Tyranid 7.1 WIP 8/18/06 Correct?
 Post subject: Tyranid 7.1 WIP 8/18/06 Correct?
PostPosted: Mon Sep 04, 2006 3:28 pm
this was edited on 9-5-06 19:35 EST as per Evil and Chaos
Hi,
Trying to get the list clear in my head. Can everyone please see if I did this right?
SYNAPSE CREATURE GROUPS
(up to 1/3 of the armies points may be spent on these groups)
Hive Group: 1 x Dominatrix unit: 400 points: 2D3+2
Harrassment Group: 1 x Harridan unit: 225 points: 1D3
Attack Group: 1 x Hive Tyrant unit: 100 points: 1D3+1
Assault Group: 3 x Tyranid Warrior units: 150 points: 1D3
Nexus Group: 1 x Hive Tyrant unit, 2 x Tyranid Warrior units: 200 points 1D3+2
SupportGroup: 1 x Greater Synapse Node unit: 75 points 1D3+1
Infiltration Group: 1 x Lesser Synapse Node unit: 50 points: 1D3
Strike Group: 1 x Vituperator unit: 325 points: 1D3+1
INDEPENDENT SWARMS
(up to 1/3 of the armies points may be spent on these swarms)
Genestealer Swarm: 6 to 9 Genestealer units: 25 points each
0-2 Lictor Swarms : 2 to 5 Lictor units: 50 points each
1 x Hierophant for 250 points
1 x Hydraphant for 350 points
UNCOMMON BROOD CREATURES
(up to 1/3 of the armies points may be spent on these units)
Biovore 25 points each
Carnifex 35 points each
Haruspex/Malefactor 50 points each
Hierodule/Trygon 125 points each
Zoanthrope 35 points each
Exocrine/Dactylis 75 points each
Mycetic Spores 15 points each
(At least 1/4 of the armies points must be spent on the following Brood Creatures)
Ravener 30 points each
Gargoyle 20 points each
Termagant 15 points each
Hormagaunt 15 points each
Dominatrix
Type /Speed /Armor /Close Combat /Firefight
WE /25cm /4+ /3+ /5+
Weapons /Range /Firepower /Notes
- Large Warp Blast / 30cm / MW 4+ / MWAA 4+
- Bio Cannon 2x / 45cm / AP3+/AT4+ / Ignore Cover
- 2x Monstrous Claws - +1EA TK (d3)
- Smite
Cluster Spines /(15cm) /small arms
notes: DC-8, Supreme Commander, Fearless, Walker, Reinforced Armor, Synapse. May step over units and impassable or dangerous terrain that is lower then the war engines knees and up to 2cm wide.
Critical Hit: Roll 1D6 and consult the chart below.
1-5: The Dominatrix loses one DC.
6: The Dominatrix?s Symbiote is killed and it is no longer treated as a Supreme Commander
Harridan
WE /35cm /5+ /4+ /5+
- Twin-Linked Bio Cannon 2x / 45cm / AP2+/AT3+ / Ignore Cover
- Large Scything Talons: +2 MW CC attacks.
Notes: DC-3, Reinforced Armor, Skimmer, Synapse , Fearless, Transport (Four Gargoyles)
1-5: The Harridan loses one DC.
6: The Harridan is killed
Vituperator
WE /30cm /4+ /4+ /4+
- 2x Bio Cannons 2x / 45cm / AP3+/AT4+ / Ignore Cover
- Spore Cannon /Template / AP5+/AA5+ /Ignore Cover
Notes: DC-4, Commander, Reinforced Armor, Skimmer, Synapse, Fearless, Transport (Eight Gargoyles, Termagaunts, Hormogaunts, Raveners, Hive Tyrant, Tyranid Warrior.
1-5: The Vituperator loses one DC.
6: The Vituperator is killed.
Type /Range /Armor /Close Combat /Firefight
WE /0cm /4+ /6+ /6+
Weapons /Speed /Firepower /Notes
Ripper Swarm /(15cm) /small arms
Notes: DC-2, Reinforced Armor, Fearless, Synapse, Teleport (may only teleport into the Tyranid table half) May not garrison
Critical Hit: The Node is killed.
Lesser Synapse Node
AV /0cm /4+ /6+ /6+
Notes: Reinforced Armor, Synapse, Teleport, May not Garrison
Hive Tyrant
AV 15cm /3+ /3+ /4+
Venom Cannon /30cm /AP5+ AT6+
Huge Claws /Base Contact /MW / CC weapon +1 attacks
Notes: Commander, Fearless, Invulnerable Save, Walker, Synapse
(Hive Tyrant may be given wings adding Jump Pack, Speed 25cm, but reducing it?s armor save to 5+)
Tyranid Warrior
Inf /15cm /4+ /3+ /5+
Death Spitters /(15cm) /small arms
Scything Talons /Base Contact /CC Weapon +1 attacks
Notes: Fearless, Synapse
Genestealers
Inf /20cm /6+ /4+ /0+
Notes: First Strike, Infiltrator, Scout, Independent
Lictors
Inf /15cm 5+ /3+ /0+
Huge Claws /Base Contact /MW /CC weapon +1 attacks
Notes:First Strike, Infiltrator, Invulnerable Save, Scout, Teleport, Independent
Hierophant
Bio-Plasmic Breath /Template /MW5+ /Ignore Cover
- Huge Scything Talons: +2 MW TK(1) CC attacks.
- Additionally, the Hierophant must select two weapons biomorphs from the Bio-Titans biomorphs list.
Notes: DC-6, Reinforced Armor, Walker, Independent. May step over units and impassable or dangerous terrain that is lower then the war engines knees and up to 2cm wide.
1-5: The Hierophant loses one DC.
6: The Hierophant is killed.
Hydraphant
- Warp Blast /30cm /AP4+ AT4+ AA5+
- Bio-Plasmic Breath /Template /MW 5+ /Ignore Cover
notes: DC-8, Fearless, Walker, Reinforced Armor, May step over units and impassable or dangerous terrain that is lower then the war engines knees and up to 2cm wide.
1-5: The Hydraphant loses one DC.
6: The Hydraphant is killed.
Bio-Titan weapons biomorphs:
- Ripper Tentacles - Extra Attacks (d3+2)
- Monstrous Claws - +1EA TK (d3)
- Pyro-Acidic Spray - Template, AP4+/AT5+ Ignores Cover
Haruspex
AV /20cm /4+ /3+ /5+
Acid Spray /15cm /MW 5+ /Ignore Cover
- Large Claws /Base Contact /CC weapon /+2 EA, MW
Notes: Walker, Reinforced Armor, Brood (4)
Malefactor
AV /20cm /5+ /4+ /4+
- Speed 20cm / 5+ RA / CC 4+ / FF 4+
- Spine banks / 20cm / 2x AP3+/AT6+ / -
------------------AND
-------------- / (15cm) / small arms / +2 EA
Carnifex: Screamer-Killer
AV /15cm /3+ /4+ /6+
Spore Cysts /(15cm) /small arms
- Big Claws /Base Contact /MW /CC weapon +1 attacks
Notes: Fearless, Walker, Brood (3)
Carnifex: Venomspitter
AV /15cm /3+ /4+ /5+
- Twin-Linked Venom Cannon /30cm /AP4+ AT6+
Biovore
LV /15cm /5+ /6+ /5+
Spore Mines /45cm /AP5+ AT6+/ Disrupt
Notes: Walker, Brood (3)
Zoanthrope
Notes: Brood (3)
Scythed Hierodule
WE /20cm /4+ /3+ /5+
- Acid Spray /15cm / AP2+/AT6+ / Ignore Cover
Notes: DC-3, Reinforced Armor, Walker, Brood (6)
1-5: The Hierodule loses one DC.
6: The Hierodule is killed.
Barbed Hierodule
WE /20cm /4+ /4+ /4+
Trygon
WE /15cm /3+ /3+ /5+
- Bio-Electric field / D3 shots /20cm / AP3+/AT6+ / Ignore Cover
Notes: DC-3, Invulnerable Save, Infiltrate, Walker, Brood (6)
1-5: The Trygon loses one DC.
6: The Trygon is killed
Dactylis
AV /15cm /5+ /6+ /5+
- Super Spore Mines /45cm /1BP /Disrupt, Indirect Fire
Notes: Walker, Brood (5)
Exocrine
AV /15cm /4+ /5+ /5+
Ravener
Inf /20cm /4+ /3+ /6+
Death Spitter /(15cm) /small arms
Notes: Infiltrator, Brood (2)
Gargoyle
Inf /30cm /6+ /6+ /5+
Flesh Borer /(15cm) /small arms
Bio-Plasmic Attack /Base Contact /CC Weapon
Notes: Jump Pack, Brood (1)
Termagant
Inf /20cm /0+ /6+ /5+
Notes: Brood (1)
Hormagaunt
Inf /20cm /0+ /4+ /0+
Notes: Infiltrator, Brood (1)
thanks in advance for your help
Ep
Squat/Demiurg Army Co-Champion (in cahoots with Jaldon)
PostPosted: Mon Sep 04, 2006 8:15 pm
While I don't have much of an opinion on the Haruspex change Hena proposes, I'm 100% against the breath weapon on the Harridan, and I do expect it to disapear in the next official version of the list.
This would leave the Vituraptor as the only flyer with a breath weapon, in line with the expected reduction.
Oh and there's no need for the 'A' and 'B' names anymore. If you're talking about a Trygon, call it a Trygon, not Heirodule 'B'... I had removed all of those oddities. :)
PostPosted: Tue Sep 05, 2006 2:37 pm
The list looks good, but very different to what I see on the web, which should I use.
Having just acquired 8000 points of tyranids
Robert
PostPosted: Tue Sep 05, 2006 4:30 pm
lilroblis : The list on the Specialist Games Website is the version 7.1 list.
This list above is what may become the 7.2 list.
So basically, use this list above and send back playtest reports to this forum!
PostPosted: Tue Sep 05, 2006 4:34 pm
A note: the Barbed Hierodule should only have a twin-linked bio-cannon, not a twin-linked bio cannon AND a normal bio cannon.
PostPosted: Tue Sep 05, 2006 6:12 pm
I think Exocrine having +1 MW attack on CC 5+ is fine. It has a rather big snippy beak about fifteen feet long after all!
PostPosted: Tue Sep 05, 2006 6:48 pm
The CC could be modified to 6+ to represent the rather unweildy nature of the Exocrine's attack?
PostPosted: Wed Sep 06, 2006 2:06 am
fixed as per E & C tonight. go up thread to see the fixes.
