Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3, 4  Next
[Tyranid Special Rules] Breakdown
 Post subject: Re: [Tyranid Special Rules] Breakdown
PostPosted: Thu Nov 10, 2011 2:38 am
It look good to me. At first it seemed a bit overly wordy, but if Expendable and Tunneller become new generic special rules then the remaining amount is fine.
I say some playtests should be got in before pre-judging the list too much.
Question - if a tyranid BTS formation absorbs a smaller formation and then gets shot up with all the original formation's units dying but some absorbed ones surviving, does the enemy then get BTS or not?
Second question - can you only swarm units that have already died or can you bring spare termagants, ect over and above what you have in the list to spawn during the game? I believe up until now the former was the case, but the current rules are written in such a way that the latter seems to be possible.
PostPosted: Thu Nov 10, 2011 5:17 am
Dave, just a bit of query...
Is it possible to remove the "brood" wording/idea and just give swarming to infantry? That way you would only need to mention in the data sheets of say the genestealers/Warriors etc "may not swarm. It would make the issue slightly less wordy. Of course it doesn't deal with the fact you have limited what brood units' brood points are but is that adjustable any other way?
PostPosted: Thu Nov 10, 2011 9:34 am
Merging formations seems never worth doing, because your formations are likely going to be rallying from broken on a 1+ anyway, so why lose that?
PostPosted: Thu Nov 10, 2011 9:46 am
Agreed, if they are not going to disappear, why lose an activation. (Unless you need the numbers for a big engagment or stringing out.)
PostPosted: Thu Nov 10, 2011 9:52 am
You also lose the entire formation for VP purposes. Worth doing in maybe 5% of games.
PostPosted: Thu Nov 10, 2011 9:56 am
well, a synapseless swarm is 3+, and no longer ignores the -2 for broken, which means that its very unlikely to rally
PostPosted: Thu Nov 10, 2011 10:03 am
A 5+ to rally is a fairly average rally roll, really.
IG and Orks have to roll those kinds of numbers all the time.
PostPosted: Thu Nov 10, 2011 10:06 am
well, its likely to be 6+ cause nids are fairly 'in your face' with their movements (while ig can sit back and shoot)
and in any case, 5+ is a marked difference to the 1+ you where talking about mere moments ago.
PostPosted: Thu Nov 10, 2011 10:10 am
It's still not worth losing a potential activation 95% of the time. Just back the unit off when it breaks (easy, as 'nids mostly move 20cm), and roll to rally on a 5+.
PostPosted: Thu Nov 10, 2011 10:15 am
its never worth it if the unit being absorbed is BTS
however, if the unit doing the absorbsion is the BTS though, it will be useful to keep it alive
i see it being potentially useful in certain situations, especially since a synapseless nid formation, even once rallied, is pretty rubbish.
PostPosted: Thu Nov 10, 2011 10:28 am
I don't think the rules should be written so that they are "less wordy". Having the Brood keyword allows very clear rules for what gets to reswarm and what doesn't. Taking the "how hard is it to explain to the opponent test", you may cut down some words, but you gain nothing when explaining it.
PostPosted: Thu Nov 10, 2011 11:36 am
I can see some situations where absorbing would be worthwhile, but probably not enough to justify its inclusion.
What if a synapse formation absorbs a broken formation? What happens then?
PostPosted: Thu Nov 10, 2011 11:40 am
RAW the formation would inherit the broken formations Blastmarkers = 1 BM per unit. As the absorbing formationis the leading formation and has fewer BMs than units it would remain unbroken. The absobing formation's status won't change.
PostPosted: Thu Nov 10, 2011 11:45 am
Broken formations don't actually have blast markers though, and I don't like the ability to autorally units by absorbing them.
PostPosted: Thu Nov 10, 2011 11:47 am
So you are saying that you think rallying should be carried out first followed by absorbing. Rule does not make this clear at the moment, but that is also the way I'd interpretate it.
