Nid Army
 Post subject: Nid Army
PostPosted: Thu Feb 14, 2008 12:09 am
I managed to pick up around 5000pts of Nids for ?30. Which was rather good.. However it is seriously low in Common Broods, so I will probably be putting it together as a 3k army to start with.. Never having played with Tyranids this is what I've come up with. Any suggestion needed.
Common
12x Gargoyles 300
12x Hormagaunt 150
24x Temagant 450
900
Uncommon
1x3 Carnifex 100
1x3 Haruspex 150
1x  Trygon 100
1x2 Exocrine 150
500
Synapse
1x  Harriden 200
3x3 Warriors 450
1x  Hive Tyrant 100
750
Independant
1x7 Genestealer Swarm 175
1x6 Lictors 300
1x  Hydraphant 375
850
My Photobucket
PostPosted: Thu Feb 14, 2008 12:23 am
Awesome deal!
And, yeah, Common Broods aren't so common anymore!
I'd suggest trying to get some 40k Rippers to use a Raveners to bulk up your Common Broods.
Are the models you got based and painted already?  If not, try doing 4 Common Brood models to a base instead of 5 to make them stretch.
Looking forward to seeing some pics!
PostPosted: Thu Feb 14, 2008 12:28 am
They are based, but I was planning to strip and rebase them so I will probably do what you suggest.. Do you think the 3k army needs any more?
My Photobucket
PostPosted: Thu Feb 14, 2008 12:42 am
(mageboltrat @ Feb. 13 2008,23:28)
Seems like a good amount to me!  I like Raveners, but many play without them.
The models you've got should give you a competitive army... regardless of which way the list evolves.  *laugh*
PostPosted: Thu Feb 14, 2008 12:53 am
I want to do some converting eventually, but get a playable army up fast/
My Photobucket
PostPosted: Thu Feb 14, 2008 3:56 pm
I think 4 to a base looks fine and I use 20x40mm bases.  And like Chroma said it will up your units by 20%.  Picking them up on eBay will be fairly expensive.  7 USD a sprue is how they've been going.
Epic 40k 'fex... don't get me started.  I've seen less than half a dozen auctions for those over the past year.  It's never pretty.
PostPosted: Thu Feb 14, 2008 4:22 pm
I have 3 of the huge original ones. So I will have to use them, I would have prefered the smaller ones.
My Photobucket
PostPosted: Thu Feb 14, 2008 9:39 pm
(mageboltrat @ Feb. 14 2008,15:22)
I have 6 of each and prefer the bigger ones.  They are esier to convert into the new hunched version.
Tyranid air marshal
PostPosted: Thu Feb 14, 2008 9:50 pm
Looks pretty neat! I'm still of the opinion that at least one of the common brood creatures should be an AV, personally. Just because the prospect of an all-biotank army would be neat.
PostPosted: Thu Feb 14, 2008 9:55 pm
I have several going spare.
PostPosted: Thu Feb 14, 2008 10:10 pm
(Ilushia @ Feb. 14 2008,20:50)
Something along that line is in the works for one of the alt-Tyranid lists I've got on the back burner...
PostPosted: Fri Feb 15, 2008 4:33 am
On round washers as bases they look good with 3-4 infantry per base and stretch even further.
PostPosted: Fri Feb 15, 2008 5:07 am
Hey good to see you back ratty :)
Can't wait to see what you come up with for the nids!
PostPosted: Fri Feb 15, 2008 5:11 am
You reacon round.. because that was what I was thinking.. I was going to go for snow bases with bitz of wall.
And I was thinking pink flesh and bone carapace
My Photobucket
PostPosted: Fri Feb 15, 2008 5:22 am
Yep sounds great! :)
Definitely go with the round bases.
