Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 140 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 10  Next
[OLD] Tyranids v9.2!
 Post subject: [OLD] Tyranids v9.2!
PostPosted: Sun Feb 22, 2009 4:17 pm
Quote: (Hena @ 22 Feb. 2009, 15:14 )
Screamer Killer carnifex has bio plasma attack.
Techincally... bio plasma is a "hand-to-hand" attack these days... *laugh*
So, with Lictors so emasculated, do you think the 0-2 limit could/should be taken off of them?
PostPosted: Sun Feb 22, 2009 5:34 pm
Despite the instant gut reaction that LV means certain death, I think it may be an overreaction, and I feel it could result in some new swarm builds. I will try them next month against the stock 3 armies - marines, orks and guards.
Some positive feedback(ie non-nerfs): +5 cm move for the assault spawns. Finally! Throw them in with warriors and they will move faster and soak up a lot of AT fire. These are very resilient.
The reduction of gaunts to 75/3 means more points can spill over to uncommon broods, making more of them viable.
Some other remarks:
If Tyranid warriors should prove (by playtesting) to be too vulnerable, why not add the option of taking 0-3 extra tyranid warriors (instead of reverting back to INF status)?
Would 25cm move on hydraphant increase its viability? It is strictly CC, and as far as my models go, have longer legs than Hierophants ;)
Oh, and why 100 for 3 gargoyles? They cost 25 in independent swarms, and received no boost. 75 would be more logical, or were they overpowered?
The possibility of the uncommon zoanthrope cluster seems a little bit weird. Are they meant to be spammed, or is it an error?
/fredmans
Follow my Epic painting projects: Tyranids vs Steel Legion and Inquisition vs Lost and the Damned @
http://www.tacticalwargames.net/taccmd/viewtopic.php?f=7&t=14636
PostPosted: Sun Feb 22, 2009 5:39 pm
OOPS!  There should be no "Zoanthrope Cluster" as they now come out of Synapse!
PostPosted: Sun Feb 22, 2009 6:48 pm
Also, should not the Vituperator be able to carry zoanthropes, given their new status? I see no reason as to why not.
/Fredmans
PostPosted: Mon Feb 23, 2009 11:53 am
Hi Chroma,
thanks for the new version. New things to try out!  :laugh:
Xenopsychology - Tyranid Swarms
-two types of Swarms, Independent and Synapse.
-"control range" checked in the End Phase (this needs *HEAVY* testing!)
Xenopsychology - Relentless
-base Initiative rating of 2+ with a +2 for Engages and Rally tests.
Xenopyschology - Expendable
-only in effect if Synapse creatures are present
I just love all of this. Good call IMO.
Xenobiology - Spawning
-simplified spawning costs:
Code Sample:
Infantry Unit 1 Spawning Point
Light Vehicle Unit   2 Spawning Points
Armoured Vehicle Unit 3 Spawning Points
War Engine Unit 3 Spawning Points/1DC
-spawning allowed after Regroup or Rally
Spawning after regroup or rally is nice, but you've effectively made Hierodules Brood (9) instead of (6) and Trygons Brood (6) instead of (4). I don't understand why.
Xenobiology - Mobility
-Tyranid AVs ignore dangerous terrain
-Tyranid LVs move as infantry, "Heavy Infantry" in effect
Tunnelling
-added from the rulebook
Rules Removed:
-Flamer Template... sorry Hena! Converted to short-ranged BP weapons.
Again, that's great.
Unit Changes:
-Tyranid Warriors move 20cm
Happy me. :))
-Lictors, Raveners, and Tyranid Warriors are now LVs
-Zoanthropes are now leader Synapse addition
Well, it seems this change hasn't been well received, but I rather like it. Zoanthropes now have a real function (being Leaders AND acting as bodyguards for TW), and the LV status encourages mixed swarms instead of "all-Infantry" or "all-AV" swarms.
Sure it make TW more fragile, but only if you're careless in your swarm composition. For 205 points, 3 TW + 3 Zoanthropes feels like a durable synapse group, particularly if you add some Raveners and/or some assault spawn in your swarm. Maybe I'm wrong and it makes them too fragile, but I'll certainly try it.  :)
-Harridan is no longer Synapse, becomes an Independent war engine
I wasn't too sold on this one, but it's slowly growing on me.
-Raveners and Hormagaunts get +1 Extra Attack
Excellent. Nice to see the Hormagaunts get an extra attack AND First Strike.
-Gaunts count as half, rounded down, in combat resolution
Hopefully this will solve the problem of the inefficient Gaunts.
-other minor tweaks and changes
I'm a bit sad to see the Dactylis get a 20cm speed (no more Garrison), but I guess it was a bit odd to see it act as a scouting unit, garrisoned at the forefront of the army. +5cm for Haruspex and Malefactor is very nice, though.
Army List Changes
-added Subterranean and Harrassment Swarm to Independent Swarms
Looks good on paper, I'll certainly try it.
-merged Assault and Nexus Synapse Groups, Hive Tyrant as "upgrade" replacing one Warrior unit
-added "0-3 Zoanthropes" upgrade to Synapse Groups
Good.
-changed Common Clutches to 3 units per Clutch
Gargoyles have received no boost so they should NOT cost 100 points for 3. 75 pts for 3 would be much better.
My initial reaction to seeing 3 Gaunts for 100 points was:  :sigh:. But the more I think about it, the more I think you may be right. Both Gaunts have received a boost so the points increase is justified, at least for the Hormagaunts (+1EA, First Strike AND count as half in assault). The Termagants feel a bit overpriced right now, but playtesting will tell, I guess.
Also, it's good to remember that, while several changes feel like nerfs, Tyranids got a huge boost with the +2 to Engage and Rally!
PostPosted: Mon Feb 23, 2009 12:42 pm
Here are some comments and impressions on your list, Chroma.
I support most of the comments already made. Especially the +1D3 spawn bonus for 30 cm proximity. I think you can explain it just as good as you could explain the opposite. There are always hordes of little buggers running around. As single creatures, they are hard to spot when lurking in the grass or hard to aim at when running around erraticly. Soldiers probably won't waste time and ammo on them unless they become an actual threat (since the REAL swarm will soon arrive). The hive mind does not care much about the roaming buggers and keeps them on a long leash. However, once the enemy draws near, the synapse creatures tighten that leash, drawing the free roamers closer and putting them under direct control to strengthen the swarm in the face of the enemy. The swarm appears to grow while closing in. That is how I see the spawn bonus at enemy proximity.
It is weird that large infantry swarms will probably be as slow as ever despite that the Warriors' speed was raised to 20 cm: Since they are LVs now, you want to protect them by having around half the swarm being LV or AV. You provide some means to do so by adding the Zoanthrope option to the Synapse selection, but Zoanthropes as well as Carnifex have only a speed of 15. Therefore the problem of some creatures slowing the Gaunt swarm down still exists. (Please note that I do NOT advise you to raise the Zoanthropes' and the Carnifex' speed! It's fine at 15 cm.)
I'm not sure about the Mobility special rule. On the one hand, adding another army specific special rule is a bad thing. On the other, Walker can be dropped from over a dozen unit entries. Jury is still out on this.
The names for Scything Talons / Slashing Claws are applied inconsistently. This is most likely an oversight. Raveners and Tyranid Warriors have Scything Talons for EA+1, others have them for EA+1 MW. You probably meant Slashing Claws for the Raveners and Tyranid Warriors.
Finally, a personal crusade of mine is to change „You may purchase one Uncommon Brood Group for every two Common Brood Groups included in the army.“ on the Uncommon Brood Groups to „Up to one Uncommon Brood Group may be taken for every Common Brood Groups included in the army.“. This is the formulation used for other armies like Steel Legion or Eldar and I like to keep things consistent. This would mean of course that the numbers on the Common Broods have to be raised. I thought doubling them to 8 was to much and would have raised them to 6. This is now incidentally the doubled amount of the current brood group size. Since the Infantry broods have lost their appeal due to Warriors becoming LVs, I would lower their cost a bit despite the new „half casualties in combat resolution“-rule. Raveners on the other hand are quite useful now as „Synapse protectors“.
I would propose:
6 Gargoyles for 150 pts
6 Gaunts for 100 pts
6 Raveners for 200 pts
Gargoyles cost more than Gaunts, but not 200 pts. They gain mobility and AA, but lose the „half casualties in combat resolution“-rule. They now cost as much as the Gargoyles purchased with the Harridan. They should not cost much more, because they can't protect Synapse.
Gaunts are cheep. Yes. They should be. The new „half casualties in combat resolution“-rule is great, but they can't protect Warriors from incoming fire any more. Their low price makes them still a viable option.
Raveners are the only group where I would double the price. It seems quite right. They are expensive, but the only common „Synapse protectors“. Also, they are capable fighters.
A nice side effect with that costing is that it scales well. It helps the player filling his last few hundred points. (Granted, your list makes it easy as well...)
Otherwise, I like most of the changes. The Harrassment and Subterranean Swarms are great ideas!
PostPosted: Mon Feb 23, 2009 4:14 pm
Had a battle with 9.2 over the weekend, unfortunately I didn't realize Warriors were LVs until after the game and we played on a 8x6 board. So I'll try for an official report this week.
Initial Thoughts:
Control Range check clears things up, but does give the bugs a bump.
+2 to Engage and Rally seemed too much to be back in 9.0, I've found +1 to be perfectly fine in all my 9.1 battles. Since were back again, I'll pull out my old suggestion of instead of a +2 to rally, just ignore the -2 of being broken.
Expendable re-work is good, I do agree with Hena's edit. We need something in there that ties Expendible with Brood. I spent a few minutes trying to put the connection together myself before the game.
Spawning after regroup will be interesting. I think it goes a way towards solving Hena's problem with not being able to do anything helpful with the bugs when they have to take a hold action. I noticed during my game though that my spawn pool was much shallower than normal. This will need some testing.
Mobility I think is a flavorful change, thanks FERC.
Tunneling units sounds fun. However I suggest making the core unit Trygons and adding Raveners as upgrades for the simple reason of what's readily available model wise. I have Trygons, in order to tunnel them I have to convert Raveners. Fluffwise, the Trygons are digging the holes, aren't they? The Raveners are just following them.
Unit changes, these and the Relentless change are where I see the biggest problems. The two chief among them being the Warrior change and the Gaunt 1/2 casualties change. Also, where'd the FS on the Hormagaunts come from? 2 at 5+ seemed like a fair trade off with a points increase.
The Gaunts change is really messing with assault core mechanics. I haven't had issue winning assaults with all Guant assault swarms, like everything it just takes some practice and some prepping. This is the thing that got the most criticism from my opponents on Saturday.
Finally, on the army list changes. I'd suggest 100 points for 4 Gaunts rather than 75 for 3. Math made easier in my opinion.
Thanks for the Heirodule step rather than the Hydraphant step.
PostPosted: Tue Feb 24, 2009 10:11 am
Quote: (Jeridian @ 22 Feb. 2009, 13:30 )
Bio-Artillery Cluster 2xDactylis. Brood 150
Speed 20cm- so can no longer garrison, so weapon range is suspect. They where a so-so choice for me before, now they serve no purpose. Gone.
Well, they can always garrison with the Synapse node, which I believe is the best option for them anyway providing both Leader and WE cover.
By the way, is the Broodlord cap gone?
/Fredmans
PostPosted: Tue Feb 24, 2009 3:16 pm
Yep, no more 0-1 per army. Just a max of 1 per swarm.
PostPosted: Tue Feb 24, 2009 3:47 pm
Yeah, the Broodlord is not the "Patriarch" anymore... just a super-'Stealer... the Tyranid Codex speaks of mulitple 'Stealer swarms led by Broodlords.
PostPosted: Tue Feb 24, 2009 4:41 pm
I'll be playtesting these guys on sunday.
MoK's Painting Blog
Now Showing:
PostPosted: Tue Feb 24, 2009 4:48 pm
Are you staying in Mansfield now MoK? Or do you have a local game arranged?
