RULES: Synapse control
 Post subject: RULES: Synapse control
PostPosted: Fri Aug 26, 2005 3:22 pm
Synapse Control & War Engines
The synapse control range of War Engines (Dominatrix) I think should be greater, how about a range equal to the Damage Capacity, multiplied by 5cm. The Dominatrix would then have a synapse range of 40cm.
Or how about 2 new special rules, having two ranges for synaspe control
Greater synapse creature: 30cm range or more (dominatrix)
Lesser synapse creature: 15cm range (for hive tyrants, tyranid warriors)
In the spirit of Hostility!
whotizname
PostPosted: Fri Aug 26, 2005 4:54 pm
Are you having a problem fitting your swarms into a 15cm radius?  That's actually a really large area.
I'm asking to see if there is some sort of deficiency you are trying to address.  I haven't heard anyone complain that the radius was difficult to use or that it negatively impacted the army beyond the level it should.
I can understand your desire for the flavor of it, but it's going to add significant durability, open up some entirely new tactics, and create questions about interaction between SC creatures.  In light of that, I think there should be a compelling reason before attempting such a change.
PostPosted: Fri Aug 26, 2005 9:00 pm
I agree with what you say, I was just an idea of 'the top of my head', a thought that larger tyranid synapse creatures would have a larger control radius.
Consider, the control radius of a hive ship, hundred if not thousands of metres.
Still your points are well made
I will consider further thought to my ideas in future. :D
whotizname
