Where do i go with all these SHT's?
 Post subject: Where do i go with all these SHT's?
PostPosted: Fri Nov 04, 2011 2:07 am
when i got into epic i painted up a bunch of the FW SHT's for the admech force when could run SHT's as core formations. through the variations to the list the SHT's have been taken out of the list. is there any other list that is current or is currently being worked on that is going to allow SHT's as core formations again? or should i just run the minervan list?
 Post subject: Re: Where do i go with all these SHT's?
PostPosted: Fri Nov 04, 2011 2:51 am
Minervans are the only one right now.
PostPosted: Fri Nov 04, 2011 5:32 am
Alternatively you could just play the old AMTL list that had them in it.
PostPosted: Fri Nov 04, 2011 6:14 am
Or you can field them as Ordinati Minoris - certain variants are just souped up SHTs anyway.
PostPosted: Fri Nov 04, 2011 11:14 am
I think the Krieg list allows you to field SHT companies as well, only as support formations. Not entirely sure whether it survived the last update, though.
/Fredmans
PostPosted: Fri Nov 04, 2011 11:23 am
Steel Legion can field SHT companies can't they? Would have to proxy as baneblades and shadowswords, of course, so the Minervans would be better.
PostPosted: Fri Nov 04, 2011 11:30 am
/Fredmans
Correct. You get access to all 4 main SHT flavours in the Krieg list.
I'd say the Minervan list is a good choice, or they could also work as proxies for Ordinatus Minorii in the Skitarii PDF list (Shadowsword = Ord Min. with Volcano Cannon, Stormblade = Ord Min. with Plasma Destructor, etc.)
