Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3  Next
Tau Infantry Discussion, part two
 Post subject: Tau Infantry Discussion, part two
PostPosted: Sun Mar 08, 2009 7:46 pm
OK, now that the first comment is up, I did notice something about the proposed FW stats (with the 15cm Disrupt shot):  They're almost identical to the Pathfinders.  Only difference is that PFs have Disrupt on both shots and a Markerlight.
This seems to be a little counter to giving the FW their own niche to fill, but based on the examples I posted earlier, it seems to be working properly in those limited examples.  Has anyone tried the 1x 30cm AP5+, 1x 15cm AP5+ Disrupt FW yet, or are we still playing with the un-modified v5 list?
PostPosted: Sun Mar 08, 2009 7:55 pm
The key difference that's been floating around is lowering the to-hit number. Instead of
30 cm AP5+
15 cm AP5+ Disrupt
Hena said
30 cm AP5+
15 cm AP4+ Disrupt.
My proposition was more radical:
30 cm AP3+
PostPosted: Sun Mar 08, 2009 10:40 pm
That's not what I meant (and I'd thought the idea was still 1x30cm AP5+ and 1x15cm AP5+ Disrupt).
I'm OK with consolidated/improved to-hit numbers, whether it's 30cm AP4+ or 30cm AP3+.  Adding a 15cm AP5+ shot from the Pulse Carbines (can't be better than that without a different name, Pathfinders have the same weapon) makes the Fire Warriors better, but still leaves them very vulnerable to a counter-attack if you have some bad dice-luck.  It also has the side effect of making the FW look just like the Pathfinders.  Both have a 30cm AP attack (whether that's AP3+, 4+, or 5+ doesn't really matter) and a 15cm AP5+ Disrupt attack.  Not sure if that's a bad thing or not, but it is a thought.
From running the numbers, adding that 15cm AP5+ Disrupt shot adds enough blast markers to break targets through shooting *IF* we try to avoid Engage actions.  AP4+ isn't any different than 2x AP5+ against targets in cover, and AP3+ by itself doesn't add enough extra kills, even with 2 FW formations going in.
Actually, disregard.  What makes Pathfinders unique and valuable is their Co-fire ability.  Adding 2 stands of PF to a FW formation adds more than just the Co-fire, although it's the primary reason to add PFs.  You use the PFs to call a co-fire and then the entire formation advances and shoots up a target (laying some extra BMs with the Disrupt from the PFs), your Stingrays drop a load of Gm-love on the same target, and then the other FW formation finishes them off.
PostPosted: Mon Mar 09, 2009 3:00 pm
Played over the weekend - Tau (FW heavy) versus Minervans (SHT heavy).  I'll have the batrep up later today.
FW = No test for their AP as there were literally no Infantry or LV units in the Minervans.  5+FF did fine.  Even against the 4+RA SHTs they were a credible threat.
Between FW and Kroot they beat a Stormhammer company in assault and lost narrowly to another at about the right attacker-to-defender point ratios.
FW soaked up a lot of fire from the SHTs by a combination of good cover use and sheer numbers.  They were not easy to shift, even with lots of Stormhammers around.  Had I played them better, they would have lasted longer than they did.
PostPosted: Mon Mar 09, 2009 10:51 pm
So, are you then thinking that FW may not need a change after all, Neal?
I've come to the conclusion that FW are barely acceptable in assaults as-is (with FF5+, would definitely be better with FF4+), but need a ranged firepower bump to allow them to have the same effectiveness in shooting as in Engaging.  My preferred bump is an AP5+ Disrupt at whatever distance (Pulse Carbines @ 15cm is fine), although changing the basic statline to 30cm AP4+ Disrupt may also work, I just haven't run the numbers yet to confirm.
Does anyone remember why Crisis suits lost their MW FF attack?
PostPosted: Mon Mar 09, 2009 11:10 pm
Well, not to their FF.  Clearly, with all AV/WE targets, that was not a game to evaluate their AP ability.
I'd say slightly less decisive than engaging as there is quite a bit less risk for the FW, but I agree with the general sentiment.
Not me.  I have to admit that in the game I was a bit underwhelmed by them, but the only chance I had to get them in assault was a disaster on armor saves, so not much of a test.
PostPosted: Tue Mar 10, 2009 3:37 am
Honda/CS,
My only recommendation is prior to posting the new list, you post a DRAFT version where you get feedback from everybody on editing mistakes only, then put up the final version.  It keeps you from having to put up version 5.2.1.1.1.7.theta and doesn't become and endless stream of "Okay, play THIS one.  No, play THIS one."
This forum is awesome for finding every little mistake which, in this case, would be to everyone's benefit.  Hena-Eagle-Eyes will no doubt find more than anyone, and English isn't even his mother tongue.  It's spooky impressive. :cool:
PostPosted: Wed Mar 11, 2009 6:47 pm
Copied from the Tau-Minervan batrep:
I think a major drawback to Fire Warriors is how difficult the army list makes it to add MLs to anything except a mech infantry formation.  You must pay for Devilfish if you take Pathfinders, so they're already mech and if you choose to deploy them without you're dropping paid-for models.  Adding Stealthsuits prevents the formation from garrisoning and makes the FW formation too large for an Orca unless you leave a unit behind.  Tetras add LV status and lose their speed and quite a bit of their Skimmer advantage.  The only option that seems feasible is to add a Skyray which, as long as it is the only unit over 15cm, will still allow the FW to garrison even though they obviously can't use air transport.
I'm probably missing a ML option, but you can surely see the point - if you want to add MLs to FW, you are extremely limited in your options for deploying the FW.
I think this is a big deal.  If FW cannot deploy effectively with ML units, that is a substantial liability.  The FW need viable ML options for every deployment scenario - garrison, mech, and air.  Without it, they will never be functional as line troops unless the Tau eschew almost all GM units.
I hope I'm not in the minority in thinking that forcing Tau to choose GMs OR FW is bad.
PostPosted: Wed Mar 11, 2009 7:08 pm
It seems like the easiest solution would be to alter the Pathfinder upgrade so that the Devilfish were not mandatory.
PostPosted: Wed Mar 11, 2009 7:09 pm
It's bad.
Very nicely written up, BTW.
PostPosted: Wed Mar 11, 2009 7:17 pm
Umm Neal, Orca can carry 12x infantry and the FW cadre is 8x units. Adding a Stealth upgrade is 3x stealth suits, so you should not need to leave anyone behind (as Stealths only count a single slot each).
I agree that with Pathfinders you end up with the same choice as Space Marines; when you put them in an Air Transport, you leave behind the paid-for ground vehicles. Is this such a big deal?
However I think you do make a valid point about ML in general. there are only a limited number of units with ML and adding them to a formation sometimes brings other disadvantages of the type you have identified. Personally, I would like the Gun Drones to have Markerlight as they now represent the various different types of Drone. Do other people have similar issues?
PostPosted: Wed Mar 11, 2009 8:16 pm
Ah.  I missed that.  I thought all the suits counted double.  Still, I think stealthsuits have a large force multiplier premium built into them because of how well their abilities work with Teleport.  On the ground or in an air assault they lose that and cost about twice as much as FW for very little increase in capability aside from the MLs.
The only SM garrison or air assault that regularly leaves Rhinos behind are Devastators.  Their value is under 10% of the formation's cost.  The Devilfish is at least 25% of the Pathfinder upgrade cost, assuming it's 25 of the 100 points, but since the entire upgrade has an inflated price, I'd say it's more like 30%.  In the grand picture of looking at the whole FW + Pathfinders formation it's 25 points out of 300.
So maybe that's not so bad, but it galls me nonetheless.  You have to admit that it feels different leaving behind a 25 point Devilfish with real firepower compared to leaving behind disposable Rhinos.
Basically, I find it hard to justify ~50 points per infantry model (for Stealth or Pathfinders sans Devilfish) just to get MLs in a FW formation.  It seems much more cost effective to field those separately and that certainly explains why people choose the other options.
PostPosted: Thu Mar 12, 2009 12:20 am
Markerlight drones as a character upgrade for FW?
PostPosted: Thu Mar 12, 2009 12:38 am
If there is to be a Leader upgrade to the FW, could that unit include a ML?
So an upgrade of a Shas'ui to the FW's would give them Leader and a ML on that stand only.
The Tau codex I have here says all this is feasible. Cost would the only issue.
Just call me Steve.
NetEA Rules Chair
NetEA FAQ
Some of my Armies.
My Hobby site.
Users browsing this forum: No registered users and 77 guests
