Post new topic Reply to topic  [ 307 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18, 19, 20, 21  Next
Some Tau Concerns at this point.
 Post subject: Re: Some Tau Concerns at this point.
PostPosted: Sat Aug 07, 2010 9:59 am
Onyx wrote:
Evil and Chaos wrote:
And the funny thing is that Fire Warriors are better than Guardsmen in CC because they have an armour save and the Guardsmen don't. So those FF3 people should be wanting CC7 too. :)
Has anyone called for FF3+?
No, but they should be, if what they want is Fire Warriors with 'true' FF ratings! :)
The range stretching isn't an anomaly of the rules, it's an intension.
Indeed.
I'm not buying that with regard to the Tau.
Anyone want to see Pulse Carbines shoot 4x their range and with no LOF?
It won't happen here in Perth and I'd be laughed at for even suggesting that it is possible... :D
Then you're not playing Epic.
You're playing something a bit like Epic, that makes ranged shooting worse.
PostPosted: Sat Aug 07, 2010 10:08 am
Sorry for thread crashing but....
Range Stretching??? I'm very lost on the subject. If its what I think then I would be laughed of the West Coast like Onxy would be down under??
Example: My Baneblade have range on the just the 2 lead Tactical marines in front on me. Now I shoot and cause more than 2 hits, are you saying I can kill more than 2 stands? Say if I hit 4, the 2 in range die and 2 more out of range die?
PostPosted: Sat Aug 07, 2010 10:17 am
More like, your Baneblade is 29cm away from one enemy unit, and 31cm away from a second enemy unit.
Baneblade fires all its guns, but only 2 Heavy Bolters hit.
Heavy Bolters have a shooting range of 30cm. However, because the Baneblade also has some other longer ranged weapons (Like the 75cm range battlecannon) the range at which your hits can apply are 'stretched', allowing your second Heavy Bolter hit to be applied to the second enemy unit 31cm away, instead of both hits going on the first unit.
This happens because your total number of hits are pooled before being applied as one allocation block, and it is an intentional part of the rules system.
So,
You roll to hit what's in range (Range of each weapon system is checked)
Then you apply hits to all potentially affected units in one allocation block (Range of longest-range weapon is used to detirmine what units can be allocated a hit)
If you're rolling each weapon system on each unit individually and then allocating on an individual basis too then that's not how the rules are intended to work and you'll be playing a version of Epic with quite 'nerfed' ranged shooting.
PostPosted: Sat Aug 07, 2010 11:18 am
Onyx wrote:
Jstr19 wrote:
Range stretching does not effect how far the units can shoot it affects where hits caused by those shots are attributed. If you have your formation within 15cm of only one base in an opposing formation range stretching with FW's means that hits caused by those shots can be applied on targets up to 90cm away. It does not mean pulse carbines can fire from 90cm away. In effect it allows you to minimize the comeuppance you receive in a following engagement.
Onyx wrote:
I understand that and there is no way that we play that way or that we will ever play that way.
We've always played that units outside a weapons range cannot be shot at by that weapon.
It may take a little longer to roll all the dice but at least we get a more realistic result to our combats.
It should probably be taken into account then with your complaints about how the Tau list functions that you in fact have been playing the shooting rules incorrectly.
PostPosted: Sat Aug 07, 2010 11:39 am
Ginger wrote:
Back on page 12, while keeping FF5+ I suggested improving the Tau close range firepower by giving the carbine disrupt and sniper at 15 cm range. The point behind this is to encourage the Tau FW to be used to shoot rather than engage. The stats are intended to represent both the power of the Tau weaponry and the fear they impose
They're better at shooting than they are at engaging right now.
Plus I don't think that Sniper fits well with the standard Tau weapons.
Disrupt fits better, and they already have that.
Onyx wrote:
Rather than quote me, maybe the answer could have been directed at the earlier posts that cause possible contradictions. Sounds like some of you are playing in different ways aswell...
Jstr19 wrote:
It does raise one question - GM's still don't need line of sight to fire right? If they are marked by another fomation so the devilfish can now hit them, can the FW shots also hit those units?
Technically yes, normal shots could be 'stretched' so as to hit units out of LOF by a non-LOF unit in a formation. Call it a quirk of the Tau's awesome Markerlight abilities I guess.
Nah I've worked through the theory on this again and have again settled on my first interpretation, that the range of the hits can be stretched as normal, but they must still be applied within LOF because the no-LOF special ability itself doesn't transfer to the normal hits.
QFT.
PostPosted: Sat Aug 07, 2010 12:16 pm
It must be stated that E&C and I have never allowed guided missiles to stretch LOF nor have we ever even considered using them to do so.
PostPosted: Sat Aug 07, 2010 12:21 pm
Indeed it was just a theoretical debate that came up. Which I then forgot about. :)
PostPosted: Sat Aug 07, 2010 2:46 pm
I thought the CC4+ of Tactical Marines in comparison to Devastators CC5+ comes from the les than 12" weapons (Flamer, Meltagun and Plasmagun) Tacticals may carry?
On Railguns: Actually the Railgun has is WORSE than a Demolisher in destroying tanks but both have the same Strength (10).
The Demolisher has the advantage that it is an Ordnance weapon ( = rolls 2D6 and chooses the higher result for armour penetration). And it uses a template which can scatter from the intended target but can still hit it ifit scatters less than 5" while if you miss with a Railgun the projectile misses completely.
And a Demolisher is only AP3+/AT4+ Ignore Cover in Epic.
PostPosted: Sat Aug 07, 2010 7:31 pm
For anything to fire it has to have LofS (or have indirect fire) and be in range of a target otherwise no attacks take place.
No weapon could ever fire at a target if it wasn't in range in the first place, guided missiles have the equivalent of indirect fire so can fire at marker lit targets that they cannot see, other weapons cannot.
The earlier post had already been replied to by Jstr19 and E&C had re-replied to that explaining his post so I felt no need to re-re-reply to that post, also when reading your post it appeared you had misunderstood what the term "range stretching" was as it appears no-one had fully explained it.
PostPosted: Sat Aug 07, 2010 7:36 pm
/Rant engaged/
The Demolisher Cannon is not a better tank hunter than the Railgun in 40k, even ignoring their range. Ordinance vs AP1 is night and day for a tank hunting unit in 40k. Even with Marine vindicators, the odds of 'hitting' /barely/ rise to 50%. Scattering off the target means you're probably not even going to damage it. You might get a glancing hit on a rhino (which has 0% chance of killing it). Staying on target doesn't even mean you're going to do anything worthwhile.
Railgun only has 1d6 to 'penetrate', but when it penetrates (the odds are in favor of the demolisher at this point) the odds of actually /destroying/ a tank jump tremendously. On a 2+ something critical to the tank is gone. Even a glancing hit from a railgun can be deadly (16% chance), which makes the effective +1 to armor penetration the Demolisher gets a moot point because glancing hits from it are most certainly /not/ deadly.
The Demolisher has a better chance of doing /something/ when it hits, but a significantly worse chance of actually making the damage worthwhile and a hit rate a solid 16% behind the Hammerhead railgun.
/Rant disengaged/
Ignoring 40k stats, the Broadsides 'light' railgun (well, a railgun mounted on a 'light' walker) is shown to be able to punch through one side of a leman russ and out the other in the fluff of the codex. Yes yes, 'all fluff is corrupt'.
The Hammerhead's gun is something like 3 times the size of a Broadside one. Lets ignore 40k stats, and think logically (the Tau are one of the few races we can do this with, after all). A railgun's power is affected by how strong the magnets are (how strong of a 'push'), and how long the rails are (how long the projectile is pushed).
The side rails are both longer and thicker on the Hammerhead, which implies to me that they are compensating for the heavier projectile of the submunition. But, when they fire the penetration round it should be absolutely devastating compared to the smaller Broadside guns.
So we have options.
Increase the AT rating. Simple enough, puts it on par with the Broadside railguns. Rate of fire vs Stronger shot. Then the balance comes down to what you want. Mobility vs Resilience. Skimmer vs Garrison. Offense vs Defense. That is a good thing, in my opinion. Make the railgun an upgrade and make their costs equal to Broadsides.
There is also the idea of adding Disrupt to the Hammerhead railgun. This is an intriguing idea, and it works in its own way. Don't send superheavies against a swarm of enemy tanks that are collectively less valuable and can destroy your superheavy with relative ease. Leman Russ crews knowing that even a 'bad' shot from a railgun could kill them all. And so on.
However, balancing that would be a nightmare. As it stands 600pts of Hammerheads w/ AT4+ Disrupt would break a Superheavy Company from the Imperial Guard, possibly in one activation (if they're shooting a marked target). It would break almost any formation I've seen really. While that amuses me, I can't speak for how to balance it. Either the AT would have to drop (making Hammerheads somehow scary, but actually pretty pants at killing things), or the price would go up. How much? It would almost require that the Railgun be an upgrade option. When would it simply be /worth it/, and could the rest of the army support this Terror Weapon formation activation wise.
I love the idea. Don't know how to work with it though. How much is saying "Yes, you, tank formation. You are now broken." worth?
I'm going to test 6 Railgun Hammerheads @ 350pts and see how they go (if they overshadow the Broadsides at that price, then we'll know we're doing something wrong.)
Any thoughts? I'm going to be on Vassal looking for games for the rest of the day.
PostPosted: Sat Aug 07, 2010 9:16 pm
Ouch... I think I've been playing them wrong, too... I really need to read the rulebook again before I play my next game of epic. That's at least twice that I've been using the Flames of War mechanics instead of the Epic ones.
PostPosted: Sun Aug 08, 2010 12:05 am
Dobbsy wrote:
So doubling on a shooting attack on infantry in cover (as you have to be picked up by transport first) gives the sum total of 4 and a bit hits? What's likely to die? That is definitely not my idea of a solid attack.
And 7 and a bit on a 30cm Advance? What about saves? What's likely to die?
In both cases it somewhat obviously depends on saves. Half the hits are kills are 4+, 2/3's are kills at 5+ save.
Its also very good. A reinforced infantry company doing the same manoeuvre would have 15 autocannons, which is 15 shots at AP7+, or 1 1/4 hits and they cost 25 points more.
A mechanised infantry company with Hydra has 22 Ap7+ and 2 AP6+, or 2 1/6 of a hit and they cost 125 points more.
How would an engagement be with FF4+ on a single 30cm move and de-bus from transport? Obviously there are no modifiers for engagement rolls
6x 4+ FF, 4x 6+ FF? What about hits for that?
Well that would be 3 2/3's. Less than the doubling and firing into cover. FF4+ has the biggest impact on defensive engagements with these weapon stats - unless of course the weapon abilities come down.
Actually all the vehicles have 6+ for FF TRC so wouldn't your example be
6x5+ and 4x 6+?
Ahh, I thought the Devilfish was 5+ :) Remove half a hit!
PostPosted: Sun Aug 08, 2010 12:15 am
Well, currently the regular tank gun fires a super dense armour penetrating dart. It goes through or your armour or explosive plates deal with it. Compare that to a battlecannon like weapon which was on the IS Russia heavy tanks. Middling armour penetration however more than 3 times the energy of comparable tank guns. Hits wouldn't penetrate however they would wreck targets (external fittings, internal stuff would rip lose etc etc) rendering them combat ineffective and crews thoroughly shaken. Not a kill per say, but no longer a fighting unit.
PostPosted: Sun Aug 08, 2010 12:52 am
While true, I'm going to assume there is a reason why the Russians were developing dedicated anti-tank rounds instead of just hurling more high explosive rounds. Of course, I'm not an engineer so I can't speak to the actual effectiveness of various anti-tank strategies. It just seems like if this was such a superior system, we would still be using it instead of, for example, HEAT rounds.
PostPosted: Sun Aug 08, 2010 1:28 am
That sounds an awful lot like Disrupt.
