Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 81 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
[OLD!] Tyranids v9.1
 Post subject: [OLD!] Tyranids v9.1
PostPosted: Tue Jan 20, 2009 2:55 pm
What parts of the french version are likely to make it into 9.2?
Having played 9.0 and 9.1 for a while, I have some comments about things that "feel" wrong.
Spawning adds little to the game as it is. The modifiers are so harsh that only swarms dedicated to defending your half of the table see any effect of it.
Hena commented in the f-erc thread about making it a Tyranid action. Perhaps Tyranid marshal could incorporate Spawn. Then it would be tactical rather than army-wide. The problem now is that once you need it, it will not be enough. If you do not need it, it is almost superfluous.
Another way to go at it, would be to purchase spawning from the start (like without numbers in 40K). It would be easier to factor in the costs of the army.
The uncommon broods are not uncommon anymore, more like on the verge of extinction. I find that decreasing the number in broods as well as inflicting the 2:1 ratio killed the bio-armoured vehicles.
There are still some Macro-weapon inconsistencies. I would rather that the concepts of Haruspex and Trygon would be switched. Haruspex could swathe through enemies (extra attacks) and Trygons have macro-weapons. I would find it more logical. I am also all for sniper attacks on Lictors.
Perhaps the independent/no-synapse ideas from the f-erc list could be incorporated. That would put pressure on Independent swarms being used to attack/contest rather than grab. It would also mean that synapse-free swarms can still attack, but not contest.
On the topic of the french list, I really liked Tyrants being inspiring and zoanthropes being leaders.
My bit of input,
Fredmans
Follow my Epic painting projects: Tyranids vs Steel Legion and Inquisition vs Lost and the Damned @
http://www.tacticalwargames.net/taccmd/viewtopic.php?f=7&t=14636
PostPosted: Tue Jan 20, 2009 3:02 pm
Sounds like they're actually getting rid of this, as they found the Tyranids had few swarms that could grab objectives in the later turns... I'm still thinking about it, as I think it reflects the Tyranid's alien outlook.
More to come soon.
PostPosted: Tue Jan 20, 2009 4:13 pm
Hey Chroma:
I've been reading and considering.  We, the FERC and the Taccomms development, actually have a lot of very similar ideas implemented in different fashion.
Starting with our special rules...
Swarms:  I like the flexible swarm system and the synapse range.  I realize it's occasionally problematic but it's also a strong flavor element.
Relentless:  I think this should be kept.  It's similar in game effect to the FERC Synapse rules with respect to keeping formations moving.
Expendable:  Your comments about the "token" BM were something I hadn't considered.  Perhaps the French "coming under fire" option is better in that respect.
Spawning:  I think this can go.
Flame Template:  Out.
From the French...
Unstoppable:  I have no issues with this for movement, though impassable should remain impassable.  I'm not sure about the restricted withdrawal move.  It could make swarms very vulnerable once they break and I'm not sure what it's supposed to add flavor-wise.
Synapse:  This is much simpler than synapse range as far as the number of words required to explain it, but in-game I would not expect it to be any easier.  Tracking different Initiative ratings as they change doesn't seem any less fiddly than checking range from Synapse.  Different objective claiming rules is of comparable complexity in both lists.
Supreme Commander:  This seems to be entirely for their BTS goal.  It's a workable option but I prefer ours.  Besides, their list could technically be fielded without a single Synapse Creature (like an Ork list without Nobz).  I'd generally avoid "if-then" rules based on force composition.
Meiotic Spores:  With their "spore chimney" as the on-board source of AA like Lionel proposed this is very much like the spore cloud system.  The difference is the AA range and the AA model stats.
Regeneration:  Absolutely not.  Way too much luck involved and feels terribly unfair to anyone not able to crush a WE in one turn.
Mycetic Spores:  I'm still a bit fuzzy on the FERC intent, so I'll withhold comment except to say that stylistically I'd like to see this as a feature of a theoretical future "Phase III" list.
Tunneler:  I like the idea of a Tunneler mechanic, but in our list the issue preventing its use is the synapse control - none of the tunnelers can bring in their own synapse.  There are a number of potential work-arounds for that, but I think it deserves a separate discussion.  There are too many things that its dependent on.
Units:
In general, the French units tend to be more shooty and more "bugzilla" in terms of power-per-unit.  I'd approach this with a large amount of care.
LV Synapse:  This is workable if you cut the synapse range/going to ground mechanic and/or if you allow more synapse  per swarm but otherwise it's a problem.  Options to "stack" synapse creatures and build groups could mitigate that somewhat.  Also, the question of unit type consistency with other similar size/genus needs to be addressed.
Zoa:  Based on 40K, I think this needs to be a Synapse Creature.  This might provide a potential middle ground between the people that would like to be able to build synapse groups and those that want them fixed.  The groups are fixed except for the option of adding Zoanthropes.
List structure:
The French system has some strengths.  The representation of Warriors as the near omnipresent tool of the hive mind is kind of neat once I got to looking at it.  It never hurts to put all those Nid Warrior models everyone has sitting around to work, either.
If the Swarm system is to be dumped, though, the Ork structure needs some tweaks.
First, there needs to be a horde discount, imho.  Otherwise, there is very little incentive to take larger swarms.  A popcorn list might not be a problem with respect to balance, but it is with respect to flavor.  Smaller swarms result in a more tactically flexible army, especially since you can easily have 2-3 BM-placing units in each.  Larger swarms need to be incentivized in some way.
Second, there should be some sort of division of common swarms and support swarms.  As the French list stands, it could be fielded without a single Synapse Creature and/or it could be fielded with a majority of elite units.  It might be that those uncharacteristic builds aren't really viable anyway but they should be restricted for flavor reasons.
All that said, I'd still rather look at ways to work with the Swarm system that could incorporate some of the benefits of the Ork template.
Edit:  Doh!  :vo  I just downloaded the last FERC revision and noticed Big/Uge discounts had been incorporated.
PostPosted: Tue Jan 20, 2009 7:32 pm
Quote: (Hena @ 20 Jan. 2009, 18:02 )
At the start of the game, the Tyranid player assigns Brood creatures to Synapse Groups, creating swarms. These swarms must be set up in legal formation using the instructions for the scenario. Additionally, Brood units must be placed within control range (15cm) of a Synapse creature from the swarm's Synapse Group. Brood units may also be held in reserve.
During the Action Phase, a synapse swarm is treated like a normal formation. However after the action, all the swarms brood creatures must be within control range of any synapse group or they are removed.
In the End Phase, after rallying and spawning (see below), synapse swarms are reorganized. Any Brood creatures out of control range are removed and any that are within control range of one Synapse Group become part of its synapse swarm. If any Brood creatures are within control range of two or more Synapse Groups then Tyranid player can choose which one they join. Note that Blast markers and broken status stay with synapse groups, not with any Brood creatures that change swarms; a swarm that has Blast markers equal to, or more than, units after these reorganizations immediately breaks.
That makes the entire situation simpler. Control range is checked at the end of action. I like the ability to combine swarms at end phase and don't want to give that up.
Sounds good to me. I used to think it was way too much text, but now that I've actually played it I realize it's quite easy to use.
Relentless: I'd prefer +2 to engage and +2 to rally with ini 2+.
Me too.
Spawning: I'd keep this. Many complain that it doesn't do enough. We could allow it to be used after every rally. This would mean that hold and marshall would do this as well. So taking a turn would allow Tyranids to really come back into fight. I have an alternative text to this one, if this sounds good.
That would be good, even though I'm happy with Spawning right now: a small but useful boost. Spawning after Marshall and Hold would indeed allow the Tyranids to compensate for their lack of shooting when they fail an activation.
Flame: I'd keep it, but I think I'm losing this one :sad:.
BP would work just as well, I think.
Move through cover: Perhaps we could use this. Depending on lenght of special rules after changes.
I like this rule. Tyranids AV and WE all have Walker so they rarely fail Dangerous Terrain tests anyway. This would certainly cut down on dice rolling.
Tunneler / Mycetic Spores: I would like something on these lines (though FERC tunneler is way too good). It would allow opening another front to Tyranids and help with "need to march across the board" syndrome.
Not too sure on this one. If these rules were to be implemented, I'd prefer to keep it on a very small level. I'd rather keep them for variant list, to be honest.
List structure: I'd actually try with allowing synapse and independent per two selection in common. This would remove two sets of % selection and leave only biotitans % selection there.
I like this. Biotitans could be something like 1 per 4 common broods (or 6 or 8, I don't know).
Expendable vs no BM on being fired: I don't like the no BM on being fired as it is better for batter save units. This change makes common brood merely bonus for enemy. Combining the two would be too good.
I really like the Expendable rule. I'd just make it so that Expendable units do NOT count as casualties in assault, as right now common broods are so fragile the generate a huge differential in favour of the opponent (see my batrep for multiple examples of 'nids losing assaults by huge margins... vs. Terminators mostly, but even the 3rd turn assault of my big Attack swarm against mere Vindicators was actually only won by 2 because I had lost a few common broods).
PostPosted: Thu Jan 29, 2009 7:14 pm
I'll copy & paste here some comments from my latest battle report concerning some of the suggested modifications to V9.1.
- 20 cm move for Warriors > This is great. No longer do the Warriors slow down their swarm. Please, pretty please, implement this in the next version as it really helps those poor infantry swarms.
- Lictors with Sniper > never really used, they only engaged the Rough Riders and the Sniper ability didn't make any difference. But I think it's better than MW.
- Hormagaunts with 2xCC5+ > This is OK. I still think First Strike would help them and the infantry swarms a lot, but I can live without it. Would 2xCC5+, FS and +25pts for 4 Hormagaunts be too much?
- All units ignore difficult terrain > Love it. I quickly lost count of the number of difficult terrain tests I should have made without this rule.
- +2 to Engage > This felt right. Tyranids can finally do the only thing they are good at without fear of failing the activation (unless you retain and have BMs, but that's perfectly normal).
- +2 to rally rolls > This felt good, perhaps a little too good even. I think it's OK to see Tyranids rally easily, they should, but I may be biased. +2 puts them just above Marines in terms of rallying. +1 is just like Marines. Personally, I'd go for +2.
- "Disposable Gaunts" > I would make Gaunts (or even Common Broods) count only half their losses in assault in order to give a chance to all-infantry formations (or armies, for that matter). Right now they just don't stand the comparison to the big 'nid units (Bio-titans & co.).
- +25 points to Hierophant > It's really, really good and feels a bit cheap at 275 pts. It's faster than most units, it's very resilient, it's shooty (for 'nids anyway) and very strong in assault.
Users browsing this forum: No registered users and 70 guests
