[Rules] BM idea?
 Post subject: [Rules] BM idea?
PostPosted: Mon Oct 24, 2005 7:15 pm
I've been thinking that nids not suffering BM is a bit.. well nasty for the opposition.  So I was thinking that when they automatically suffer a BM, ie failing an activation roll, rolling a 1 for teleporting, maybe coming undefire, but not for suffering casulties.  They suffer a single hit one the majority unit (or weakest armour save if tied).  This could represent the whole small ones getting stamped on in the stampeads a hivenode growing though some granite and damaging its hive ganglia ect.
Tyranid air marshal
PostPosted: Mon Oct 24, 2005 10:34 pm
I'd sign up for this for teleporting, but not the rest. I do feel kind of dirty when my opponents points out I need to roll for BM "sorry mate, no point!"
The other stuff doesn't need anymore negative effects. IMHO
Cheers Scott
Tyranids 5.40B - (w/d/l) 5/2/2
PostPosted: Tue Oct 25, 2005 5:27 pm
There were a number of suggestions concerning this on the old board - I know I suggested a rule, as did a couple of others. I'm sure someone could search round and unearth those suggestions. Mine was simply that Tyranids took BMs for anything but casualties, and if it took a number greater than the number of Synapse Creatures present, then the formation would be forced to take a Hold action as its next action, as it regroups and is slowed down/disoriented by the enemy assaults, etc.
PostPosted: Tue Oct 25, 2005 11:05 pm
I take it your idea also has it that they don't take them for coming underfire, NO-1.  Otherwise tyrant lead formations would never doing anything of value.  Also what would happen to the indepdendant formations that took BMer?
Tyranid air marshal
PostPosted: Thu Oct 27, 2005 1:38 pm
Quote (ragnarok @ 25 Oct. 2005 (23:05))
I take it your idea also has it that they don't take them for coming underfire, NO-1. ?Otherwise tyrant lead formations would never doing anything of value. ?Also what would happen to the indepdendant formations that took BMer?
Well, my suggestion was made before the Hive Tyrant was made a seperate choice from the Tyranid Warriors. Even then, it was a relatively undeveloped suggestion - the full details hadn't been, and still haven't been, worked out.
PostPosted: Thu Oct 27, 2005 7:35 pm
An idea I had today, is that independant broods suffer from BM like normal, possible with ATSKNF.  Since 'stealers and 'vores roll Ld tests as normal when out of synpase range in 40K.
Tyranid air marshal
PostPosted: Fri Oct 28, 2005 1:32 am
Quote (ragnarok @ 27 Oct. 2005 (19:35))
stealers don't test in 40k...
PostPosted: Fri Oct 28, 2005 9:37 am
ragnarok
Stealers and vores have brood telepathy, which makes them use normal moral and pinning checks when outside synapse range.
Tyranid air marshal
PostPosted: Sat Oct 29, 2005 4:58 pm
Quote (ragnarok @ 28 Oct. 2005 (09:37))
ragnarok
my bad, I thought you meant IB tests...   :8):
