7.1 WIP List
 Post subject: 7.1 WIP List
PostPosted: Thu Sep 07, 2006 3:24 am
NOTE: This List was Edited on 9/24/06. The only changes to the list were adding Walker to the Zoanthrope, Correcting the TL VC on the Venomspitter to AP 4+/AT 5+, and combining the Large Warp Blast and Smite on the Dominatrix into the Bio-Titan Warp Blast.
Hamman?s World Phase IV ?Subdual? Tyranid Infestation (7.1 WIP 9/24/06)
Subdual Tyranid Infestation armies have a Strategy Rating of 1. All Subdual Swarms have an initiative of 2+.
SYNAPSE CREATURE GROUPS
(up to 1/3 of the armies points may be spent on these groups)
Hive Group: 1 Dominatrix unit 400 points (Spawning rate, 2d3+2)
Strike Group: 1 Vituperator unit 325 points (Spawning rate, 1d3+1)
Harassment Group: 1 Harridan unit 225 points (Spawning rate, 1d3)
Nexus Group: 1 Hive Tyrant unit and 2 Tyranid Warrior units 200 points (Spawning rate, 1d3+2)
Attack Group: 1 Hive Tyrant unit 100 points (Spawning rate, 1d3+1)
Assault Group: 3 Tyranid Warrior units 150 points (Spawning rate, 1d3)
Support Group: 1 Greater Synapse Node unit 75 points ?(Spawning rate, 1d3+1)
Infiltration Group: 1 Lesser Synapse Node unit 50 points: (Spawning rate, 1d3)
(note: Only 1 Dominatrix per Army has the Supreme Commander ability)
COMMON BROOD CREATURES
(At least 1/4 of the armies points must be spent on the following Brood Creatures)
Termagant (1 unit) 15 points each
Hormagaunt (1 unit) 15 points each
Gargoyle (1 unit) 20 points each
Ravener (1 unit) 30 points each
UNCOMMON BROOD CREATURES
(up to 1/3 of the armies points may be spent on these units)
Biovore (1 unit) 25 points each
Carnifex /Venomspitter /Zoanthrope (1 unit) 35 points each
Haruspex /Malefactor (1 unit) 50 points each
Exocrine /Dactylis (1 unit) 75 points each
Barbed Hierodule /Scythed Hierodule /Trygon (1 unit) 125 points each
Mycetic Spores (special, see note) 15 points each
(note: Mycetic Spores are not allocated to a swarm. They are grouped into separate pool that may be tapped by any swarm during the rally phase as per T1.50. Each Mycetic Spore is a single use item similar to the One-Shot special ability.)
INDEPENDENT SWARMS
(up to 1/3 of the armies points may be spent on these swarms)
Genestealer Swarm (6 to 9 Genestealer units) 25 points each
0-2 Lictor Swarms (2 to 5 Lictor units) 50 points each
Hierophant Bio-Titan (1 unit) 250 points each
Hydraphant Bio-Titan (1 unit) 350 points each
Subdual Tyranid Bio-Construct Unit Descriptions
Dominatrix
Type /Speed /Armour /Close Combat /Firefight
WE /25cm /4+ /3+ /5+
Weapons /Range /Firepower /Notes
- Bio-Titan Warp Blast ?30cm ?MW 4+/AA 5+ and
? ? ? ? ? ? ? ? ? ? ? ? ? ? (15cm) ?(small arms) /Macro-Weapon, Extra Attack (+1)
- Bio-Cannon ?45cm ?2x AP 3+/AT 4+ /Ignore Cover
- 2x Bio-Titan Claws ?(base contact) ?(assault weapons) /Macro-Weapon, Titan Killer (d3), Extra Attack (+1)
Notes: DC-8, Supreme Commander (note: Only 1 Dominatrix per Army has the Supreme Commander ability), Fearless, Walker, Reinforced Armour, Synapse. This war engine may step over units and impassable or dangerous terrain that is lower than its knees and up to 2cm wide.
Critical Hit: Roll 1D6 and consult the chart below.
1-5: The Dominatrix loses one DC.
6: The Dominatrix hive node Symbiote is killed and it is no longer counts as a Supreme Commander (or it suffers one additional point of damage if this result is not applicable).
Vituperator
WE /30cm /4+ /4+ /4+
- 2x Bio-Cannon ?45cm ?2x AP 3+/AT 4+ /Ignore Cover
- Spore Cannon ?flame template ?AP 5+/AA 5+ /Ignore Cover
Notes: DC-4, Commander, Reinforced Armour, Skimmer, Synapse, Fearless, Transport (Eight Gargoyles, Termagants, Hormagaunts, Raveners, Hive Tyrant, Tyranid Warrior.
1-5: The Vituperator loses one DC.
6: The Vituperator is killed.
Harridan
WE /35cm /5+ /4+ /5+
- Twin-Linked Bio-Cannon ?45cm ?2x AP 2+/AT 3+ /Ignore Cover
- 2x Piercing Talons ?(base contact) ?(assault weapons) /Macro-Weapon, Extra Attack (+1)
Notes: DC-3, Reinforced Armour, Skimmer, Synapse , Fearless, Transport (Four Gargoyles)
1-5: The Harridan loses one DC.
6: The Harridan is killed
Hive Tyrant
AV /15cm /3+ /3+ /4+
- Venom Cannon ?30cm ?AP 5+/AT 6+
- Piercing Talons ?(base contact) ?(assault weapons) /Macro-Weapon, Extra Attack (+1)
Notes: Commander, Fearless, Invulnerable Save, Walker, Synapse
(Hive Tyrant may be given wings adding Jump Pack, Speed 25cm, but reducing it?s Armour save to 5+)
Tyranid Warrior
Inf /15cm /4+ /3+ /5+
- Deathspitters ?(15cm) ?(small arms)
- Paired Talons ?(base contact) ?(assault weapons) /Extra Attack (+1)
Notes: Fearless, Synapse
Type /Range /Armour /Close Combat /Firefight
WE /0cm /4+ /6+ /6+
Weapons /Speed /Firepower /Notes
- Ripper Swarm ?(15cm) ?(small arms)
Notes: DC-2, Reinforced Armour, Fearless, Synapse, Teleport (may only teleport into the Tyranid table half) May not garrison
Critical Hit: The Node is killed.
Lesser Synapse Node
AV /0cm /4+ /6+ /6+
Notes: Reinforced Armour, Synapse, Teleport, May not Garrison
Termagant
Inf /20cm /0+ /6+ /5+
- Fleshborers ?(15cm) ?(small arms)
Notes: Brood (1)
Hormagaunt
Inf /20cm /0+ /4+ /0+
- Scything Talons ?(base contact) ?(assault weapons)
Notes: Infiltrators, Brood (1)
Gargoyle
Inf /30cm /6+ /6+ /5+
- Bio-Plasma ?(base contact) ?(assault weapons)
Notes: Jump Pack, Brood (1)
Ravener
Inf /20cm /4+ /3+ /6+
Notes: Infiltrators, Brood (2)
Biovore
LV /15cm /5+ /6+ /5+
- Spore Mines ?45cm ?AP 5+/AT 6+ /Disrupt
Notes: Walker, Brood (3)
Zoanthrope
- Warp Blast ?30cm ?AP 4+/AT 4+/AA 5+
Carnifex: Screamer-Killer
AV /15cm /3+ /4+ /6+
- Spore Cysts ?(15cm) ?(small arms)
Notes: Fearless, Walker, Brood (3)
Carnifex: Venomspitter
AV /15cm /3+ /4+ /5+
- Twin-Linked Venom Cannon ?30cm ?AP 4+/AT 5+
Haruspex
AV /20cm /4+ /3+ /5+
- Molecular Acid ?15cm ?MW 5+ /Macro-Weapon, Ignore Cover
Notes: Walker, Reinforced Armour, Brood (4)
Malefactor
AV /20cm /5+ /4+ /4+
- Spine banks ?20cm ?2x AP 3+/AT 6+ and
? ? ? ? ? ? ? ? ? ? ? ? (15cm) ?(small arms) /Extra Attacks (+2)
Exocrine
AV /15cm /4+ /5+ /5+
Notes: Walker, Brood (5)
Dactylis
AV /15cm /5+ /6+ /5+
- Meiotic Spores ?45cm ?1 BP /Disrupt, Indirect Fire
Scythed Hierodule
WE /20cm /4+ /3+ /5+
- Acid Spray ?15cm ?AP 2+/AT 6+ / Ignore Cover
- 2x Bio-Titan Talons ?(base contact) ?(assault weapons) /Macro-Weapon, Titan Killer (1), Extra Attack (+1)
Notes: DC-3, Reinforced Armour, Walker, Brood (6)
1-5: The Hierodule loses one DC.
6: The Hierodule is killed.
Barbed Hierodule
WE /20cm /4+ /4+ /4+
Trygon
WE /15cm /3+ /3+ /5+
- Bio-Electric Field ?20cm ?d3x AP 3+/AT 6+ /Ignore Cover
Notes: DC-3, Invulnerable Save, Infiltrator, Walker, Brood (6)
1-5: The Trygon loses one DC.
6: The Trygon is killed
Genestealers
Inf /20cm /6+ /4+ /0+
Notes: First Strike, Infiltrators, Scout, Independent
Lictors
Inf /15cm /5+ /3+ /0+
Notes: First Strike, Infiltrator, Invulnerable Save, Scout, Teleport, Independent
Hierophant
- Bio-Plasmic Breath ?flame template ?MW 5+ /Macro-Weapon, Ignore Cover
- Bio-Weapon Slot (1) ? (select a weapon from the Titan bio-morph list, below)
- Bio-Weapon Slot (2) ? (select a weapon from the Titan bio-morph list, below)
Notes: DC-6, Reinforced Armour, Walker, Independent. This war engine may step over units and impassable or dangerous terrain that is lower than its knees and up to 2cm wide.
1-5: The Hierophant loses one DC.
6: The Hierophant is killed.
Hydraphant
Notes: DC-8, Fearless, Walker, Reinforced Armour, This war engine may step over units and impassable or dangerous terrain that is lower than its knees and up to 2cm wide.
1-5: The Hydraphant loses one DC.
6: The Hydraphant is killed.
Titan Bio-morph weapons:
- Pyro-Acidic Spray flame template ?AP 4+/AT 5+ /Ignore Cover
- Bio-Titan Claws ?(base contact) ?(assault weapons) /Macro-Weapon, Titan Killer (d3), Extra Attack (+1)
- Ripper Tentacles ?(base contact) ?(assault weapons) /Extra Attacks (+d3+2)
7.1 WIP Weapons Profiles, suggested corrections (with no stat changes)
Weapons ?Range ?Firepower ?/Notes
- Bio-Titan Talons ?(base contact) ?(assault weapons) /Macro-Weapon, Titan Killer (1), Extra Attack (+1)
Squat/Demiurg Army Co-Champion (in cahoots with Jaldon)
PostPosted: Thu Sep 07, 2006 1:20 pm
Great jorb, epilgrim!
Thanks a bunch!
PostPosted: Thu Sep 07, 2006 2:48 pm
(epilgrim @ Sep. 07 2006,03:24)
Zoanthrope
Notes: Brood (3)
Are Zoanthropes not walkers?
Hmmm... that's gonna hurt if they aren't.
PostPosted: Thu Sep 07, 2006 9:18 pm
Currently they are not.
I wouldn't be adverse to a change to that, or even giving them the Jump Pack ability.
PostPosted: Fri Sep 08, 2006 1:04 am
For all concerned,
At the end of the weapons summary, I have attached a download. I editied 7.1 WIP into a format similar to the rulesbooks. I hope it is of use. Enjoy.
Ep
PostPosted: Fri Sep 08, 2006 8:38 am
Great job epilgrim,
Juist noticed one thing -  the use of spores - I thought it had been decided that the spore would be committed AFTER rally (spawn) test not before. Your Word document states the following.....
"? add +1D3 spawning points by sacrificing ONE mycetic spore to the swarm during the Spawning Action, before the Rally test "
Lightbringer
:cool:
Overseer Lightbringer II
PostPosted: Fri Sep 08, 2006 10:07 am
7.1.a sounds kooky to me :D
Great job epilgrim.
PostPosted: Fri Sep 08, 2006 11:29 am
Lightbringer,
To the best of my ability the list rules are edited for spelling and grammar.
Where I made changes to enhance readability or clarify the intent of the rules as I understand them to be intended, they should appear as highlighteded in blue text. I did this to make any correction as easy as possible.
If any changes are needed, such as the Mcyetic Spore rule you pointed out, let it be discussed. As I remeber the thread discussion, the intent was to obligate the Tyranid player to commit the Mycetic Spore before the rally test. Seeing how this roll can never be worse than a 3+ (for enemy within 30cm) this seems to be a small element of risk.
The single largest change I made was to the flame template rule. the text is based on a lot of discussion and has been sent to the ERC.
All comment is welcome and all corrections will be updated as they are resolved. As for the name of the list, I am not responsible for the list  :)  I'm just trying to help!
PostPosted: Sun Sep 24, 2006 1:18 pm
Posted updated WIP, changed Zoey-Walker, Lg Warp Blast/Smite = Bio Titan Warp Blast and TW-Lk VC on Venomspitter to AP 4+/AT 5+.
PostPosted: Sun Sep 24, 2006 8:47 pm
(Hena @ Sep. 08 2006,11:33)
You aren't then it's based on E&C, and then kooky 7.1.a it is :D.
The list of modifications isn't just mine, it's had input from every active forum member here (Including yourself Hena).
It's more a consensus thing with my lose guiding hand than my personal vision for the Tyranid list (I'd remove the Vituraptor & Hydraphant for a start lol).
PostPosted: Mon Sep 25, 2006 12:50 am
Has anyone actually modeled a Vituperator?
PostPosted: Mon Sep 25, 2006 8:12 am
(epilgrim @ Sep. 25 2006,00:50)
Not as far as I know. I've never seen someone playtest one either. It's the bad idea noone talks about...
