Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 67 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
E&C's Tau Proposal
 Post subject: E&C's Tau Proposal
PostPosted: Fri Aug 21, 2009 2:00 pm
True, but with 4's available, I have a suspicion they'll become the most common type.
I wouldn't bet on that. I never field 4's... too brittle by a long shot and you can't rely on it to do a job when it's broken all the time.... plus it doesn't hit hard enough, especially with the new GM/ML rules. Hell, if you implement the node again they will need it for sure! Personally, I think you're actually a little mad to take 4. Even with a 'ray attached you'll be broken with two kills. Not my idea of a solid armour formation anyway...
I voted 4's because it makes sense for Manta deployment and they can still be 6's. 4's as a solo formation is just an add on in my view if I have points left over - yeah right!  :laugh:
We always found that the leader upgrade for Hammerheads was too good, or at least too cheap, as Hammerheads then never needed to Marshall at all.
I wonder if we play the same army then  :vD  even with a leader my HHs had issues getting back in the fight.
If pathfinders are to be allowed as an Upgrade, they will have to be really really expensive. The point of my proposal was to make formations have to rely on each other in a synergetic manner in order to win... if the Fire Warrior formations can be made self-sufficient in this manner (having both Coordinated Fire and Markerlights), that does somewhat break the synergetic style of the list.
How is it not synergy to have a PF unit attached? Just because it isn't a separate formation doesn't make it any less synergistic.... Having two units of PFs attached is a great synergy. It works nicely. Also remember I'm still paying points for that synergy.... Plus the list still has issues with ML costing so much that a 200 point PF formation means I lose a solid fighting formation from my army. In a list this fragile that's not great at the business end of a game (turn 3 or 4). Tau suffer towards the end of a game in trying to claim objectives (which they aren't really suppose to. lol) due to brittle formations being either broken or destroyed fairly easily once they contact the enemy.
You mean Skyray?
Sorry I read Pirahna and for some reason thought Tetra  :blush:  So that makes it even worse as there's actually no possibility of indigenous Co-ord for the FWs. It may be trying to force a synergy but that synergy actually hampers the list building IMO.
I really think a reconsider on the PF attachment is warranted here. As I said I see you want people to use fire warriors but then you go and hamstring them if anything they should have any and all assets available to them to make them more attractive.
Remember I'm not asking that PFs need to be an upgrade to every formation - just the PBI that you say should be the backbone of the list. In modern terms the PBI get almost any support it needs attached to it.
Anyway, just some food for thought. I can't convince you if you have your mind already set. It'll just be a pity is all to not help bolster the FW ethos for your list
PostPosted: Fri Aug 21, 2009 3:37 pm
I agree entirely with Dobbsy. I think that FW's should have lots of upgrades available to them so they can be tailored for any job. This would certainly make FW's the centerpiece of the army. Ideally I'd like to see Stealths, Broadsides and Pathfinders allowable as upgrades for FW's.
Although I would be hesitant to reintroduce the C&C node.
PostPosted: Fri Aug 21, 2009 3:58 pm
What it does is, just like my Markerlight Proposal, force formations to work together to achieve their goals.
It gives each formation type a niche, a role to play within the overall whole.
Allowing formations to become totally self-sufficent reduces that theme of synergy, and what you end up with is just 'better' individual formations, rather than formations that must work together to function most effectively.
Fire Warriors should be desirable because they're awesome at killing enemy Infantry, not because of the Upgrade types available to them.
PostPosted: Fri Aug 21, 2009 7:03 pm
Question..
What do you envision the role of those Fire Warriors to be when playing against an all (or mostly) AV/WE army?
PostPosted: Fri Aug 21, 2009 7:22 pm
Question..
Pretty much the same as all the other dedicated AP units out there. They'll struggle.
PostPosted: Fri Aug 21, 2009 8:13 pm
Most of those "dedicated AP units" would have the option of an assault as they often come with decent FF values.
The Tau are different in that they rely on their shooting, you can't fall back on assault characteristics.
PostPosted: Fri Aug 21, 2009 8:21 pm
Again it needs to be repeated that 5+ FF, 5+ armor and skimmers arrayed in front so you don't get countercharged into CC is hardly terrible in assault.
PostPosted: Fri Aug 21, 2009 8:23 pm
Agreed. Fire Warriors are not bad at assaults at all. Hardly specialised assault troops, but not terrible by any means.
PostPosted: Fri Aug 21, 2009 8:24 pm
Yup, FW are actually not awful in an assault.
PostPosted: Fri Aug 21, 2009 9:55 pm
Quote: (zombocom @ 21 Aug. 2009, 19:22 )
They'll struggle.
Which is it?  :vD
I'm a little surprised.  When asking the question how do FW deal with vehicles I didn't expect the answer to be "assault them".
PostPosted: Sat Aug 22, 2009 12:14 am
I think the question should be how to FWs deal with RA WE and vehicles. They can't exactly assault that sort of formation. Would be nice if someone would reinstate the MW FF for Crisis  :laugh: But that's a different argument.
I'm not doubting that it forces formations to work together. I'm doubting that it helps you avoid a weaker list. That niche could easily be filled by a PF upgrade as it is still synergy. They are working together in the same formation. It's not as if the PFs would be a free upgrade.
I think where we differ is that you see synergy as completely divided into separate fromations whereas I see it as single upgradable formations.
But as I said, you've got your mind set so I'll have to put up with it I guess :laugh:
PostPosted: Sat Aug 22, 2009 2:36 am
For the record, I'm with Dobbsy and clausewitz on this one.
FW's with limited upgrades are a one trick pony. If the enemy has few/no infantry formations and plenty of RA WE's, the centerpiece of the Tau army is a toothless tiger.
Just call me Steve.
NetEA Rules Chair
NetEA FAQ
Some of my Armies.
My Hobby site.
PostPosted: Sat Aug 22, 2009 2:37 am
how would PFs help deal w/ RA or WEs? you still have the skyray for a few GM shots.
than again, if PFs were in w/ the infantry formation it wouldn't have to rely on them being within 30 cms. which would do way w/ the dreaded gunline that this list is supposed to prevent.
PostPosted: Sat Aug 22, 2009 3:08 am
Who is asking for just PF's to be allowed?
I'd like to see Broadsides available and if there are many allowable upgrades then there would be other combos that could deal with WE etc.
Just call me Steve.
NetEA Rules Chair
NetEA FAQ
Some of my Armies.
My Hobby site.
PostPosted: Sat Aug 22, 2009 3:27 am
Let's be clear here. We aren't asking for multiple upgrades across the list here. We would just like to have a bit more utility for the FWs. We don't need every unit type available just some carefully picked ones to give the FWs a greater ability to deal with various types of situations. As Onyx mentions maybe a Broadside upgrade and as I mentioned a PF upgrade.
For example, FWs are infantry, so being able to add the other infantry/LV types would make sense from a support asset stand point. Only 3 types of upgrades can be taken. And you could stipulate that Fott FWs get only Broadsides and Mech FWs get Mech PFs/Tetras etc..
Just re-iterating. I don't want masses of upgrades - I like the mainly streamlined design, E&C - but FWs don't seem that great yet in terms of utility, the choice of upgrades available at present isn't the greatest diversity :agree:
