[Batrep] Marines vs Tyranids - 3000pts
 Post subject: [Batrep] Marines vs Tyranids - 3000pts
PostPosted: Thu Jun 11, 2009 9:41 am
Well, here it is, the battle report I promised. I hope it is imformative and entertaining.
Battle Report – Tyranids vs Marines 3,000pts
Marines:
Thunderhawk, Devestators, Dreadnaught, Librarian
Thunderhawk, Devastators, Dreadnaught, Librarian
Predator Annihilators, Hunter
Warhound (standard), Warhound (inferno) - BTS
Terminators, Chaplain
Landspeeders
Tacticals, Supreme Commander, 2 Razorback
Activations: 9
I took Librarians in the T.Hawks instead of Chaplains to try to destroy the AV in the swarms I assaulted, its more risky than inspiring but you need to damage those synapse. The Dreads were used in case of a draw roll and the Tyranids got into CC. It was the first time I had used a Predator squadron for a long time, but as people say they are ok, I thought I would (more AT shots); the Hunter just gives a long range AT shot. Tacticals are (mostly) a waste of time, but I cannot bring myself to field a Marine army without them; the commander was to make sure the T.hawks did not fail an activation (as much as the 150points galled me to do so!). Activations are a little on the low side with this army, but that is because of the commander and using a 2 T.hawk strategy and the dreads – both of which I don’t normally field).
Tyranids:
6 Genestealers
(Left swarm) 3 Warriors, Zoanthrope, 2 Gargoyles, 4 Hormagaunts, 4 Termagaunts, 2 Malefactors, 1 Haruspex
6 Raveners (burrowing)
(Centre swarm) 2 Hive Tyrants, Zoanthrope, 2 Malefactor, 6 Hormagaunts, 4 Termagaunts, 2 Gargoyles
Heirophant Bio-titan
Harridan, 5 Gargoyles
Dominatrix
(Right swarm) 3 Warriors, 2 Haruspex, 2 Malefactors, 4 Termagaunts, 2 Hormagaunts
Activations: 8
BTS: 9
The swarms have designations to be able to identify them during the battle (and from photos). This is a fairly typical Tyranid army he uses, though he recently got some Zoanthropes and wanted to try those out. The Dominatrix has proven to be a tough mother to kill so he decided to field it on its own, rather than with Trygons (though don’t do this against Guard!), she can spawn stuff onto her if needed. The extra Gargoyle was because he had points left over. His tactic was as simple as it always is; triple and charge, firemen and fires!
Deployment
As can be seen from the deployment photo, most of the objectives were on the left, so that is where much of the fighting would be. The Warhounds were to defend the blitz, the predators to assist them by killing anything that can hurt the Hounds (the Tyranid AVs) while the tacticals were effectively a reserve formation; they will move to the right to give width (and break up the Tyranid advance) or swing into the centre to support the push on objectives. The Tyranids had a fairly typical deployment – 3 big swarms broken up by titans. The Harridan was positioned to flank the marine force and help hem them into the bottom left for the inevitable Tyranid rush.
Turn1
Strategy – Marines
The marines call in a Thunderhawk on Centre Swarm to help slow the Tyranid advance, while the Tyranids Left Swarm start to rush towards the Marines, taking position in the rocks. A second Thunderhawk is called in on the Left Swarm and blows a Malefactor and a Hormagaunt to pieces with its attack run. The Genestealers carry on lurking near the hill while the landspeeders, initially going for the genestealers, decided the Harridan was too menacing and switched to move behind Left Swarm; the melta weapons leave a Hive Tyrant a shrivelled husk. Seizing the moment, the Predators are ordered to engage Left Swarm, their Lascannons killing all the Synapse creatures and causing the Tyranids to mill about in confusion.
The Dominatrix acknowledges the plight of her children and charges the Landspeeders – two of the small craft make it out alive and the Dominatrix regains control of much of Left swarm.
Comment - the landspeeders had a choice, I could not counter and try to save as many as possible (she only assaulted 3) but that would enable Left Swarm to support, so I decided to go full speed towards the Dominatrix and hope. She killed 2 Speeders for 0 wounds, so the result was T=5 M=1, meaning 2 more speeders die
Seeing their chance, the Warhounds go on the hunt for the mother Bug and give her everything they have. The Dominatrix screams in pain, but her wounds regenerate and she remains unharmed.
Comment – she is one tough mother! I got 6 hits on her, 1 of them a MW and she lost no wounds! 4+RA, 6+Inv, 8DC is pretty good for less than 500pts. But I suppose it should be.
Right Swarm now rushes towards the Marine line and takes position in the ruins. Seeing the threat (and the Harridan looming), the Tactical squad move to the centre and fell a Malefactor from Right Swarm to try to slow them down. The Heirophant moves into the trees near the Tyranid centre and knocks a void shield off a Warhound, while Centre Swarm rushes towards the scout titans. Finally, the mighty Harridan also moves to the centre near the ruins (the Gargoyles spying a Thunderhawk) and its bio-cannons knock another void shield off the Warhounds.
End of Turn1
The Tyranids spawn a few more creatures – Malefactor on Right Swarm, Hormagaunts on Centre Swarm and another Malefactor on Left Swarm. The Dominatrix assumes control of most of Left Swarm, but some of it wanders off without Synapse.
Both the Thunderhawks disengage without a hitch, despite being mobbed by multiple Gargoyles each and the Landspeeders rally behind the hill.
Comment – observe the positioning of the Tyranid army after turn 1. The swarms have lurched forward into a mass and the big creatures are guarding the rear. This is to ensure that you cannot flank the Tyranid force. Dropping T.Hawk assaults into the rear will see me fighting the big powerful stuff, while attacking the swarms at the front is basically suicide – the Marines cannot get to the Synapse in the assault and, even if they did win, they will be counter assaulted by the big stuff. Knowing there would be space on the right, Right swarm took position in the ruins to make sure his gaunts got armour saves in an assault, making it the toughest swarm to attack. I needed some width to my Marine force now, so as not to get hemmed in.
Turn2
Strategy – Marines
Under pressure, the Marines needed some space. The Warhounds back up and open fire into the oncoming Centre Swarm, inflicting many casualties. The Tactical Marines, seeking to provide width to the army, move to the right of the hill by the ruins and put fire into Right Swarm, again inflicting some casualties.
Comment – I had the opportunity here to accept the Warhounds would be attacked and move the tacticals near Right Swarm then assault with a T.Hawk. It might have worked too. I decided not to risk exposing the tacticals just yet and to try to stem the assault be firing the Warhounds, laying BMs.
The Dominatrix with Left Swarm rushes towards the Warhounds and opens fire, knocking down void shields. Centre Swarm then charges, the hormagaunts easily closing the distance and the Dominatrix and Left Swarm provide supporting fire for the attack.
One of the mighty Warhounds was felled in the assault and the other fell back behind the hill on the left – the machines had survived.
Comment – as we decided to play the ‘½ gaunts’ rule, the warhounds got 5 gaunt kills and the Tyranids caused 3 damage, destroying a hound. T=6 M=3. Tyranids would have still won had the ‘1/2 gaunts’ not been used.
It was now time to put pressure on the Tyranid rear and the Marines called in a Thunderhawk assault on the Genestealers on the extreme right. The devestators got out and started to concerntrate fire on the bugs and the stealers, caught flat-footed, had no chance – they died to the last.
Comment – M=6, T=1, all stealers die
Seeing their chance the Predators on the hill concentrate all the firepower into the Dominatrix. Lascannon after lascannon shot pounds into the great beast. The Marines expect to see her badly wounded, but when the laser blasts stop, she was totally unscathed!
Comment – what do I have to do to hurt her?! Against my better nature (as my Pred looked vulnerable there) I decided to sustain as I do not think I would get a better chance. 9 hits, 0 wounds!
The Tyranids rush Right Swarm from the cover of the ruins towards the Tactical marines. Risking getting shot at, but not caring for the swarm, the Tyranids now have the Marines trapped – there are few places they can move where the Tyranids cannot get them. Attempting to outflank the swarm and retain even more width by baiting the Bio-titan, the Landspeeders move to the rock on the left. The Heirophant takes the bait and moves to intercept the Speeders, its bio-cannons destroying one and causing them to break yet again.
The second Thunderhawk seizes the opportunity and drops from the sky onto the Harridan, Devastators with grim faces engage the huge beast who ignores the shots and charges headlong. A flurry of wings and the Marines are mostly dead or dying and their Gunship in ruins, what remains withdraws towards the Tyranid baseline.
The Harridan gives chase and smashes into close combat again, leaving the rest of the marines dead. The loss of the Thunderhawk assault formation is a major blow to the Marines and removes options.
Comment – this demonstrates how fragile the Marine assaults can be on Tyranids. I thought the Harridan should be an easy target, but I failed to cause significant damage. The Harridan then followed up into combat and, with it ludicrously powerful 6 attacks (2 of the MW), it tore the Marines to pieces. 1st: T=3, M=4. 2nd: T=5, M=4. 3rd: Tyranids kill all Marines
End Turn 2
All the Tyranid swarms shrug off what shock effects from attacks remained, the synapse easily rallying all Tyranid creatures to them. Many more Tyranid creatures joined the swarms also – Dominatrix gets back a Malefactor and a Haruspex, Right Swarm gets 3 hormagaunts and centre swarm gets 1 gargoyle. The Dominatrix then passes Left Swarm over to Centre Swarm, going alone and forming a huge Centre Swarm in the process.
Unfortunately for the Marines, the Warhound fails to get back into the fight, as does the Landspeeder.
Comment – I expected the Tyranids to smash the centre, they were going to assault somewhere with 3 possible targets available at the start of turn 2 (firemen and fires!). The loss to the Harridan was a major blow as it meant the Tacticals were unsupported for the assault that is coming their way and, not being able to turn a swarm around, the Devastators on the right will now have minimal impact. To top this all off, I need to bring the Terminators down this turn on the blitz, or I lose the game. This means that yet again, the Tyranids will have 3 targets to assault, so they will defiantly get one of them…
Turn 3
Strategy – Marines
There was a flash of blue light and the Space Marine Terminators of the First Company appear in good order near the Harridan. They then rush towards the Harridan, expecting the fell the miserable creature. However, though they beat it back, they fail in their task and it still lived!
Comment – the Harridan is impossible! The Terminators only caused 1 wound on it. T=2, M=3 – the Fearless Harridan falls back.
Then, fearing for their own lives and that of their fellow Terminators, the Predators speed towards the Heirophant and away from the Dominatrix. Their Lascannon puncture the Bio-titans flesh multiple times and it is severely wounded. Right Swarm then charges towards the Tactical squad, the Marine commander shouting for his men to stand firm. They do, but it costs them dearly and they die to a man!
Comment – the Marine supreme commander really is rubbish for the 150 points he costs! Neither Fearless nor Inspiring is a bit of a joke for a Chapter Master… Anyway, the Tyranids utterly destroyed the Marines in this assault, it really was embarrassing, even though the Marines actually gave a good show of themselves. T=11, M=4 (without the ‘1/2 gaunts’ rule, the Marines would have been on 6 and still lost by loads). It was not actually that great a loss to the Marines though – something was going to get assaulted and this was the lesser of 3 evils…
Seeing the Synapse unguarded on Right Swarm, the Devastators open fire and fell 2 of the 3 Warriors. The Hierophant then moves across towards the Terminators, denying them their objective. Seeing the beast badly wounded, the Terminators call in the remaining Thunderhawk to strafe it – the shots bounce off the creature’s thick chitin, but it is also spooked and it scurries off into the woods. However, it appears that this just delays the inevitable as the Dominatrix also rushes towards the Terminators, while Centre Swarm rushes towards the Marines baseline.
Comment – I knew the Tyranids would take the Marine blitz as there was nothing to protect it, but I could hold off if the Terminators held the Tyranid blitz. I failed to realise that the Dominatrix was just in range with a triple move… I suppose I could have moved the Predators to the Blitz, but they would have been in assault range of Centre Swarm and certainly would have died. Besides, I needed to hurt that Bio-titan.
The battle was over and the Marines had failed in their task to defend this particular planet. There will be other battles on other planets, but for now, the Tyranids will feed.
Comment – Tyranids won with the Marine Blitz and one other Marine objective for a Take and Hold, while the Marines had one of their own and one Tyranid objective, meaning they had nothing… T=2, M=0
TYRANID VICTORY!
Comment – the Warhound failing to rally, the stalled assault on the Harridan, not being able to hurt the Dominatrix, despite the Warhounds and the Predators shooting her are all things I could point at to blame. A few tactical errors occurred on both sides, but the Tyranids are very forgiving of that while Marines actively punish for them. My overall plan started out well, I destroyed Left Swarm and forced the Dominatrix to commit, removing her from the Tyranid Blitz. I knew she would come for my Blitz like a freight train and I just planned on contesting it with the Warhounds. My Terminators would drop on the Tyranid Blitz while my Devastators held the objective on the hill, giving me two points to the Tyranid zero. Alas, is was not to be. The Tyranids, for their part, performed as expected – Swarms rush while biggies hold the rear, get more assault targets then your opponent can move out of the way, then crush those targets you do have. The fact they they threaten so many of your formations means that it is hard to set up combined assault/support situations because you need activations to save some units.
Recommendations.
Harridan – lose the 2 MW attacks and drop its points to 150.
It should be a harassment creature, skulking the flanks and picking off stragglers. However, its current stats allow it to charge headlong into an armoured formation and destroy them!
½ Gaunts – drop it, it is not needed. In this game the dropping the ½ gaunts rule would have meant that the Marines would get a dice roll in assault, as opposed to getting so utterly crushed that they all died.
Rally,Engage - switch to +1 for these instead of +2 as it gives a reason to lay BMs on swarms to try to slow them a little.
I hope you enjoyed this battle report!
PostPosted: Thu Jun 11, 2009 12:03 pm
The Warhounds were not in support range as I had considered that option, but I would have had to move hounds forward. I might have beaten the swarm, but then the hounds would be destroyed by Dominatrix and the net result would have been the same either way. By moving back I denied the Dominatrix an assault and reasoned I had a better chance against the swarm where only the Horms could charge I would have void shields against the rest.
The Terminator DID get the MW attacks - see the arrows on the photo, they charged into Close Combat.
I reduced the Bio-Titan to only 2 wounds with the preds and dropped enough BMs on it to ensure I could break it with a T.Hawk, which I did.
The dominatrix was very lucky to make all its save from both Landspeeders, Predators AND Warhouds. I wanted to wound it enough that it became dangerous for him to use it so boldly as I would have got BTS had it had died (and won the game).
And I normally would let the Nids got first, but I wanted to lay a BM and hope he failed an activation, which would have stopped his 'triple then charge' dead in its tracks and gave me more room to move.
As for the T.Hawk assaults, they were both in Turn2...
UNless you meant on turn 1? Again, I considered that, but the point of attacking the Genestealers was because they had that objective, not to remove them. If I had done it on turn1 the Harridan would have attacked the Devs and I would have died, thus not having the objective I needed to win.
PostPosted: Thu Jun 11, 2009 12:54 pm
Thanks for the report, alakazam!
If I could make one suggestion about writing/posting them: It would be great if each Turn was its own post... makes it a little easier to comment!  *laugh*
Honestly, I'm quite surprised at the survivability of the Harridan!  It's only got RA5+... it should've died a lot quicker than that facing Devs... is your Tyranid player know for his luck?   :laugh:
As Hena mentioned above, the trick to taking out Tyranid war engines is to set up crossfires to reduce their armour...  they fold pretty quickly then... not always easy to do, of course!
PostPosted: Thu Jun 11, 2009 3:48 pm
Tyranids must be assaulted to break them.
Yes, but the only way to kill Synapse is through shooting. See what happened to Left Swarm in turn 1. If I had done what you suggested then, yes, I probably would have defeated Centre Swarm. But then the Donimatrix was in range to assault the Warhounds (which were my BTS - dont forget that) and the Heirophant or Harridan would have killed the Devestators that just dropped from Thunderhawk. I would have lost 2 formations. As it happened, I only lost 1 Warhound and, if it had rallied, I would have possibly won the game.
Umm... With Harridan I would have used skimmer ability to force FF
Maybe, but with 6 attacks (2MW) he could severaly damage the Terminators. He was not bothered about loosing the Harridan at this stage, he wanted the Terminators broken from his Blitz...
Yet you never tried to create crossfire.
Well, if my opponent would have been kind enough to stop killing my units, I might have been able to...  :smile:
You saw the positioning after turn 1 - what oppurtunity was there? It is easy enough to say it, but doing it against a skilled opponent is another matter. Fires and Firemen...
I suppose I could have held the Landspeeders back a turn and used them for a crossfire, but I also needed the to crossfire Left Swarm, which I did and killed all the Synapse - reducing him to only 2 big swarms.
If I did the army again I would have dropped the supreme commander and the dreads and taken a second Landspeeder formation to make crossfires more likely.
Of the major marine failings I would agree that the tactical squad were underused. I used them to create some width to the army and then they were poised to assault Right Swarm after the devestators had dealt with the Harridan - alas, the winged beast had other plans...
Yes, he was, by his own admission, lucky on saves in this game. I forced his Dominatrix to take 3 Inv Saves and he made them all (if he had failed even 2 of them, I would have risked units to crossfire it and get my BTS). The Harridan only took 2 wounds the whole game despite me hitting it with 2 assaults. However, I did not really need to kill the Harridan, only break it, so I was not that upset by the Terminators failure to kill it. The Dominatrix was a different matter.
Anyway, I knew it would happen that everyone believes the Tyranids are so underpowered that it was obviously the Marine failings that caused the loss. Our Tyranid player is hurt that you believe his skills to be so inferior that it was not due to his clever use of the Tyranids that he won  :smile:
Any comments on the Tyranid tactics?
My friend just wanted people to know that he does not agree with the 'tyranids are underpowered' assessment of the list. He thinks Chroma has done a great job so far but agrees there needs to be tweeking.
PostPosted: Thu Jun 11, 2009 5:09 pm
I can't see the pics here at work so I'll reserve commenting on most of the game for later, but what rules were you using? I noticed in your list you have a non standard warhound configuration. Second, I'm surprised with your loadout for the dev detachments since it prevents you from filling the thunderhawk or using the two you have to their greatest potential. I think you would have been better off just taking 2 dreads for the detachment or none at all and packing both into a single thawk since it would have given you more dice in the assault as well as more units. It would also give you an empty thawk you can drop in and scoop up the two devs with and leave no detachments on the ground.
Against RA, short of having some kind of TK shot or MW shot, you need to get crossfire or it's basically worthless to shoot as has been mentioned and as marines it's really important to concentrate formations more and set up supporting fire or multiple unit engage clipping assaults.
That's about all I can say until I see the pics, however, your nid results are anomalous to the general results I've seen posted which is why folks are questioning your tactical choices opposed to the nid tactics.
-Vaaish
PostPosted: Thu Jun 11, 2009 5:34 pm
That, and its easier to continue to bang the 'nids are underpowered' drum, despite the fact the the Tyranids have racked up a few victories from battle reports recently.
I have posted this in response to a request from Chroma in order to assist in Tyranid development and so far there has not been a single comment on the Tyranids. The lists I have seen have not included any Haruspex or Malefactors, yet these give a)reinforced armour saves to you Synapse and b)a lot of punch in assault. You speak of clipping assaults, yet fail to 4acknowledge that a Malefactor (placed on the flanks of the swarm) is 2 FF dice hitting on 4s - 2 of them will give 4 FF dice to a 'clipping' assault (with a 5+RA save) meaning the 'Nids are still in with a good chance at causeing damage. And as for the Haruspex, though it is taken mainly for the 4+RA, if it actually gets to assault it is a total beast!
Why dont people take these creatures in their Tyranid list? Why the fixation on Raveners to protect the synapse when they only have a 5+ save?
There are a lot of questions that Chroma could ask about the Tyranids and I am just doing my bit to help.
PostPosted: Thu Jun 11, 2009 7:22 pm
Great report, thanks for the write-up and coments  on intended tactics.
I note you think the Marine SC is 150?? I think you will find it is only 100 points (50 + 50  upgrade), but he is expensive.
On Tactics, I agree that you should try to reorganise the list to make better use of the THawks. Devs and a Dred get ~3.16 hits, and are slightly better than Tacticals though fairly static. However, if you stripped the dreadnoughts and put both in a single THawk, you get ~5.3 hits, and have the option of adding a Chaplain as well as the Librarian. Even better Vs Nids, you have the potential to use them to land and fire with cross-fire - and the second THawk to pick them up and do it again. Note, by dropping the Razorbacks together with the 150 saved so far and you have a second Land speeder formation - - - -. Another formation choice would be Thunderbolts both because they provide 'omni-directional' attacks, and they give extra activations.
I agree that you need to use the Marines mobility to concentrate on particular points - when you do need to make sure you will get an overwhelming assault to destroy a swarm / prevent retaliation. Another tactic is to out-activate the 'Nids, so as you win the strategy roll, let them go first and then try to move to areas that cannot be threatened. Doing this (and getting 11x formations for 9x activations) should both allow you to build up a concentrated assault on one point for turn #2, while extricating your army from another area.
Obviously the Nids are strongest when the swarms are marching across the table close together to provide mutual support with the WE killing machines running after objectives and enemy formations. But this should allow the Marines the freedom to manoeuvre on flanks and rear as you did.
One final thought is that you should avoid using my dice - or make sure you are using his 'very' lucky dice :laugh:
PostPosted: Thu Jun 11, 2009 7:27 pm
I mentioned I'm not familiar with the nid list for most things which is why I didn't mention specific nid units in an assault, but the ability to do a clipping assault has nothing to do with what nid units are there or not. That malefactor will only give those attacks if it is part of the assault and clipping assaults don't necessarily have to come from the flanks since you can get the same effect anywhere you minimize the number of enemy units in the assault. However, since you brought it up, a 5+RA save means you save about 65% of the hits which is slightly better than a marine. 4FF dice if there are two caught in the assault(for sake of nice round numbers) grants them about 2 hits. Marine 4+ armor means you will likely lose one unit. This is just vacuum math though since it doesn't take into account where you hit the swarm and what else is around it, but my point is if you are pulling a clipping assault with 2x dev detachments and a thawk you have ten "units" in the assault and even losing one to a Malefactor, you will likely kill plenty more than that(2x4+ FF, 8x3+ FF, and 2x3+MW total 12 attacks; 6.3 normal hits and 1.3 MW hit) to balance it out and give you a good chance of winning the assault and breaking the swarm regardless of what was actually killed unless I'm missing some rule for the nids that lets them ignore breaking if they lose an assault. Once broken, the nids will either have to pull in another swarm to counter attack you or you will be able to extract the troops with the second thawk. Remember you only need to get within 15cm of the nid swarm and they will likely only be able to counter charge 5cm keeping you out of CC with some of the nastier beasts.
-Vaaish
PostPosted: Thu Jun 11, 2009 11:22 pm
Mainly because Raveners are a Common Brood, which you get four per clutch, while the Assault Spawn are more expensive and you get less.
Raveners can "soak" AT and AP hits, while the Assault Spawn can't.
Assault Spawn *are* good, but find them better as *assault* units, rather than Synapse bodyguards.
PostPosted: Thu Jun 11, 2009 11:52 pm
Yet the Tyranids are said to be 'failing' with the tried and tested attitudes? *shrug*
I have said what I have to say on Tyranids and now bow to far wiser heads.
PostPosted: Thu Jun 11, 2009 11:56 pm
It's got nothing to do with "wiser heads", it's that the "old way" of being able to screen your Warriors with other infantry is now gone, and people are having to adapt their play-style... and that's usually when you lose more games.
People are developing "new ways" to do that, so new player input is always welcome.
PostPosted: Fri Jun 12, 2009 9:59 am
But if people are not taking any Tyranid AVs then either a)they have not considered to do so (and perhase they should try a "new way" or b)there is something fundamentally wrong with the Tyranid list that a whole category of unit is considered worthless...
PostPosted: Fri Jun 12, 2009 10:03 am
You cannot really count my game in this lot as the marine player himself admitted that he played in a manner not worthy of a battle report.
