Post new topic Reply to topic  [ 107 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8  Next
Is it possible to transport gargoyles?
 Post subject: Is it possible to transport gargoyles?
PostPosted: Thu Jul 02, 2009 4:00 pm
Quote: (Chroma @ 02 Jul. 2009, 15:51 )
Quote: (Evil and Chaos @ 02 Jul. 2009, 15:48 )
And the current number of words in the 'nid Special Rules is... 1291?
I get 1132.
I hope you're not including the reprinted "Tunnelers" rule in there, since that's a general rule that just wasn't included in the online pdfs.
And a lot of "flavour" text could be pared down if we really need to get the word count down.
I was; I get 1122 words without the Tunnelers rule (I didn't count headers).
PostPosted: Thu Jul 02, 2009 4:03 pm
So, I guess we're "good" there...   :laugh:
/Still working on cleaning up the Special Rules...
*cracks whip*
Do stuff!  :))
PostPosted: Thu Jul 02, 2009 5:44 pm
Just for reference since number of special rules compared to the French list was somehow spawned, I'm posting what each official list has(forgive any mistakes):
Nids: 5 special rules
Biel-Tan: 4 special rules (after the removal of Pulse and Spirit stones)
Siegemasters: 3
Feral Orks: 1
Space Marines: 2 (3 if you count drop pods)
IG: 1
Orks: 1
Black Legion: 5
And compared to a few of the other lists I have on hand:
AMTL 3.14: 0 (1 counting the warhead special rule)
DE: 4 (6 counting no garrison and lance)
Minervan: 2
Necron: 7(!)
Tau: 4
I don't have a nid army to try them out, so I'll refrain from commenting on how it plays, but having pulled it open and read through it thoroughly for the first time, here are my thoughts on how understandable it is and what might be done.
Swarms: Straightforward but wordy. Fairly simple to explain though.
Relentless, expendable: no problems at all, very straightforward.
Mobility: Pretty clear, but not as clearly presented as the Relentless. WE and AV moving through terrain seems awkward, and the LV seems slightly ambiguous. (what counts as normal terrain, if it only works for moving through, are they normally affected if they are just in terrain or must they take a test if terrain is dangerous to infantry but not vehicles?)Special effects seem odd. Wouldn't this only apply to WE and AV and only to the dangerous test, and do they have to take a dangerous test in these cases (lava flows or other special terrain) since they are said to never take it?
Spawning: mostly straightforward, but very complicated in that there is a lot of stuff to remember that modifies what you can spawn and how much can be spawned. It also reads that it doesn't matter the outcome of the rally or marshal rolls, it can still spawn. If they need to pass it successfully, the -1d3 for broken can go away. the -1d3 for being on a hold action I think I can understand better, but it still seems an odd caveat. Dom I understand is worth giving the bonus, and enemy within 30cm can be assumed to be killing off nids reducing the effectiveness of spawning.
As far as what you can do with the spawn points, the war engine option seems hopelessly idealistic given that even getting enough points to spawn a 2dc WE is going to require exceptional rolls. Even more so for 3dc WE. If this is meant to represent existing WE regenerating DC, I think it could use a bit of clarification. Because of that is spawning even needed for them?
Can spawning be simplified to say,
After a Synapse Swarm successfully marshals or rallies, it may attempt to spawn infantry and vehicle brood units. Each Synapse Swarm rolls 2D3 modifying the number of dice rolled using the list below.
Synapse Swarm contains a Dominatrix +1D3
Any unit of the swarm is within 30cm of the enemy -1D3
The total rolled is the number of points available to add dead Brood units to that specific swarm using these costs:
Infantry Unit 1 Spawning Point
Vehicle Unit 3 Spawning Points
All spawned units must be placed within 5cm of a Synapse creature from the swarm spawning them, joining the swarm even if they were not originally part of it. Spawned units may not be placed in the zone of control of enemy models or in impassable terrain. Excess spawn points are discarded.
Again, coming in fresh and reading what's there, and based on the assumptions above, I tried make it read more cleanly (at least to me) and cut down the amount of stuff to remember without changing the essence of the rule. Some minor changes have larger effects, like making the rally and marshal rolls need to be successful so I could remove the need to modify the spawn points for a hold or broken formation. It also seems statistically improbable to get enough points to spawn WE most of the time and only possible in a Dom swarm, so I pulled that. I lumped all vehicles to the same cost for two reasons, put more emphasis on bitey infantry broods (horde of tooth and claw) and because it was a category that seems to only contain the biovore and ravener. Since you you can only spawn when you successfully marshal and rally, there wasn't any need to for the last sentence about spawning in to broken swarms. It comes in at 134 words from 214 originally.
This is just all my impression for reading through it.
-Vaaish
PostPosted: Thu Jul 02, 2009 5:51 pm
I disagree. "Swarms" is anything but straightforward, as it completely breaks one of the main rules of Epic, fixed formations. Trying to explain the intricacies of this to an opponent during the 5 minute warmup is not going to go well.
PostPosted: Thu Jul 02, 2009 6:08 pm
"so they may change formations".
You really don't think a new opponent would say "huh? What do you mean change formations? How? Why?"
PostPosted: Thu Jul 02, 2009 6:14 pm
Okay so instead of "so they may change formations" go instead "in end phase brood units are controlled by synapse creature they are in range of. If in range of several tyranid player choose". That was hard. NOT!
You are making too big of a fuss about this. Also remember that this 5 minute thing is actually more important in friendly games. In tournament games you know you can run into tyranids before hand(you DID read tournament rules didn't you?) so if there are unfamiliar armies allowed you can do that readout at home at your leisure.
www.tneva.net
PostPosted: Thu Jul 02, 2009 7:22 pm
From the other thread, moved here to try to keep on topic:
Quote: (Chroma @ 02 Jul. 2009, 19:16 )
Quote: (Ginger @ 02 Jul. 2009, 19:14 )
- How to handle gargoyles that can be both part of a swarm and 'independant'?
This question has already been answered... just not sure if it's in this thread or the actual Gargoyle one.
The question has been answered as to how it currently works, but there remain serious questions over whether it should work that way.
Chroma: I'm yet to hear from you on whether you think it makes sense that gargoyles/raveners who are bought with synapse vanish when the synapse dies, but those bought without synapse remain fine. Even Hena admitted this is a dichotomy...
Yes the rules are currently clear on the matter, but does that mean they're right?
Either gargoyles and raveners are smart enough to work without synapse or they're not, but currently they're both, like some bizarre Schrodingers Bug.
PostPosted: Thu Jul 02, 2009 7:56 pm
I don't have a problem with units changing formations, it does have precedent with WE picking up infantry to transport thereby changing the formation. I would only have a problem with it if it becomes unclear which unit is part of which formation.
I still think the section could be pared down and cleaned up to make it even more clear.
They work as "shields" for Dominatrix :;):.
Still though, I think it seems rather unlikely that you will get the requisite 6 spawn points to spawn a 2dc WE, and even as shields would it really change much if it was just simplified to exclude WE in the spawning?
About spawning. The modifiers tries to resemble rallying. Eg. modifiers for being close and broken. I don't mind it emulating the rally modifiers, but 2x the number and based around a d3 which further complicates the process seems a bit much. It might be so bad for the nid player that knows the list well, but for a new player or the nids opponent who might not be familiar with the list it seems an ideal spot for fudging or forgetfulness granting the nid player an advantage with spawning.
I guess what I'm saying is how much is really needed to keep the feel of the list without it devolving into minutia?
-Vaaish
PostPosted: Fri Jul 03, 2009 12:32 am
The only real issues that I have personally had is understanding the LV rule and how it works in cover situations.
Apart from that, I try and make sure an opponent has read the rules at least or we spend a good 10 mins going over the special rules before the game. Afterall, who goes into a tornament game (not a friendly as these issues can be resolved over several games in that case), that allows the Nids without knowing your enemy?
Just because it is different does not make it confusing or broken. It just means that you have to think differently which I believe is the main gripe for most people that have an issue with the rules. Yes the wording needs to be cleaned up, and maybe some units looked at, yet the mechanics are sound.
PostPosted: Fri Jul 03, 2009 2:16 am
This is a bit of a brainstorm (probably should be listed elsewhere)but could the spawning system be simplified to a sort of pseudo-save roll for the whole formation/swarm and only effect broods(inc ravenors)?
e.g you have 8-12 termagants/hormagaunts/ravenors/gargoyles in the swarm with no save. your opponent does 7 casualties from shooting. you roll a d6 Swarm Save and you roll a 4. You get 4 termagants back.
You'd have a chance to get 6 back but you'd also have a chance to get 1 - them's the breaks when it comes to random dice rolling. It would still have the effect of "a rolling unstoppable swarming mass" but spawning would just happen immediately after shooting and it's one less end-phase roll to worry about... It also becomes one less thing for your opponent to be confused about as it's essentially a save roll and everyone knows how they function.
