purchasing Mycetic Spores?
 Post subject: purchasing Mycetic Spores?
PostPosted: Tue Aug 22, 2006 12:29 am
I am not sure how this works. Can I buy more than one Spore to add to a swarm but only use one every spawning? Otherwise how are they used?
PostPosted: Tue Aug 22, 2006 2:25 am
(Dobbsy @ Aug. 22 2006,00:29)
The Spores are kind of kept as a collective "pool" and expended (used up) to give an extra +d3 to a successful spawn.  You don't buy them per Synapse swarm, any can use them when they spawn, but a max of 1 per swarm per turn.
PostPosted: Tue Aug 22, 2006 2:30 am
So then,  I could buy 8 and use 1 per spawning formation a turn? e.g 1st turn I use one on a gaunt brood. 2nd turn I could use another one on the same brood. Is this right?
PostPosted: Fri Aug 25, 2006 9:11 am
Just a quick spore related query - do you allocate the spore before you roll to see if the spawn occurs or do you allocate it if you pass the test but before you roll to see how many spawn points you have?
Lightbringer
:cool:
Overseer Lightbringer II
PostPosted: Fri Aug 25, 2006 10:11 am
Where is Jaldon these days anyway?
Users browsing this forum: Google [Bot] and 56 guests
