Page 2 of 4 |
[ 48 posts ] | Go to page Previous 1, 2, 3, 4 Next |
Tau Air |
| Ginger |
Joined: Wed Nov 16, 2005 7:20 pm Posts: 5483 Location: London, UK |
| Top | |
| The_Real_Chris |
Joined: Mon Jul 04, 2005 4:45 pm Posts: 8139 Location: London |
| Top | |
| dptdexys |
Joined: Tue Jul 05, 2005 11:39 pm Posts: 1974 Location: South Yorkshire |
The pattern I see is that all the newer lists are creeping up in power slightly and that is why their is to be a rules review . if the Eldar were not a touch out of balance their would'nt need to be much of a rules review. I can see the same happening again in a couple of years after Tau /Necron /Tyranid and the other experimental lists come into play were their is going to be another situation of the older lists (IG/SM/Orks/Eldar/Ferals Siegemasters etc.) needing a bump up to match the newer lists so why not just keep things in check now (things like stopping ever increasing air power)and save another situation similar to the where Eldar one is at the moment. |
| The_Real_Chris |
| Top | |
| HecklerMD |
As Honda has shown, other armies can have loads of cheap air activations, even at 900 points, and are additionally not burdened with 9 Orcas just to do so. Moving on... THe problem with this approach comes in when we try and create new aircraft, without an idea of what is a reasonable level of down-statting to fit with those that came before, and it's something I think all the AC's (including myself) who are designing lists including new aircraft could use some guidance on. |
| dptdexys |
With the Kroot hopefully being able to use the orca and then maybe the inclusion of vespids in some form the problem of not having assault troops will be gone and maybe a drop in the overall firepower could happen. I know the Kroot and Vespids won't be great assault troops but it would give the option to engage especially in FF with decent support from Tau formations. To say that Tau have good aircraft or shooting is not to say that all other races need to be redesigned - and I think its a far stretch to even propose that. |
| dptdexys |
In the Tournaments ang games I've seen and played in ,when orks or Imperials max out on air formations they cannot win many games (around 1 in 10 in the games I've been involved in).In one tournament an ork player had 1000 points of F/Bombers but only won 1 out of 5 games but when Tau max out on Air assaets they are winning around 8 or 9 times out of 10 and this should not be possible if the stats are in line with others. I'm not saying the aircraft should be toned down but they should be point costed to what they can do or have a 1/4 limit on air assets similar to siegemasters to help reign in their abilities to win games . |
| dptdexys |
The fighters were not down graded to show the situation on Armageddon but to keep them from being too good for the game and keeping the emphasis as you stated on the ground game . The fighters were limited to 2 in a formation to show the situation on Armageddon were as the orks have access to bigger formations to show their command of the skies. As for the second part of your quote I think it answers most of the arguments about tau air assets, keep the emphasis on ground combat. The first applies in no way to the Tau list, different campaign. ?I feel for our Steel Legion friends operating in and around the vicinity of the 3rd Sphere Expansion Zone without adequate air cover, I really do, but... |
| dysartes |
Yup - Eldar starting the process of being toned down because they're too good currently and Chaos Space Marines beng a problem in general - but that's for another topic. Needless to say, I expect them to get toned down in the future, but that's still a problem now. I still say the AC's need some guidance on aircraft design, so as to stop this problem. Oh, and as faras I was aware, the lists you are meant to use as a benchmark when designing these lists are the ones in the core rulebook - no others. The two stated reasons for the air downgrade (Mostly IN, really) are: The air situation on Armageddon (Campaign Specific) and the emphasis on ground combat. |
| Honda |
Joined: Wed Aug 10, 2005 11:44 pm Posts: 1891 Location: Katy, Republic of Texas |
You are making an assumption that all the Tau players want to use these formations. That would not be correct. There are a large number of Tau players that don't take allies for various reasons. It just so happens that any HtH troops that are currently in the list aren't that good. Making them better won't change how I play or what I field, so downgrading aircraft is forcing a change in play style, which is not what I am personally looking for. In the Tournaments ang games I've seen and played in ,when orks or Imperials max out on air formations they cannot win many games (around 1 in 10 in the games I've been involved in).In one tournament an ork player had 1000 points of F/Bombers but only won 1 out of 5 games but when Tau max out on Air assaets they are winning around 8 or 9 times out of 10 and this should not be possible if the stats are in line with others. |
| Tactica |
| Top | |
| dptdexys |
There is no assumption at all I said it gave an OPTION for an assault to work in the tau list . |
| Tactica |
| Top | |
| dysartes |
So, out of interest, when we feel there is a problem, what sort of evidence do you accept? You've rejected statistical evidence/tournament experience as unreliable. When games are done with a specific, possibly "abusive" ist in play (take 5 Aces, for instance), we get players arguing there's an agenda at work to "neuter" their forces. It's frustrating that every time we try to discuss a potential problem, it gets rejected out of hand, especially with comparisons to SW lists as justification (where at least 2 out of 3 are being "adjusted" in the next Rules Review). Those of us pointing out potential problems are trying to help produce a balanced list, to try and minimise the amount of adjustments that will take place in the future. In fact, I'm getting a growing feeling that if you're aiming to play a list when it is completed, you should probably play *against* it when you're testing - it gives you a real grasp of the strengths & weaknesses from the opponents perspective, and helps to get the feel of a list right from an opponents eyes. IMO, this is the major problem that befell the Swordwind lists - too much tweaking was done on the basis of those playing the list felt was needed, and not enough attention was paid to those who were having to face the list. /rant over. _________________ The forgotten Champion - AMTL, baby! Dysartes.com - Resources for the Modern Wargamer - Last updated: December 2004 - Next Update: In Progress Sentinels are just young titans that haven't grown up yet! |
Page 2 of 4 |
Who is online |
Users browsing this forum: No registered users and 71 guests |
