries have aligning battle doctrines
- Technology solves most problems the body cannot
- Intelligence, discipline, and doctrine over brute force, emotion & ego
- Combined arms
- Unmatched battleifeld flexability
- Mobility & Evasion
- Arms specialists
- Close Combat avoidance
- Decisive results
- Accuracy of ordinance
There are others, but that's the stuff that comes to mind as I'm typing this.
Our current list acheives all of these things!!!
 - Removing E:A Formations from our list removes flexability unnecessarily.
 - Combining slow moving elments with fast moving elements slows down the list and encourages CC engagements.
 - Creating "jack of all trades" E:A formations is not only counter productive, but it also reduces the likelihood of decisive results from a given action and adds complexity to plan strategically.
 - Combined arms is represented in tactical decisions of a player making formations work in concert with available Markerlights and utilizing Coordinated Fire in E:A - NOT by forcing a player to group unlike fighting elements into a single activation.
Rob
