Crisis Cadre
 Post subject: Crisis Cadre
PostPosted: Sat Nov 26, 2005 4:00 pm
I don't understand the logic of giving some bonus to Tau-only forces. If people don't like the auxilia, then just don't take them and use the points on Tau stuff.
PostPosted: Sat Nov 26, 2005 4:01 pm
Quote (Steele @ 26 Nov. 2005 (10:16))
Quote (asaura @ 26 Nov. 2005 (11:05))
Quote (HecklerMD @ 26 Nov. 2005 (07:34))
Its seems like bad mojo to have to burn up a contingent choice to take a supreme commander.
You can get a Crisis upgrade and put the SC on that. No need to use a contingent choice.
Why slow down a Formation ( Firewarriors w/ Devilfish) ? Narrowed use of Jetpacks aside.
Steele
Huh? I'm just saying that there is a way to get the SC without burning a contingent slot even if Crisis was not a cadre.
PostPosted: Sat Nov 26, 2005 7:32 pm
Quote (CyberShadow @ 26 Nov. 2005 (13:50))
- Crisis Cadre: It seems that the general feel is that this Cadre works OK and that people like it. It doesnt sit 100 percent with me concerning the background, but I have no real reason to get rid of it... although uping it to 6 units is worth of consideration.
- Auxilia/Additional formation: I must admit that I would like to add a formation to Tau-only forces... My warped brain has been thinking of this recently and I stumbled on the potential of a modified Tigershark formation (called a Whiteshark? ?:devil: ) with modified cargo of a second formation of Drones and Crisis suits which could be dropped as per the normal rules...?
Comments?
CS,
Regarding your two points:
I don't understand the reasoning behind considering forcing an upgrade to 6 in the cadre. The formation is working at 4 with an option to upgrade to 6. Does this formation need to be be bigger for some reason in your mind?
Regarding your second consideration, I'd recomend you start a new thread. It deserves a bit more clarification on what you are talking about doing. When the army champion says - I have an idea, if its not a clear idea, then minds start wandering. Also, it has nothing to do with the crisis comment this thread was positioned on - and people that don't care about crisis may never see the comments about the planes that you are kicking around.
Rob
PostPosted: Sat Nov 26, 2005 9:26 pm
I would say that the supposed 'rarity' of Crisis teams is far less of an issue on T'au that one may believe.
In terms of production capacity, there is no indication that the Empire is lacking in its ability to churn out sufficient XV8s for its armed forces. (Indeed, to the Fire Caste the XV8 would be seen in the manner that carapace armour on grenadier-doctrine IG worlds would be, not in the manner that those guard would see Marines!)
Each Battlesuit Cadre represents only twelve warriors, not a lot considering that for fifty points less one can see forty shas'la on the table. However, the place of those twelve XV8 pilots in the list is at the very core of the Hunter Cadre, the key to the uniqueness of the Tau armed forces in the battlefields of the Eastern Fringe, and should not lose its place as a core choice.
Perhaps the myriad variants seen in the Empire regarding the role of certain other core formations (More Crisis teams from Vior'la, core Stealth and Broadside Cadres from Sa'cea, core alien auxiliary formations from Dal'yth etc) can be explored once the T'au list is out of the way and we have time to expand on the empire's diversity, but the T'au list is more or less fine enough as it stands.
And as regards all-Tau armies, I am a firm believer in the notion that you should focus on the strengths of the force you choose while taking into account its weaknesses (if you forego that Kroot or Gue'vesa formation, those points go into arguably more useful formation choices anyway!) Besides, the alien contengent in the T'au list isn't that big of a deal in any event - which is the whole point, this list is primarily focussed on Hunter Cadres, exactly where it should be! Dal'yth will be where the presence of the rest of the Empire should really be felt...
So don't have a crisis over the XV8 Cadre - and please forget about this bonus-to-Tau-only-armies idea, they don't need it and should have to plan without it.
Gary
v7.3 pdf
PostPosted: Sat Nov 26, 2005 9:36 pm
...modified Tigershark formation (called a Whiteshark?  :devil: ) with modified cargo of a second formation of Drones and Crisis suits which could be dropped as per the normal rules...?
Comments?
I like the concept but I really don't think you could fit crisis suits in a Tigershark fuselage (or even a Whiteshark for that matter :/)
These are taken from Forgeworld's 40k Tigershark page:
Orde
"I'm smelling a whole lot of 'if' coming off this plan."
Tau Army List Archive
PostPosted: Sun Nov 27, 2005 4:05 am
If they were laying prone in the launchbay, you might get 1 or 2 stands, but you would probably still need two whiteshark mods to get 4 stands on the board.
It 'could' be done though.....
PostPosted: Sun Nov 27, 2005 9:08 am
Quote (Honda @ 25 Nov. 2005 (15:15))
I tend to agree with HecklerMD here. Keep the 4x unit formation with upgrades.
The crisis after all are the cream of the crop and listed as "Elites" in the 40K Force Organization Chart.
My thoughts are that they are a formation of 4 units(8-12 suits per formation) and they can spread out 5cm apart which means that in-game they would be working quite a distance apart from each other in scale. I see an E:A formation to be more than a formation in its own right. I see it as an operational force under a single command element which happens to be made up of several squads/troops etc. working in concert on the battlefield.
It's like putting squads of elite SeALs or sections of SAS under a single command element in battle. They are part of a bigger group but still elite. Also, remember the scale of E:A - it generalises in this aspect. You have to bunch things together to form E:A formations.
Sorry for the ramble guys :blush: I guess I'm trying to express my view for keeping them as a formation of their own.
PostPosted: Mon Nov 28, 2005 4:48 pm
Auxiliary/Tau-only:  The reason the bonus contingent for all-Tau was added was because there was no armor cadre and nearly everyone felt that armor was essential.  This basically auto-burned contingent slots and made the auxiliary nearly a required part of the army.  Personally, I think that with the addition of an armor cadre that the all-Tau bonus contingent could simply be eliminated.
I'd like to hear if people are having trouble with lack of slots.  So far, no army list I've drafted has had anything beyond modest problems with availability.
Specialty formations:  I'm not sold on the idea that they are needed.  Kinda neat, but I think they can be heavily customized as it is.  However, if you want to add focuesd formations, I suggest you add them into the Auxiliary formations' slots in the list.  In other words, each Cadre would allow 1 alien auxiliary or 1 specialty formation.
Crisis:  I don't have a problem with the current formation.
PostPosted: Tue Nov 29, 2005 5:36 am
Agreed, with the advent of recent changes. from v4.1, i think we've remedied the old problem that used to linger in the list and required the 'bonus' contingent. I'm with NH. Now with the armored cadre and upgrades avail, the 'bonus contingent' clause can easily be removed.
Not anything significant in Tau WIP v4.2.x.
Agreed.
Agreed with this statement in regards to the CS proposed formations in discussion.
My vote is not to limit alien aux, and leave out the specialty formations CS.
Rob
PostPosted: Tue Nov 29, 2005 5:58 am
I have no problem with the basic Tau TO&E of one Cadre of F/W or Crisis Suits with attached support elements (contingents and/or upgrades)  It appears to me that a Cadre with attached units (Tau, Kroot, Gue', Air Caste, etc.) should be a pretty potent force properly employed ...   :;):
