Page 2 of 3 |
[ 39 posts ] | Go to page Previous 1, 2, 3 Next |
| Ilushia |
| Top | |
| Evil and Chaos |
Joined: Fri May 05, 2006 2:57 am Posts: 20887 Location: Harrogate, Yorkshire |
| Top | |
| Ilushia |
| Top | |
| Evil and Chaos |
| Top | |
| Ilushia |
| Top | |
| Evil and Chaos |
| Top | |
| Evil and Chaos |
| Top | |
| baronpiero |
Your calculation for the reaver is based on the Mars pattern reaver, which I think does not cost the current 650 pts. So I would consider taking a warlord titan most of the time under your system. But should the reaver chassis cost 340 pts in your system, meaning a Mars pattern ?reaver would cost 600 pts, the difference between reaver and warlord would be: - 100 pts for the chassis - about 100 pts for the 4th weapon to pick up. A few examples: Average configuration: - Reaver with 3 turbolaser: 340 + 3 * 100 = 640 pts - Warlord with 4 turbolaser: 440 + 4 * 100 = 840 pts Cost ratio = 1,313 (4/3 being 1.3) Bargain configuration - Reaver with 3 Laser burner: 340 + 3 * 15 = 385 pts - Warlord with 4 Laser Burner: 440 + 4 * 15 = 500 pts Cost ratio = 1.298 Expensive configuration - Reaver with 3 vortex missile: 340 + 3 * 200 = 940 pts - Warlord with 4 vortex missile: 440 + 4 * 200 = 1240 pts Cost ratio = 1.319 As you see, the cost ratio doesn't vary much. In effect, ?everything got scaled up proportionally whatever the configuration.That's why I think such a system could work and be balanced. Maybe it lacks formalization as regards to your methods but I believe it could be done. - Would be simpler. - Could be a first step to more general titan/war engine design rules. Ilushia I'd consider Warlord melee-combat weapons to be worth more then Reaver, as it's got 2+ CC ability. As an example: Warlord with Devotional Bell, Chain Fist and Melta-Cannon. Moves as fast as a Reaver, fights in CC at 8 2+ normal and 6 2+ MW attacks, and gets 2 TK(D3) 3+ shots or 1 TK(1) 3+ fire-fight attack to boot. Plus all the other bonuses Devotional Bell gives! Surely people agree that 6 attacks at 2+ is preferable to 6 attacks at 3+, and should cost proportionally more. |
| Ilushia |
| Top | |
| Evil and Chaos |
| Top | |
| Evil and Chaos |
Noted. Also: Why do the Fire Control Head and CPL cost MORE on the Reaver then on the Warlord? Typically they'll be less powerful on the Reaver then on the Warlord, since the reaver only has 3 (or 2 with the CPL) mounts to put other weapons in. |
| Evil and Chaos |
| Top | |
| NOVAGUARD |
| Top | |
| Evil and Chaos |
| Top | |
Page 2 of 3 |
Who is online |
Users browsing this forum: No registered users and 75 guests |
