Post new topic Reply to topic  [ 185 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 13  Next
EA Tau - Rules Questions
 Post subject: EA Tau - Rules Questions
PostPosted: Fri Oct 10, 2008 1:03 am
As I suggested earlier, while it is the best way to treat Markerlight, following the same principles as for cover still gives issues. (The principle being that the entire formation declares whether it is shooting at Markerlit targets or not).
1) Where part of the target formation is in cover, you now have to decide whether to shoot at targets in-cover or out-of-cover, Markerlit or not-markerlit with the relevant bonuses and deductions etc.
2) Most Tau vehicles with GMs also have Railcannon or other weapons that do not benefit from Markerlight, so some dice get bonuses while others don't, and you have some weapons that do not require LoS while others do on top of the skimmer visibility rules.
All in all, this just makes these formations horribly complex to shoot with and thus likely to slow the game down quite apart from not necessarily being 'fun' to play against.
PostPosted: Fri Oct 10, 2008 1:09 am
So perhaps for simplicity's sake we should change the rule to make the formation markerlit rather than individual units?
PostPosted: Fri Oct 10, 2008 9:09 am
Quote: (blackhorizon @ 09 Oct. 2008, 04:57 )
Wouldn't it be better for this thread if people asked questions and Cybershadow answered? Or did I misunderstand the creating of this thread?  :upside:
Actually, I like to see what other peoples opinions and interpretations of the rules are, and I dont always have the absolute answer either.  :sulk:
PostPosted: Fri Oct 10, 2008 8:42 pm
What save does a deflector shield provide against lance weaponry?
PostPosted: Sat Oct 11, 2008 5:15 pm
Quote: (Hena @ 11 Oct. 2008, 11:58 )
I feel that considering the entire formation to be marked would be quite a boost for Tau.
Not when combined with losing the turrets and GMs losing the unguided firing mode.
PostPosted: Sat Oct 11, 2008 5:27 pm
Losing Turret is a balancing move and why would GM not be fired unguided?
Because that is the case in the background, in both versions of the 40k list and the FW epic list.
It's also a neat ballancing move making ML more important, thus making the Tau player have to move more. Combined with the ability to ML whole formations at a time, ML becomes key to the list.
PostPosted: Sat Oct 11, 2008 7:58 pm
In the background and all other rules versions for guided missiles they can only ever be fired when markerlit. Why is this list different?
+1 to hit is good, but currently not worth sacrificing units for. Make ML essential for GMs and the tau player won't be able to sit back in a bloody gunline anymore.
PostPosted: Sat Oct 11, 2008 8:33 pm
From what others have presented, the Tau should be 'best' at medium range shooting and FF style assaults, so I strongly believe this emphasis on the use of Markerlight to permit 'long-range' shooting is the way to go, requiring the use of LVs and forward positioned troops to set up the relevant Markerlight zones which can then be hit by the supporting vehicles.
Currently GMs can still be fired 'unguided' at 75cms range which seems wrong, so to add to Zombo's suggestion, we would need to prevent GMs from firing unless Markerlit (in practice this would mean that GMs could always be fired if within 30cms of the unit as they all carry markerlight). Further possible restrictions would be to require the Markerlight formation to be unbroken for Markerlight to work, and/or to remove Markerlight from most of the vehicles carrying the GMs.
Treating the entire formation as markerlit is then a reasonable compromise. Equally, if we require GMs to be 'Markerlit' to fire them, then the stats should have the Markerlight bonus built in.
PostPosted: Sat Oct 11, 2008 9:25 pm
Percisely my reasoning.
PostPosted: Sun Oct 12, 2008 1:15 am
Whilst I understand the reasoning behind your suggestion zombocom, it's not a very practical solution.
What would the Stingrays (yes I know they have their own Markerlight but at 30cm range they will not last long) and Scorpionfish do once all the Markerlight units are destroyed/broken (an obvious tactic...), use harsh language?
You cannot have hundreds of points worth of units that could be unusable with the removal of the spotter formations.
Is there a precident for that in any other list (genuine question)?
Keeping the present rules is much more prefferable/playable to this suggestion.
Just call me Steve.
NetEA Rules Chair
NetEA FAQ
Some of my Armies.
My Hobby site.
