Post new topic Reply to topic  [ 89 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
[Lists] Proposed Tyranid Armylist WIP
 Post subject: [Lists] Proposed Tyranid Armylist WIP
PostPosted: Sat Nov 19, 2005 2:09 pm
Currently I regard the stats for termis and hormis as perfect, but I think raveners need some work to give them a distinctive balanced role.
Hena is right - why would you spawn a hormi when you could have a ravener (apart from the LV problem....) i would like to see some sort of differentiation here. It is curious that raveners (based on warrrior genus whereas all other commons are gaunt genus) are still classed as common brood creatures. Something not quite right there I think.
PostPosted: Sat Nov 19, 2005 2:24 pm
Quote (Markconz @ 19 Nov. 2005 (13:09))
I think it's purely a game/model effect as the original thought was that forcing 25% in Hormagaunts, Gargoyles, and Termagants was too prohibitive (in the 3.0 lists, all the other sections were *max* 25%, so you really needed a lot of Commons.) so there was a need for a more expensive Common.
Could the solution to the horde/ravener issue be to bump them up to Uncommon Brood? ?I've used, at most, nine Raveners in 2500-2700 points, I could fill that space with Gargoyles easily enough.
Thoughts?
PostPosted: Sat Nov 19, 2005 2:44 pm
Quote (Chroma @ 19 Nov. 2005 (13:03))
Termagants have shorter ranged, but more effective, weapons than Guardsmen, so I think FF5+ represents this well.  Technically devourers and spinefists (and various other bio-morphs, I see "toxin sacs" on them all the time!) could be in there too.  I know everyone thinks of Termagants as the Grots of the Tyranids, but, really, they're the basic Tyranid trooper, like a Guardsman or Ork Boy, and should have some decent stats for the points.
Agreed. Termagaunt FF5+ fits. The effect of fleshborers compensating for shorter range compared to IG troopers has nice symmetry.
Also not sure how good termagaunts would be compared to hormagaunts with FF6+. Only case where termies would be of any good would be when enemy assaults them(and albeit at that point hormies suffer without FF value).
Keep termagaunts as it is. They should be appealing enough to take as, afterall, they ARE what could be considered as most core like unit of tyranids. Definetly not just cannonfodder for better units.
www.tneva.net
PostPosted: Sat Nov 19, 2005 5:17 pm
Quote (Hena @ 19 Nov. 2005 (14:42))
Well... I do like the idea that I can make my infantry hordes with common brood. Then the uncommon brings in the heavier stuff like exocrines, haruspexes and carnies. So in that sense the ravener do belong to common.
Raveners are also good if you want to mirror the 40k "godzilla" army like I have been threatening my friend of doing  :)  In the 40k version you have Ripper Swarms, 6 Carnifex, and two Hive Tyrants.  In the Epic version, I built it with Raveners (since they are the biggest common), AV's, and War Engines...  just a silly 2 cents  :)
PostPosted: Mon Nov 21, 2005 9:31 pm
yeah, I'm definatley for gargoyles only in a Harridan... fits with the Forgeworld stuff pretty good.
PostPosted: Mon Nov 21, 2005 9:35 pm
Quote (Hena @ 21 Nov. 2005 (18:11))
Also I would like to change the transport capasity of Harridan (probably not vituperator to give them differentiation as well) to gargoyles only.
Agreed. Maybe transport 6?
PostPosted: Mon Nov 21, 2005 10:26 pm
Quote (2.0 @ 21 Nov. 2005 (20:31))
What is the Forge World fluff on Harridan's transport ability?  Has anyone seen the latest update for it?
PostPosted: Tue Nov 22, 2005 5:28 am
pretty much just has pods, chutes, nests, whatever word I'm looking for that house Gargoyles on it's underbelly, transports an ungodly amount of gargoyles underneath it.
PostPosted: Tue Nov 22, 2005 6:29 pm
Contrary to previous experience, myraid flights of Harridans carrying Gaunts, Tyranid Warriors and Hive
Tyrants instead of Gargoyles both surprised and overwhelmed the defenders of Espandor in a battle that led to the fall of
Eclesiarchy headquarters on the cardinal world of Espandor.
Where does the above quote, taken from the Harridan flavour text, come from?
PostPosted: Tue Nov 22, 2005 6:53 pm
Hi Chroma,
I wrote that when I started adding color to the text.
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Tue Nov 22, 2005 7:04 pm
Quote (MaksimSmelchak @ 22 Nov. 2005 (17:53))
I like the colour!  Do you have any other reference to Harridans transporting more than Gargoyles handy?
PostPosted: Sat Nov 26, 2005 10:52 am
I thought you would limit spawning to Marshal actions. So you still are able to spawn when failed Initiative?
Cheers!
Steele
Quid pro Quo
