[Xeno-Biostatistics] Bio-titan weapons
 Post subject: [Xeno-Biostatistics] Bio-titan weapons
PostPosted: Thu Oct 27, 2011 4:00 pm
I wanted to preface the Bio-Titan thread (hoping to post later today) with stats for all the old Bio-titan weapons. I don't have the SM/TL stats with me but the NetEpic stats are very close so we'll go with those for the moment:
Code:
Bile Launcher     100cm   1          3+   -3
Bio-Cannon        75cm    3          5+   -3
Cluster Spines    50cm    8BP        3+   -1
Pyro-Acid Spray   0cm     Template   3+   -2
Ignoring special rules for the moment, range-wise there's a clear progression: Pyro-Acid Spray, Cluster Spines, Bio-Cannon and Bile Launcher. Given that I'm looking to give those EA ranges of 15cm, 30cm, 45cm and 60cm respectively.
For firepower:
The Bile Launcher is the weakest, it's 1/3 the shots of the Bio-cannon but it does have a handy barrage-like special rule for splatter. Given that I was looking at giving it 3BP.
The Bio-Cannon has good armor penetration (-3) and rate of fire. With that and the 40k stats for them I'm going with a MW4+ for these.
The Cluster Spines have a lot of barrage points, enough that I think 4BP ought to work here.
Finally, the Pyro-Acid Spray has good armor penetration and using the flamer template to hit. Rather than try to bring that back though I think 3BP MW works. However, they did have Ignore Cover in NetEpic (not sure about SM/TL), thoughts about adding that as well given its 15cm range?
Code:
Bile Launcher     60cm     3BP    -
Bio-Cannon        45cm     MW4+   -
   and            (15cm)   SA     Extra Attack (+1), Macro-weapon
Cluster Spines    30cm     4BP    -
Pyro-Acid Spray   15cm     3BP    Macro-weapon (perhaps Ignore Cover)
So what we're left with are weapons who's relative power decreases as their range increases. I think they'll be fairly easy to balance this way. Thoughts?
For the Razorclaw, obviously a TK CC attack is needed, I was thinking TK (1D3). They also had frag spines embedded into them as well, I was thinking of doing something similar to the Eldar Titan Power Fist here, namely EA (+2) in FF if the Razorclaw isn't used for CC. Thoughts?
Code:
Razorclaw   (base contact)   Assaults Weapons   Extra Attack (+1), Titan-killer (1D3)
   or   (15cm)   Small Arms   Extra Attack (+2)
 Post subject: Re: [Xeno-Biostatistics] Bio-titan weapons
PostPosted: Thu Oct 27, 2011 4:16 pm
From the modern standpoint, there are only two Bio-titan weapons; the Biocannon and (bloody huge) Scything Talons.
Personally I think the wide variety of bio-weapons should be kept for a bio-titan focused list rather than in a core list.
PostPosted: Thu Oct 27, 2011 4:30 pm
I dunno, the above 5 weapons aren't that much, they certainly leave scope for more in a Titan specific list
PostPosted: Thu Oct 27, 2011 4:31 pm
I'd echo Zombo on this one.
PostPosted: Thu Oct 27, 2011 4:42 pm
Those thoughts aside, what do you think of the stats? We're not talking army lists at this point.
PostPosted: Thu Oct 27, 2011 4:52 pm
Well I dislike the Biocannon stat, I prefer the old 2 shots and AP focused ones.
Definitely don't have both MW and Ignore Cover on a barrage; one or the other.
Cluster Spines seem more like something that should give extra FF than biocannons.
PostPosted: Thu Oct 27, 2011 10:46 pm
i'd rather see the acid get disrupt and ignore cover, giving it MW and IC is a bit nasty i think
i agree with zombo on the cluster spines getting the extra firefight attacks.
i also think that for the most part, he's probably right about not needing too many options for weapons in the core list. i'd suggest like the gargants, have a default option, with a "can swap X for Y" option. pick a weapon that suits (either bile if you're swapping the claws, or probably the cluster spines if you're trading the biocannons) and leave the rest for somewhere else
PostPosted: Fri Oct 28, 2011 12:16 pm
So i'm back home and have all my books handy :)
The Bio-Cannon should definately be 2 x 45cm AP3+/AT4+ Ignore Cover as it's roughly the same as two Demolisher shots.
PostPosted: Fri Oct 28, 2011 8:36 pm
Other Bio-Titan Weapons (according to Netepic) include Ripper Tentacles, Spore Pod and Stinger Salvo which I believe all had models which bump it to 9 weapons total (if you include the modern really big scything talons)
PostPosted: Fri Oct 28, 2011 8:49 pm
Titan-grade Scything Talons, Bio-Cannons and Ripper Tentacles is all what we need for the two lists.
The Bio-titan list can use the other weapons.
PostPosted: Wed Nov 02, 2011 2:44 pm
Stat time:
Code:
Bio-Titan Bio-Cannon         45cm             3x AP4+/AT5+      -
Pyro-Acid Spray              15cm             3BP               Ignore Cover
Ripper Tentacles             (base contact)   Assault Weapons   Extra Attack (+2), First Strike
Razorclaw                    (base contact)   Assault Weapons   Extra Attack (+1), Titan-killer (1D3)
   or                        (15cm)           Small Arms        Extra Attack (+1)
Massive Scything Talons      (base contact)   Assault Weapons   Extra Attack (+1), Titan-killer
Gargantuan Scything Talons   (base contact)   Assault Weapons   Extra Attack (+1), Titan-killer (1D3)
I'd rather not add extra FF attacks to the cluster spines since it never had them before. I'm just looking to extrapolate the SM/TL effects into EA.
For the bio-cannon, the titan-grade version had more attacks in SM/TL hence the RoF increase for it here.
For the Ripper Tentacles, I think the the current 9.2.1 rules are fair enough. I don't believe Spore Pods or Stinger Salvos ever had models however, hence why they've been left out. We can obviously add them in at a later date however.
PostPosted: Thu Nov 03, 2011 10:45 am
Bio-Cannon should be the same for each creature. Still thonk 2 x AP3+/AT4+ is the way to go.
Ripper Tentacles would be more proper represented if they would give First Strike to the basic CC-attacks.
PostPosted: Thu Nov 03, 2011 11:01 am
Just leave the bio-cannon as the same for each creature please. You're just adding unnessesary complication otherwise IMO.
PostPosted: Thu Nov 03, 2011 3:06 pm
So noted on the bio-cannon.
PostPosted: Thu Nov 03, 2011 4:38 pm
Interesingly, the biocannon on the hierophant in the apocalypse rules does actually have more shots than the Barbed Hierodule one, so we could go either way on that one.
