Post new topic Reply to topic  [ 71 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Skitarii 2.1 (Approved)
 Post subject: Re: Skitarii 2.1 (Approved)
PostPosted: Thu Apr 23, 2020 5:32 pm
Congratulations, Vaaish. It was a long travel but you arrived there.
Sculpting Orks thread
PostPosted: Sun Apr 26, 2020 10:11 am
Very nice!
Looking forward to play the list as soon as I can
PostPosted: Fri Jun 05, 2020 7:52 pm
When I buy Support Missile, 0–2... 75 pts
Is it 75 pts pr. Missile? Can I choose 2 differenct Missiles or do they have to be the same?
PostPosted: Fri Jun 05, 2020 8:02 pm
It's 75pts per missile. If they have to be the same it will be noted in the list entry for the unit. 0-2 means that you can only take two missiles total in your army, not that you get two missiles.
-Vaaish
PostPosted: Thu Jan 21, 2021 11:47 am
Hydra statline is missing from the document.
Loving this list, though.
PostPosted: Fri Jan 22, 2021 3:32 am
I raised this a couple of times during testing, there was something about not being able to fit it into the formatting.
Would like to see it there though, instead of needing to bring the IG list just for that.
Agree though, it is a great list to play with. Lots of scope for some very diverse builds.
I know how this one ends
So bite your tongue if you can't tame it
PostPosted: Wed Jan 27, 2021 6:17 am
Yeah, I couldn't fit the Hydra onto the page without shrinking the font at the time or pushing stuff off the page. I can take a look at it again.
Glad to hear you're enjoying the list, it was a long hard road to get here :)
-Vaaish
PostPosted: Wed Jan 27, 2021 9:06 am
Without it there, it's impossible to tell whether the fact it's missing is the problem, or if it shouldn't actually be an option to purchase at all. This is especially the case given that the changelog indicates it came and went quite a bit.
If the list was added to the Tournament Pack page, that would help resolve the issue.
PostPosted: Fri Jan 29, 2021 6:37 pm
Generally speaking, if it's in the list selection, it's supposed to be there regardless of whether a datasheet is available. I'd trust that to be accurate first and foremost in any list.
As for the TP page, I'm not certain why it's not up there yet. It's been months. I'll poke around and see what I can find out.
-Vaaish
PostPosted: Sat Jan 30, 2021 9:43 pm
I asked Dave and it looks like getting Skitarii up on the TP site is a victim of Covid. It'll be up when he can get to his work computer again. In the mean time I'll see about getting the hydra in.
-Vaaish
PostPosted: Sun Jan 31, 2021 6:27 pm
OK I think I got the Hydra in there without destroying anything. It all looked right to me, but let me know if something got screwed up. If this is good, I'll update the file at the top of the thread.
AdMech.94.pdf [624.62 KiB]
Downloaded 720 times
-Vaaish
PostPosted: Mon Feb 01, 2021 4:42 am
Looks good. I see you've aligned the unit summaries too, so you don't have to keep rotating the page or trying to read sideways as you scroll back and forth.
PostPosted: Mon Feb 01, 2021 4:50 am
Actually, another minor issue is the Minorus. It has a line for "With Corvus Assault Pod", that I believe is just meant to indicate the increased movement. However, the heavy bolters are found on the same line, implying they are also a feature of the assault pod.
Ideally, it would just say, "or 25cm" and have the explanation in the notes, which seems to be the standard way it's done on other lists for units with variable features. The improved CC for close combat weapons could be handled in the same way.
As long as this info gets transferred correctly once the main TP list is added, I wouldn't consider it a huge deal, though.
PostPosted: Mon Feb 01, 2021 6:38 pm
I'll see if I can fit it without pushing the notes. The ordinatus are weird since the corvus changes speed and CC weapons changes the CC value.
-Vaaish
PostPosted: Mon Feb 08, 2021 9:20 am
Hi Folks,
Quick question about the Titans weapons choices :
Does minoris have access to all the arsenal (especially the « carapace only » ones ?)
