Post new topic Reply to topic  [ 193 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13  Next
V4.4 - Scorpionfish and Dragonfish
 Post subject: V4.4 - Scorpionfish and Dragonfish
PostPosted: Tue Mar 21, 2006 12:01 am
I had a problem with the previous points as I could never fit them into my list. Too expensive for the yeild.
I reckon the yield is a lot more potent now.  Certainly the MW missiles should be useful against your IG opponent.  And with MLs should be able to engage the likes of the Shadowsword while keeping out of sight.
1 @ 225 (Contingent)
2 @ 400 (Cadre)
Hmm, I hadn't thought of making them a Cadre choice.  Had that been discussed before?  Certainly makes that choice a lot more flexible.  But it doesn't seem to fit in with my mental concept of what the Tau consider a cadre.  I will be interested to read what everyone thinks about this.
Hopefully sooner rather than later.
Patience is a virtue. :)
PostPosted: Tue Mar 21, 2006 3:25 am
2 @ 400 (Cadre)
Then you could also limit the +100 points for SC Dragonfish mod on the Cadre version only.
I think we could start at 400 for a pair, though it may creep up to 425. Not so sure about the Cadre choice though. As much as I'd like to see that, I'd be really concerned that someone goes all WE on the list and gets 6 x pairs, then one more that they upgrade to the SC. That just doesn't "feel" right.
Also, I'd really rather not see the SC limited to the Cadre/pair. I'd rather not have to spend 500 pts just to get a SC if that is how I field my Supreme Commander. I was pretty big on using these guys and I will again, but some of the early versions were fairly painful from a C&C perspective.
Honda
"Remember Taros? We do"
- 23rd Elysian Drop Regiment
PostPosted: Tue Mar 21, 2006 4:00 am
Ok this is a terribly long thread (apologies if I've missed things and am repeating them) so I've got the gist and here's my thoughts...
Scorpionfish (I like Marlin personally :;): )
Speed ? ? ? Armor ? ? CC ? ? FF
20cm ? ? ? ? ?4+ ? ? ? ?6+ ? ? 5+
2x SMS ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ?75cm ? ? ? ? 2x AP5+ Guided missile Ignore Cover
2(3 maybe?)x Tracer Missile System ? ?90cm ? ? ? ? MW5+ Guided Missile
2x Twin Linked Missile Pod ? ? ? ? ? ? ? ? 45cm ? ? ? ? AT4+/AP4+
Damage Capacity 3. ?Critical Hit Effect: ?Munitions Store is hit, vehicle explodes. ?All Units within 5CM suffer 1 hit on a D6 roll of 6.
Notes: ?Skimmer
Ok, my reasoning is:
1/if it "anchors the base line" IMO it shouldn't be moving too much or too fast -hence the slower move in conjunction with it's up armouring from an orca
2/should be able to deliver it's "artillery" over an extended range (90cm Tracer) - I don't see the point in giving it a 75cm Tracer when these things can rain down from orbit i.e it doesn't really mean much to me in terms of "support" when you compare it to Hammerhead formations etc. Long range Support should be exactly that IMO not just the same ranged weaponry. It should stand out and have a reason for me to take it.
3/Giving it the SMS in addition to the T-L Missile pods gives it the necessary AP (and AT)values it requires to be an "all-round" type of support vehicle it's touted as being.
4/upping the FF to 5+ due to it's payload of SMS
5/giving it 3 DC 4+ armour would sound to me more like reinforcing the armour of an Orca. Just because it's "reinforced" doesn't literally mean it needs to be "RA" - it seems silly to me to have its save reduced but more resilient due to actual RA. In conjuction with a SC, it would still get its invulnerable save and without one it wouldn't be impenetrable.
6/On a modelling note... having 3 weapon systems you only need to model it with 3 launcher-type boxes - which (in my mind at least) makes it more simple to convert.
PostPosted: Tue Mar 21, 2006 4:08 am
I wouldn't want to see them as a Cadre choice.
I do favour seeing them as a pair with a slight (say 25 point) discount, having them around like that ensures they put out a lot of firepower and I see a supporting formation like this as all about the number of dice :)
I don't think they should be availible seperately in order to get a reduced cost SC.
Reason being I like the imagry of him being in a crisis suit in small battles and larger battles getting into one of these things - but due to the increased
danger of said battle having a mate around to soak bullets makes sense!
Upgrade wise Skyrays, Networked Drones or Dragonfish (a triscropitooth with a shield and a SC), drones.
PostPosted: Tue Mar 21, 2006 4:28 am
yep - I agree guys - no cadre.
225 each, and then 425 for the pair (25 point discount for the bulk purchase)
Works for me.
Rob
PostPosted: Tue Mar 21, 2006 4:30 am
Quote (Dobbsy @ 20 Mar. 2006 (21:00))
Page 10 has the most recent version that CS liked...
Scorpionfish
A formation consists of one or two Scorpionfish, at 225 points each.
Stats
Type: War Engine
Speed: 25cm
Armour: 5+
CC: 6+
FF: 6+
Variable Munitions Launcher
Either: 4x Tracer Missiles : 75cm : MW6+ : Guided
Or: 6x Seeker Missiles : 75cm : AT6+ : Guided
Or: 6x Submunitions Missiles : 75cm : AP5+ : Guided, Ignore Cover
And: 2x Twin Linked Missile Pod : 45cm : AT4+/AT4+
Notes: Damage Capacity: 3. Critical Hit Effect: The primary munitions store is hit, igniting the payload internally and ripping the vehicle apart from the inside. All units within 5cm suffer a single AP6+/AT6+ hit.
Skimmer, Reinforced Armor.
BTW: regards to modeling - this is why I like the crisis 40K missile pods, they have three large barrels on each one when you spin them around backwards - so one tube in each 'box' for each missle variant type. ;)
OK, see you on page 20 :p
Rob
PostPosted: Tue Mar 21, 2006 5:36 am
Just a few notes on how things like the VML might work and look:
Vertical Launching Systems
And...
Ohio class SSBN and SSGN Subs
Please note the SSGN:  1 Submarine, 154 Tomahawk Missiles, each capable of carrying various warheads:  AP, AV, Anti-Ship, Bunker Buster, FAE (Nasty!), and, of course, Tac-Nuke.
Sorry, but that gets me hot.  :devil:
Edit:  Oh, and a Polar Bear trying to eat a Submarine:
Click
PostPosted: Tue Mar 21, 2006 5:53 am
So people are happy with the 75cm tracer? :( It just doesn't seem quite right to me - a bit flat and boring(no offense to whoever proposed it). I was thinking that if you pair 2 Scorp's up you get 4x MW tracers. It's not too OTT with just 2 per vehicle and the other systems fulfill their "fluff" design. I'd prefer longer range and less attacks to keep price balanced.
Having the armour go down when it's supposed to be "up-armoured" doesn't make sense to me either. Surely it should at least stay the same value and have a higher DC?? Okay I'll shut up now as I'm repeating what I stated in my post earlier :blush:
PostPosted: Tue Mar 21, 2006 5:54 am
Armour wise the triscorpitooth has far higher armour. I don't get your point. 4+ 2DC is lower than 5+ RA, 3DC.
The first requires 4 AT / 2 MW / 2 TK hits on average to kill (baring criticals).
The second 6 3/4 AT / 4 1/2 MW / 3 TK hits on average to kill (baring criticals
Even as a straight hit for hit comparison against AT fire 4+ armour saves 50% of the time and 5+RA 56% of the time
In case you are interested here is the guide on when to use the MW missiles
If you want to shoot both infantry and vehicles in a formation.
If you want to get less hits but with greater chance of killing what you hit (so say firing at a formation with Ogryn in front and guard behind, fire MW to limit hits to the Ogryn as opposed to AP to hit more people but less chance of Ogryn killing).
Shooting at 2+/3+/4+ AT, RA AT. Otherwise AT missiles all the way!
Shooting at 2+ AP, RA AP inor out of cover. Otherwise AP missiles all the way!
PostPosted: Tue Mar 21, 2006 6:04 am
Quote (HecklerMD @ 21 Mar. 2006 (04:36))
Sorry, but that gets me hot. ?:devil:
Me too. We are a sad bunch of gaming nerds aren't we? ?:laugh: ?:laugh:
ahh but my point was 4+ 3DC.
PostPosted: Tue Mar 21, 2006 6:31 am
4+ 3dc is lower than 5+RA 3dc
The first requires 6 AT hits, 3 MW hits and 3 TK hits on average to kill baring criticals.
The second 6 3/4 AT, 4 1/2 MW, 3 TK hits on average to kill baring criticals.
Add in a Tau shield and it changes to
The first requires 7 1/5 AT hits, 4 1/2 MW hits and 6 TK hits on average to kill baring criticals.
The second 6 3/4 AT, 4 1/2 MW, 6 TK hits on average to kill baring criticals.
PostPosted: Tue Mar 21, 2006 3:16 pm
Scorpionfish
Stats
Type: War Engine
Speed: 25cm
Armour: 5+
CC: 6+
FF: 6+
I thought the above version was what we were agreeing to.
I still believe that we should not force the SC to run with a pair of these. Reasons:
1. You're assuming that everyone shares the "crisis-thing" vision
2. A commander needs to be able to move to where ever the action is and not degrade a particular fire sector to do that, like he would if he had a tag along.
3. What is the logic of costing a SC at 500 pts?
In my earlier battles, I fielded three of these things (ScF), with one of them upgraded to the Dragonfish. The pair went where ever needed, the DrF floated back and forth, lending fire support and potentially calling CF as needed with the assets at hand. Would the extra Scorpionfish give that formation extra fire power. Obviously yes, but I don't want the extra fire power shackled to the Commander. Let it be my choice to do that.
Honda
PostPosted: Tue Mar 21, 2006 3:30 pm
Well yes, given the choice I would have all my activations cheap and tough :)
And 500 points for a supreme commander? Not exactly unheard of..... :)
Most lists have it pretty expensive, I think the cheapest is the Siegemasters at 150 points and the exception is the Orks were it can go anywhere.
Even marines have to pay a fair amount (typically 400+).
Not all armies have a flexible Supreme Commander choice.
IG has the 500 point Reg HQ.
Tyranids have the 500 point Dominatrix.
Even Eldar cant get a SC in a formation for less than 375 points.
The Tau have the choice of taking two different forms of SC.  In a Crisis suit and in the Dragonfish.  The crisis option starts at 350 points.  IMO, there should be a downside to taking the Dragonfish SC option (to balance its greater survivability) and forcing the Dargonfish to come as a formation of Dragonfish + Scorpionfish seems appropriate.
PostPosted: Tue Mar 21, 2006 4:33 pm
1)As we are to playtest this unit, I think we should first let it be taken in formation of 1, 2 (or even 3 ) to widen the range of the test. If it seems too flexible, let's restrain the size of the formation.
2) I'm not against the idea of a cost reduction if they are taken in pair (as it is for IG). But remember that in the Tau list, 1 cadre = 2 contingents, and personnaly, I often have troubles to take all the contingents I would like, so taking a formation of 1 SF is not a no-brainer for me.
Users browsing this forum: No registered users and 81 guests
