AMTL: pros and cons
 Post subject: AMTL: pros and cons
PostPosted: Fri Feb 24, 2006 3:20 am
I'm just wondering if everyone thinks the AMTL list has the same advantages and disadvantages.
Advantages:
Durability: many tought, unbreakable formations
Poten Firepower: long range, powerfull guns mounted on Titans, so thus they don't suffer from return fire, and have the advantage of hight.
Disadvantages:
Unwieldly: Most Titans are slow, and there are few of them. (the Warhound list circomvents this, as do many of the axillia units)
Low Activations: have to have 50% of the force being expensive Titans, and only 2 support formations per Core Titan.
Minimal Air support/defence: only 2 formations of aircraft can be chosen, and AA support can be a little scarce.  Each air choice is very durable though.
And as for as the GT Senario is concerned:
Very Durable BTS formation.
Several Formations powerfull enough to deal with opposing BTS formations.
Fearless formations that are good at holding Objectives, and preventing HTF and NSP goals.
Well, that's just a start, and is mostly just speculation.  What do y'all think?
P.S.:  I can see how the Warhound army would avoid many of the disadvantages
Note to self:  add clever signature
PostPosted: Fri Feb 24, 2006 6:17 am
I think an all Titan force is "dumb" ... for the reasons I mentioned on other posts.  Since I been playing Epic since '90, I've amassed a litte "knowz Watz" ! :;):  L4SoTR - If your opponent has a Titan in his force; you better also.  Only 50% of a TL can be used on Titans, CAS, Ortillery(off-board support).  A pure Titan Force is "power gaming" ... IMO :D  But as I always say, "Do what works for you !" :;):
