What should happen with the Laser Burner?
Poll ended at Wed May 28, 2014 5:50 pm
No Change 50%  50%  [ 5 ]
Keep existing stats, cost to 25 points 20%  20%  [ 2 ]
(-1 attack) Laser Burner: (15cm) EA (+1), OR Base Contact EA (+3), free 10%  10%  [ 1 ]
(CC only) Laser Burner: Base Contact EA (+3), free 10%  10%  [ 1 ]
Other, please explain below 10%  10%  [ 1 ]
Total votes : 10
Laser Burner Poll
 Post subject: Laser Burner Poll
PostPosted: Wed May 21, 2014 5:50 pm
One final poll for the laser burner.
-Vaaish
 Post subject: Re: Laser Burner Poll
PostPosted: Thu May 22, 2014 8:45 am
I haven't voted on this yet as I see any change proposed above bringing the Laser Burner into conflict with the CCW which with the TK (D3) is a superior weapon.
The EUK list has made a change in the view of the weapon to Small Arms and no benefit to Close Combat, thus keeping a distinction. However I do understand the want to keep it closer to the original weapon style and would lean towards "no change" at the moment, even though it is a must add weapon to an advancing Reaver.
PostPosted: Thu May 22, 2014 9:00 am
Why the heck does the poll not include the Epic-UK version of the Laser Burner stats? (which it was proposed you changed to instead) I suggest deleting the current poll and running another with this as an allowed option - it's a viable, popular choice and what many would prefer.
Epic-UK have the Laser Burner being +3 FF MW attacks, zero CC for +25 points. That is very powerful, but limited to FF only, so more limited tactically and less defensive (no good against teleporting Terminators say).
The current Laser Burner is too good and annoying / lazy because it is good in both CC and FF. Against a titan legion with lots of Laser Burner an engagement based army is going to really struggle e.g. Tiny Tim's recent 4-0 win against Dark Eldar using 3 Laser Burners. I played a 3k list with several Laser Burners against Marconz and we were both of the opinion that they are too good as is at the moment. If they stay as is they should cost +25 but splitting them so the TL player has to choose between a good CC weapon or good FF, rather than getting one good at both, is my preference.
PostPosted: Thu May 22, 2014 9:34 am
One battle report does not necessarily cover all aspects needed to make an opinion.
I'm going to play EUK AMTL this weekend probably against the same army. I'll try and do a report again and it will hopefully show some of the differences/similarities between the two lists.
PostPosted: Thu May 22, 2014 3:48 pm
It's not there because further research showed that the lasburner was primarily a CC weapon not a FF weapon. I think we should try to keep weapons in their traditional roles so more emphasis on the CC side than FF. If the lasburner is too powerful, there are several other option there that reduce the power while keeping it in line with the fluff.
You can also propose your own ideas and if they get enough traction we'll do a run off. Hardly a reason to delete the poll though.
-Vaaish
PostPosted: Wed May 28, 2014 7:17 pm
The vote ends with no change to the Laser Burner. We'll keep an eye on it and bring it up for review again at some point.
-Vaaish
Users browsing this forum: No registered users and 83 guests
