Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3  Next
Please select one of the following options.
Poll ended at Tue Jan 14, 2014 12:51 am
The CLP grants indirect fire to ONE BP weapon. This is the eUK style 53%  53%  [ 10 ]
The CLP grants Disrupt to one weapon and the AML stats change to 60cm 3bp, Indirect Fire. 5%  5%  [ 1 ]
The CLP allows BP weapons to fire using the LOF of a scout titan so long as the target is in range of the titan with the CLP. 42%  42%  [ 8 ]
Total votes : 19
Vote on the future of the CLP
 Post subject: Re: Vote on the future of the CLP
PostPosted: Mon Jan 13, 2014 1:09 pm
The issue with that is overwatch, surely?
PostPosted: Mon Jan 13, 2014 1:23 pm
Vote on the poll: none
Glyng alternative: You are still left with MW weapons being able to fire out of LOF. This is a big issue. Rule would be better with no +1 to hit and just doubling range.
I would still rather dump the CLP away altogether, and give indirect to the AML.
PostPosted: Mon Jan 13, 2014 4:00 pm
perhaps it could be tied to sustain in order to activate?
-Vaaish
PostPosted: Mon Jan 13, 2014 6:28 pm
I chose A). There's no clear mechanism for B), and C), while thematically nice, creates even more focus on Warhounds, which are already too common compared to Battle titans IMO.
PostPosted: Mon Jan 13, 2014 8:08 pm
GlynG wrote:
I've thought of another alternative suggestion that I prefer even more anyway - CML "allows the titan to fire any barrage weapons at any target within range, line of sight is not required." Range would NOT be doubled. would encourage more movement, leave normal benefits for sustaining and encourage me to use it a fair bit (particularly on a Reaver with twin Inferno Cannon or AML).
This is the best and simplest solution I have seen so far. Gets away from the 180cm range MW Quake Cannon which I have always hated. It still gives a benefit to twin Quake Cannon build, but not overwhelmingly so, and crucially does not invalidate anyone's existing models.
My Epic trades list
PostPosted: Mon Jan 13, 2014 8:27 pm
I'd planned for the poll to run for 10 days, but looking at the results right now it's pretty close and there seems to be a lot of support for Glyn's CLP idea.
Do you guys want to let this poll run the full 10 days or call it now and put up a second round with the top two options here (they are one vote apart right now, but we could just go with the top one) and glyns CLP idea?
-Vaaish
PostPosted: Mon Jan 13, 2014 9:15 pm
Personally I reckon the top 2 choices plus GlynG's second suggestion of no double range but no LoS.
Still gives 3 choices.
My Epic trades list
PostPosted: Mon Jan 13, 2014 9:55 pm
Good to see my idea is popular with others. I reckon a new poll with that and the other top two would be a good way to go.
PostPosted: Tue Jan 14, 2014 12:58 am
Do another poll with Glyns idea!
PostPosted: Tue Jan 14, 2014 4:14 pm
Ok, I'll leave the poll open until the end of today (12am EST) until then anyone can post ideas for the CLP and vote on these.
-Vaaish
PostPosted: Wed Jan 15, 2014 1:13 am
Just a reminder, the poll will be closing in 5 hours in case anyone wants to rally for option 2... or any of the others.
I'll be launching a second poll shortly after this which will run until Sunday or, if we have the same turnout as this poll, we can discuss closing the poll sooner.
-Vaaish
PostPosted: Wed Jan 15, 2014 1:23 am
Based on this, does the following sound reasonable:
CLP: BP weapons in the same formation as the CLP do not require LOF.
-Vaaish
PostPosted: Wed Jan 15, 2014 1:41 am
I vote, as expected, No.
the current CLP cost/benefit analysis may be off, it may be too good, and encourage a too static playstyle.
but it provides three effects
1, it doubles range
2, it provides +1 to hit via the need to sustain (a factor which is particularly important for barrage weapons, who without special rules cannot otherwise recieve to hit value tweaking to balance their effects like every other weapon type)
and 3, it provides freedom from Line Of Sight issues
In my experience, the first two points are incredibly valuable, easily more than the third, depending on how you play LOS and terrain in your area, maybe two or three times more valuable than the LOS restrictions.
so, if nothing, else, the proposal should reduce the effectiveness of all these areas, not reduce the effectiveness of one of these areas while completely eliminating another.
I believe that a responsible path to testing would be to perform an incremental reduction in all capabilities, and with testing, continue to adjust, upwards or downwards if needed, not this drastic butchering of capabilities
My proposal remains that we should reduce LOS capabilities (via the warhound LOS one, or something similar) and reduce the range benefit (my suggestion would be "increases range by 30cm" which impacts Quake Cannons, the apparent prime offender, much more than that of the generally considered underpowered AML and rarely taken Inferno Guns) while allowing for movement (thus decreasing the dependance on a static playstyle.)
Coupled with an outside rule to penalise any attempts to win via VP through static play, this would solve the problem, instead of overcompensating against a single symptom of that problem and not treating the main issue.
But since the AC is not willing to entertain any sort of range adjustment in pursuit of this vendetta, the vote goes to No
PostPosted: Wed Jan 15, 2014 5:54 am
Ok new poll will be up shortly.
-Vaaish
PostPosted: Wed Jan 15, 2014 7:11 am
Close this one then?
