Post new topic Reply to topic  [ 75 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Skyray
 Post subject: Skyray
PostPosted: Thu Dec 15, 2005 11:36 pm
3-4 skyrays worry a thunderhawk? Considering they are flying bricks supposed to take it on the chin that would worry me somewhat that the flak was getting out of hand. It simply shuts down the sky to enemy aircraft (apart from super heavy flyers) and to be frank thats no fun. I have noted that in larger games lack is so prevailant that only thunderhawks and the like bother turning up. Nevermind air in Epic is  a bit screwy - for instance currently just flying onto the table is bad enough (3+ to activate next turn), a Hydra squadron, say, at 150 points has enough firepower to 2/3's of the time kill a 150 point formation of thunderbolts. Other races are the same.
How much would you cost 3-4 skyrays at if they knock a thunderhawk out of the sky more often than not? (No one likes being air assualted, but for the marines thats the one trick they've got.)
PostPosted: Fri Dec 16, 2005 12:26 am
Probably 125 each, if they get that powerful.
Remember, these are the things that the Imperial pilots wanted confirmed kills of more than anything else (like _other planes_).  One Skyray should be able to sweep TBolt formations out of the sky.
I'd note that the description of the Marine operations in IA3 showed that they'd teleport/HALO drop units in to silence AA defenses before risking Thunderhawks to a couple stationary Hydra turrets.
PostPosted: Fri Dec 16, 2005 1:49 am
[quote="HecklerMD,15 Dec. 2005 (05:28)"][/quote]
Even if they didn't ... inbetween now 21st century... and the 41st 'millenium' - about how many years is that for them to perfect it?
[it being our version of the marked AA and their version in the 41st millenium version]
6000. ?The Tau went from stone age to space age in 6000 years. ?Dont be coy.
@ Heckler - not discounting the rest of your comments, but regarding what you said above:
hmmm...
21st century (thousand) is year 2000+ AD...
41st Millenium (million) is year 40,000,000+ AD...
That's roughly 39,998,000+ years to perfect the technology from what we use in the trade marked 'real life' by comparison to our ficticious friends in the 41st millenium...
... unless my math is wrong (and that's happened more than once!). ? :/
Rob
PostPosted: Fri Dec 16, 2005 2:01 am
That is incorrect Tactica, 40k is set in the year AD 40,000, (or therabouts, give or take a thousand years or so, depending on what events we are looking at), not the year 40 million!
Still a rather long time though.... :;):
www.darkrealmminiatures.com
PostPosted: Fri Dec 16, 2005 8:43 am
Er, and the Tau did not come about at year 0.  They are the new guys remember?
Just out of curiosity, does anyone use the 'cuda for AA defense?  Seams that this guys is pretty strong, and it would make sense that the Aircaste would be intercepting any incoming spaceships, bombers, and assaults more than ground units would be.  Not that ground units wouldn't be, but I would personally like the 'cuda to always be better point-for-point at AA than the Skyray.
Thats just me though....
PostPosted: Fri Dec 16, 2005 9:01 am
Quote (Tactica @ 15 Dec. 2005 (16:49))
Quote (HecklerMD @ 15 Dec. 2005 (05:28))
6000.  The Tau went from stone age to space age in 6000 years.  Dont be coy.
hmmm...
... unless my math is wrong (and that's happened more than once!).   :/
But the Tau are not using our technology, and the subject at hand are the Tau.
In the 40K 'verse, the Tau were stone age and primitive roughly 6K years ago.  Flight, as a technology, had not yet been invented yet, so the need to shoot down an aircraft did not exist for them either.  As the Tau continue to not use our technology, whatever time humans have had, even 39 million years (lol), would not apply to them.
Humans and Tau have enough pertinant similarites (5 Senses [Sight, Sound, Smell, Taste, Touch], similar abilities [Unable to fly on own {Except for the Air Caste?}, cannot throw huge rocks or hurl plasma, IE lack of supernatural abilities] that when faced with the same challange they would probablly reach the same conclusion.
That means that both societies, independently of each other, would attempt the same techniques to achieve the same results.
So when the Tau encountered the need to shoot down an aircraft, they would attempt different methods, as we have, and discover what works better, as we have.  So the Tau would probablly discover that Optical/Laser tracking is inferior, as we have.
mil?len?ni?um
Pronunciation Key  (m-ln-m)
n. pl. mil?len?ni?a (-ln-) or mil?len?ni?ums
  1. A span of one thousand years.
  2. A thousand-year period of holiness mentioned in Revelation 20, during which Jesus and his faithful followers are to rule on earth.
  3. A hoped-for period of joy, serenity, prosperity, and justice.
  4. A thousandth anniversary.
Your math is way wrong.
40K = 40,000
40K- 2K = 38K
You are off by 39,958,000 years.  Give or take, er, 40K
With that post you are really trying to derail this thread, and by answering it I'm helping you.  So I'm gonna stop that.
The Skyray, as is (1x AA6+ @75cm) is really weak sauce.  The race with arguably the best missile technology has the worst missile AA.  Why?  the SMs have the best AA missile tech, probablly because they had 39 million years (lol) to develop it, but the Tau should have the best, or at least far better then what they already have, missile AA.
I'm sticking with:
2x Hunter Missiles AA5+ @75 CM
2x Seeker Missiles AT6+ @75 CM Guided Missiles
+ whatever
75 Points to start at.
This effectively means that you could paint entire areas of the sky with marker light beams (like a laser show) and as an aircraft flew through it would hit this light and be illuminated.....- but when the only thing surrounding the target is fresh air it doesn't matter.
Lasers are able to be diffused/refracted/reflected by water molecules, such as those in fog, clouds, rain, ect, and would more than likely cause the seeker head to confuse a cloud for a target.  We could only fight on clear, sunny days, I suppose, if we ask our opponents nicely.  :p
This is becoming draining.
PostPosted: Fri Dec 16, 2005 10:27 am
Incidentally I've always thought ECM is damn good in the 41st millenium - it makes a lot of stuff make sense (kinda like some of the get outs hammers slammers use against aircraft).
Missle tech wouldn't be that good at range on the battlefield with this level of ECM around making dumb fire the most sure method.
Whereas the average guard company might be aways from the nearest jammer planes would most certainly have them on board.
Without ECM the whole universe pretty much falls appart and armys would lose to any race that could churn out cruise missiles.
PostPosted: Fri Dec 16, 2005 12:32 pm
Responding to multiple threads...
Just out of curiosity, does anyone use the 'cuda for AA defense? ?Seams that this guys is pretty strong, and it would make sense that the Aircaste would be intercepting any incoming spaceships, bombers, and assaults more than ground units would be. ?Not that ground units wouldn't be, but I would personally like the 'cuda to always be better point-for-point at AA than the Skyray.
I am a big fan of the barracuda and prefer to rely on air superiority for my AA vs. ground units. After all, it's the American way.
Very interesting comment, however, I think the opposite conclusion is equally valid, i.e. that the diversity inherent in the races (e.g. how they think) would automatically introduce new and different solutions.
After all, on this planet alone, how many different examples of government have been created? Just off the top of my head, Monarchy, Theocracy, Oligarchy, Communism, Socialism, Democracy, Cults of Personality (i.e. Dictatorships) and the blends that come from individuals who borrow ideas.
So, although your statement "can" be true, I also think the opposite "can" be true as well.
:8):
Honda
"Remember Taros? We do"
- 23rd Elysian Drop Regiment
PostPosted: Fri Dec 16, 2005 3:39 pm
Just because it might be important, I'm going to reiterate that the current Tau Air/AA ability seems equal to or just slightly below that of the Eldar.
If everyone is okay with that, then fine, but it seems a bit strong to me.
PostPosted: Fri Dec 16, 2005 4:23 pm
Is that including Eldar airpower, or just their all prevailent ground flak (is it really equal to that, I swear sometimes the shurikan catapults can fire AA).
If thats the case then maybe it should be going down a bit, Eldar flak just shuts down the sky making Thunderbolts and to a lesser extent FB's useless.
PostPosted: Fri Dec 16, 2005 4:58 pm
I was considering it as an overall air-domination ability that would include all aircraft and all flak ability.
PostPosted: Fri Dec 16, 2005 5:59 pm
Based on the fluff from IA3 (man, I'm getting sick of that line, but there's no other source right now :/ ), I'm OK with that level of Air Defense Environment.
PostPosted: Fri Dec 16, 2005 6:47 pm
So you would be in favor then of increasing Eldar air defence so it again was the best (stated in more sources than IA3 :) )?
PostPosted: Fri Dec 16, 2005 7:20 pm
Does the current Tau Air Defense Environment (ADE) really exceed the Eldar's?
Does 2x 75cm AT6+/AA5+ Guided Missile on each Skyray (my preferred statline) exceed what the Eldar _can_ do, given the Skyray's cost and deployment limits?
How much AA does a 'typical' Eldar player bring (since there's no such thing as a 'typical Eldar')?
Without more information, I can't really make a good call.  The Tau should be better than the Imperium, and not quite as good as (but really close to) the Eldar, IMO.  They should be a threat to the Eldar's battlefield superiority, with their tech growing by leaps and bounds during every conflict.
(Yes, I'm very much a  Gue've'sa.  I really don't like the Imperium much anymore)
PostPosted: Fri Dec 16, 2005 10:31 pm
Well, Eldar AA seems to come in two forms:
1: 3x Fire Prisim Troupe for 250 pts, which gives 3x AA5+ with lance
2: Firestorm Grav Tank which can replace 1 or 2 Falcons in a Falcon Troupe, which gives 1~3 AA4+ Pulse shots.
There are also some Titan AA options in the Eldar list, I wont get into those.
Note:  Just adressing the AA aspects here. :;):
Eldar AA is good on paper, but form my never-played Eldar-viewpoint, the inability to attach AA to all but 2 formations would cause them to rely on interceptors.  I certinley would not want to fly near any AA they have, however.
The Pulse and Lance abilities are not to be sneezed at.
Users browsing this forum: No registered users and 71 guests
