7.0 Playtest Games
 Post subject: 7.0 Playtest Games
PostPosted: Sat Apr 29, 2006 3:45 pm
I finally got a playtest game in (woo hoo!! :laugh: ) and was also able to discuss the games the other guys had played in detail.  The breadth of experience is not great as the Nids were primarily gaunt-based armies and the opponents were all various flavors of Orks.  Nonetheless, there seems to be some common themes that should hold across other kinds of battles.
Spawning:  The feel of the end-of-turn spawning is VASTLY better.  It does, however, have a few side effects that might not be so great.
1)  It multiplies the value of synapse creature formations.  Not only is there the normal activation count issues, but now each synapse generates its own broods constantly.  Some of that is mitigated by more expensive SCs getting more spawning.  Overall, though, the bigger SCs seem to be somewhat frowned upon and I think this may aggravate that problem.
2)  It's a bit too fast.  In pretty much every turn of every game played, virtually the entire Nid army has regenerated every turn. Even without Mycetic Spores it happens.  In some of the games my friends played, the Nids had excess spawning capacity every turn and never used a spore.  It should be possible, barely, to wear down a swarm that comes charging willy-nilly across the battlefield at you.
Regeneration:  While I don't think that the average regeneration is too fast, it is highly randomized and can result in some amazing recoveries, especially for the 8DC beasties.
Firefight Tactics:  I didn't use this, but a tactic they reported from previous games was essentially a variant on a Tyranid token assault.  The Nid player moved some of the FF-strong units into range for support.  Then they did multiple assaults on the target formation with token troops.  The goals was NOT to win the assault.  In fact, that was almost a bad thing.  The goal was to inflict casualties via the supporting fire.  Even with the new assault rules, it won't stop that.  They can throw enough Hormagaunts into the mix that the enemy is highly unlikely to stall the assault by killing all of them.
This is obviously what prompted the "they are FF monsters" comment.  The "monsters" in question were either 250 point Heirophants or a formation of Haruspex (FF version) and Trygons.
To be fair, part of the problem was that they were allowing broods to move out of coherency and not killing them off at the end of the move so SCs were sending waves of troops to start the assaults.  Nonetheless, the tactic would work almost as well without that.
Units:  Some minor concern about the Trygons' price, but certainly not to the point anyone thinks it is broken.  And, obviously, you saw the previous comments about Raveners which are being adjusted.  Other than that, the broods, SCs and biotitans feel just about right.  No comment on Stealers and Lictors as they haven't been used.  Same for the arty units.
Garrison "tricks":  They haven't been using any of the 0cm garrison/handoff the broods tricks to "deep garrison" troops that would otherwise be unable to do so.  When I described them and we discussed it, they pretty much felt that such things were bordering on cheesy.  Starting so close would undoubtedly have aggravated the spawn speed issue.
==Suggestions==
Spawning:  Reduce the amount of spawning.  The ideas we kicked around were
1) reduce to d3 as the base - ~-1.5 per swarm, per turn and less randomness
2) reduce the "bonus" numbers by 2 - possible exceptions for Dom (leave at +6) and lesser nodes (leave at d6 or drop to d3)
3) modify the mycetic spores to 15 points, +d3
Regeneration:  We really don't know.  As noted, it's not the average that is a problem.  It's the potential mega-regen.  Also, it may look very different against forces with better TK options than the armies that have been played so far.
Firefight:  Tweak some of the FF values is justa bout the only thing we could think of.  The problem units are mostly the WEs because you can pack in a lot of FF firepower in a small area.  You could use a horde of Termagaunts to do the same thing, but it would be much more difficult due to space constraints.
Garrison Nodes:  Either revised garrison standards for Nids or disallowing it outright.
Hope some of that is helpful.
PostPosted: Sat Apr 29, 2006 6:30 pm
First Off Thanks Neal :)
Spawning: ?The feel of the end-of-turn spawning is VASTLY better. ?It does, however, have a few side effects that might not be so great.
The feel is about right, as the boom here is your new horde, IS now gone.
1) ?It multiplies the value of synapse creature formations. ?Not only is there the normal activation count issues, but now each synapse generates its own broods constantly. ?Some of that is mitigated by more expensive SCs getting more spawning. ?Overall, though, the bigger SCs seem to be somewhat frowned upon and I think this may aggravate that problem.
It does aggrevate the big-small problem to some degree, but it isn't all encompassing, thankfully.
It's a bit too fast. ?In pretty much every turn of every game played, virtually the entire Nid army has regenerated every turn. Even without Mycetic Spores it happens. ?In some of the games my friends played, the Nids had excess spawning capacity every turn and never used a spore. ?It should be possible, barely, to wear down a swarm that comes charging willy-nilly across the battlefield at you.
It is too fast and I have been messing around with ways to slow it down.
Regeneration: ?While I don't think that the average regeneration is too fast, it is highly randomized and can result in some amazing recoveries, especially for the 8DC beasties.
It is going to be reduced to 1/2 DC rounded up, while the randomness is nice, it has had some startling results even in some of our games that had titan killer weapons around. Combined with the lower cost WEs this should work it out fine.
This is obviously what prompted the "they are FF monsters" comment. ?The "monsters" in question were either 250 point Heirophants or a formation of Haruspex (FF version) and Trygons.
We have encountered essentially the same problem and for awhile I was really at a loss what to do about it. Your original post was too vague, for good reason, and it really was hard to know exactly what the issue was then. Hydraphants and Hierodules are pulling off the same things.
Spawning: ?Reduce the amount of spawning.
Yes
An idea we have tossed around also.
We have used different fixed numbers both to create bigger seperation between the different synapse creatures, and to roll back spawning.
Hadn't even thought about this one, and I actually like it. I am going to have to mess with these numbers a bit, and see what it looks like. Then give it a go :)
Tweak some of the FF values is justa bout the only thing we could think of. ?The problem units are mostly the WEs because you can pack in a lot of FF firepower in a small area. ?You could use a horde of Termagaunts to do the same thing, but it would be much more difficult due to space constraints.
The Norn Queen Report I'll be posting by Monday/Tuesday addresses this problem, and some others, with the Nid AVs and WEs. Basically I am going to make them better at CC and a little poorer at FF. Consider it being something like all WEs and AVs having CC3+ and FF5+ except for the Carns which don't change.
Garrison Nodes: ?Either revised garrison standards for Nids or disallowing it outright
Again, the Norn Queen report goes into real depth on this issue, basically it is not going to be possible to do this anymore. The Report goes into real depth as to why.
Always, and thank you..............
Jaldon :p
PostPosted: Sun Apr 30, 2006 6:38 am
1. WEs and regen. If the regen goes down to 1/2 DC, would it be possible to regen with 5+? As for me there has been rarely the time that I manage to throw the 6 with full DC, never mind the 1/2 DC. This would keep the general rate of regen same, but disallow too fast regeneration. Also keep in mind that the Dominatrix didin't get lowered price so this will make her even less wanted.
It is going to be 5+, what I wanted to do was lower the bar so that the WEs didn't 'spring back' to full, or close to full, life again. 1/2 the total while increasing the chance should aleviate this problem. Again,as with all changes, playtesting is the best way to find out.
2. Spawning. I feel that the current system is too fast. I posted the list on the other thread that I would have used had I managed to get a game. And I think that that would have been quite effective list. And would have formation, which the enemy would not have been able to finish off with the current rules. I think that we need to have some minuses when near enemy as well as general slowing of the speed. So I'll wait and see the report.
Att his time I am hestitant to put any minus in it until I get something that is more workable. I would like to avoid them if a I can.
3. FF. I don't know what others are thinking, but I don't want all FF ability to vanish. I think that some should be able to be FF support to swarms. I haven't found it too bad, but perhaps I play with a different style. I do think that Nids should have some around (haruspex B perhaps). Without it, killing skimmers becomes quite hard. And I do think that hierodule is the bit that needs work.
The problem that Neal addressed above has also been occurring more, and more, in our battles as well. And this includes all of the present WEs and AVs on the list. I want to try the proposed changes across the board, I really don't think it will cripple the Nids.
Thanks All............
Jaldon :p
