Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 69 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Should Crisis suits be Infantry?
I play Tau. Yes 45%  45%  [ 14 ]
I play Tau. No 16%  16%  [ 5 ]
I do not play Tau. Yes 19%  19%  [ 6 ]
I do not play Tau. No 19%  19%  [ 6 ]
Total votes : 31
 Post subject: Should Crisis suits be Infantry?
PostPosted: Tue Nov 22, 2005 2:16 am
ROFLMAO
wait till somebody moves their models into tanks into the woods and forgets to roll for dangerous terrain in my next game... I'll look at them with a question...
"GoTJ ?"
OK ... going home now...
Rob
PostPosted: Tue Nov 22, 2005 8:41 pm
What else do you call it when you're rolling to see if your 250-pt uber-chaplain-o-doom™ smacks into a tree headfirst, removing himself from the rest of the battle?
I should admit, I've had a Shas'o jump into and out of terrain 12 times (over 6 turns) sniping tanks with a fusion blaster, and just laugh at the puny trees (made 12 tests).
PostPosted: Tue Nov 22, 2005 8:48 pm
Quote (Tactica @ 21 Nov. 2005 (22:29))
"george of the jungle test"
ROFLMAO - I found that flashback particularly hilarious.
Ah yes, that does bring back childhood memories!  :D
PostPosted: Wed Nov 23, 2005 11:57 am
Location: Leicester, UK (termtime). South Essex, UK (holidays).
...so...baaack to the topic then :p
I'm definately on the side of 'I play Tau - yes' here. Not particularly because I play Tau, but because having battlesuits as LV's really doesn't make sense. Obliterators (a unit with the same numbers per base and general purposes) are infantry. Termies are infantry. As far as terrain goes, both of those are *far* less manoeuverable (did I spell that right? :p) than crisis suits. Assault marines are infantry despite having jump packs so I don't see any reason why crisis suits should be altered by having them.
As far as damage is concerned, what you have to remember is that although crisis suits are often targeted by AT weapons in 40k, the chance of a single lascannon (for example) killing an entire squad (read: one stand) of crisis suits in one go is exactly 0%! Of course, a space marine missile launcher could theoretically kill a whole squad in one shot...but only using its frag missiles - equivalent to using its AI value in epic.
We have to remember that EA is a game based on whole armies and combat is viewed from the squad level. AT weapons just wouldn't have the rate of fire to be worth taking into account in an anti-battlesuit role.
I think most of this stuff has been mentioned before, but its worth bringing back up for this thread too. Another old (but valid) point is that if we made crisis and broadsides into infantry then we could also remove the rule about drones taking hits from AT weapons too, which means the strange situation of that a lascannon shooting at a devilfish and then killing 5 drones instead (the drones all dived in the way simultaneously apparently ???) would be eliminated as well.
'Of course you should fight fire with fire; you should fight everything with fire!'
'Those who live by the sword, die by the rifle'
PostPosted: Wed Nov 23, 2005 1:35 pm
Good point Soulless1 ... I voted yes too ... but I tend to think of them as Dreadnaughts ... ???  :/  :alien:
PostPosted: Wed Nov 23, 2005 3:48 pm
The basing can be changed if deemed necessary to fit the style of the unit.
PostPosted: Wed Nov 23, 2005 11:18 pm
Quote (Soulless1 @ 23 Nov. 2005 (10:57))
That's an excellent point Soulless! Thanks for posting it.
PostPosted: Thu Nov 24, 2005 2:07 am
hey dobbs,
I like that icon blown up better now  :;):
Rob
PostPosted: Thu Nov 24, 2005 5:38 am
I am really starting to not care.  I just want to make sure that it is known that if they are made LV, then they are a target for every single weapon in the enemy army, AV and AP.  If they start dropping like flys and people still refuse to make them Infantry, just increase their firepower, or reduce their points.
If they are made infantry, and they are more diffucult to remove than terminators, oblits, demons, etc... then you can do the opposite.  From those other examples it follows they should be infantry, but in the end I don't care as long as they are balanced appropiately.
PostPosted: Thu Nov 24, 2005 11:14 am
Nor can heavy bolter for that matter...But we are talking about period of multiple shots so it's not one go but sustained firing.
And single lascannon will take out 3 crisis + their drones heck of a lot faster than 1 HB will.
But anyway drones shouldn't be concidered for that unless you want to reduce their armour save. Drones are taken into concideration in the armour save already. Drones good but not THAT good that they should give double advantage. Especially as drones don't contribute to unit's firepower yet heavy bolter(or other AP weapons) will be killing crisis suits at so slow rate that...Well you can pretty much ignore them.
www.tneva.net
PostPosted: Thu Nov 24, 2005 7:27 pm
I am starting to get like Red Devil, I don't care.
The truth is there are valid arguments on both sides of the issue, and even some silly ones, and IMHO in the end it is a judgement call as to whether they should be Infantry, LV or even AV (as per Dreadnoughts).
I repeat this a hundred times, you cannot make direct correlations across from WH40k to Epic-A and then make valid absolute arguments based upon that correlation. JJ has said many times WH40k is a guidline not a hard fast line that must be followed. It makes sense as the scales are so different.
Jaldon :p
PostPosted: Fri Nov 25, 2005 12:48 am
Like I said, I see the C/suits = dreads ... maybe it's just me ! :;):
PostPosted: Fri Nov 25, 2005 2:21 am
Apologies in advance lads - rant incoming. My view has changed slightly recently and I need to express it. I'd like to state upfront that I'm not trying to take a shot at anyone here either, so please don't take it that way. I really don't rant very often and I'm a little embarrased to do this but...
I really can't understand why ppl are on the negative here. It's not like it's a big problem if they're classed as infantry - it only helps the Tau player get what every other player gets for his SC. Surely fairness should win out here? What's the big deal? Why do ppl want to poopoo the battlesuits? It doesn't make sense to me. ?
So you can't fire AT values at em - guess what? Neither can I shoot my AT at a SC in Termie armour and they have teleport! So they've(battlesuits) got a good shooter - whoopdie-do! They have a crap CC/FF so it balances out some - face it Termies have a half decent shooter themselves and they have 3+ CC/FF and a reinforced armour save!
If the issue is the battlesuit 3+ save - give em 4+ and let's stop arguing about this and make them what they are - infantry. For heaven's sake! It won't hurt you to have to fire only AP values at em - I get that vs termies and I get on with the job. Just because the list is open to debate, doesn't mean it should be bent to hurt the Tau player for the sake of a few "worries" in the general community. I mean why EXACTLY does it NEED to be LV?
Rant off.
My apologies again to you folks but I had to get that off my chest - it's been frustrating the be-geezus outta me and I'm quite passionate about this. :blush:
PostPosted: Fri Nov 25, 2005 2:45 am
Amen Brother D!
Honda
"Remember Taros? We do"
- 23rd Elysian Drop Regiment
PostPosted: Fri Nov 25, 2005 9:12 am
So do I Dobbsy!
Cheers!
Steele
P.S.: We should develop, not trample on a single spot.
Quid pro Quo
