Post new topic Reply to topic  [ 106 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 8  Next
Some questions on the units in the 8.4 rules...
 Post subject: Some questions on the units in the 8.4 rules...
PostPosted: Sun Oct 28, 2007 7:40 pm
I think that is represented pathetically in Epic, with a Carnifex with nothing but a 3+ save.  Compare that to those same vehicles that have a 4+ RA.  Completely backwards from 40k, to be sure.
Their offensive power is lackluster as well.  I have YET to see ANY Armored Target survive an Assault from a Carnifex (S10, 2d6 AP per attack), yet fully half the hits are saved by typical armored targets in Epic.  A single MW attack does not do them justice.
But, all of that said, I think the Carnifex is appropriately done in the Epic list, purely from a standpoint of game-balance.  But don't kid yourself...they definitely don't match their fluff OR their abilities in 40k.
I think 4+ RA could go a ways towards balancing carnifexes (They're rubbish in Epic right now).
2)  +2 on any Cover Save they make, Always counts as being in Cover even if in the open (-1 to hit, 5+ Cover Save)
But even THAT doesn't work as well as it should, because in Epic, unlike in 40k, MW shots IGNORE cover saves, as opposed to only GETTING a save vs such weapons if you are in cover.  Goofy.  And just another example of how you shouldn't get too locked into the mindset of how everything must be a direct conversion from 40k or Fluff to Epic.
Worth bearing in mind, but I think it could be a better mechanic than simply raising their save to 4+ RA.
PostPosted: Sun Oct 28, 2007 7:41 pm
(Dave @ Oct. 28 2007,14:29)
(Kagetora @ Oct. 24 2007,18:50)
Give Gargoyles a 30cm AA 3+ attack that, if it hits, you remove the Gargoyle stand. ?25 points and a possiblity of a Brood 2 re-spawn seems VERY appropriate cost-wise for a 3+ hit that armor/jink saves are allowed against.
So for 25 additional points you can give your Termegants jump packs and a 3+ AA attack? I don't see anything very appropriate cost-wise about that, sorry. That would instantly make them the best AA in the game I think...
Try that with your opponents throughout the campaign, and then have them post comments on it here.
Ok, explain to me how the following is the best AA in the game:
I pay 25 points every time I cause a hit, and for that hit, I recieve a Blast Marker, AND lose a Unit from the Formation.  I can get that Unit back, but it costs double the Brood Points of any comparable Unit.
Not to mention that the Aircraft eithe get an Armor Save, or a Jink Save (even for free after their attack run).
Additionally, using my AA prevents me from advancing my Tyranid Swarm at March Speed.
And you think that somehow compares to MW5+ AA on every Feral Ork unit, 6xAA4+ for a group of Firestorms, or a bazillion shots at AA6+ from dirt-cheap Ork Flawagons?  Please.  Not to mention most lists can have their own Aircraft on CAP and also have incidental AA fire from some units.
No, I think that would be pretty far from the best AA in the game.  Pretty far indeed.
You are correct, however, in assuming it may not be the best solution.  I never said it was...it was merely a suggestion I thought would be cool "fluff-wise."
In fact, the more I think about it, the more I am coming to believe that Tyranid AA is functioning like it should...that is to say, the advance assaulting swarms essentially leave the AA envelope when they attack.  I just really think the AA enevlope in the rear (i.e. the Mieotic Spores) should be better able to do their job.  They should be a bit cheaper, limited in number to avoid Junk Activations, and be able to spread out a bit.
I'd like to see them be 100 points for 6, 0-2 in the list, and have Scout.  Let them sit over the top of the Synapse Node/Dactylis groups and protect them from air power, but don't charge an arm and a leg for it.
And I'd be perfectly happy to see Gargoyles lose AA ability at all, or just keep their 6+.
You guys have mostly changed my mind on this issue.  At least until AFTER I get blown to smithereens by Air Power in the upcoming Campaign.  At that point, I'll probably start pushing for better AA again.   :D
PostPosted: Sun Oct 28, 2007 7:44 pm
They are limited in number already because they eat into your independent budget.
No need to go placing 0-x limits in as well, lest we end up with something like the Black Legion list (Which has too many overpowered unit types constrained by clunky 0-x limits).
Lose it. Lose it. Lose it.  :D
PostPosted: Sun Oct 28, 2007 8:21 pm
@Kagetora: You compared the Lictors to Tyranid Warriors. But bear in mind that the stats for the Lictor represent one single Lictor while the stats for the Tyranid Warriors represent a unit of three Tyranid Warriors.
Apart from this i totally agree on your perception how Lictors have to work.
PostPosted: Sun Oct 28, 2007 8:30 pm
Blacklegion: Not really, Lictors are covered under the 'large tyranid infantry' special rule*Yep another  special rule!*, which allows them to be based singly. Tyranid warriors are also listed in this special rule.
Thus, most people base their warriors in threes as they have lots of them, but they base their lictors singly when technically they should also be based 3-7 like other infantry.
PostPosted: Sun Oct 28, 2007 8:41 pm
Ah ok. But this is strange, becaus ein Wh40k Tyranid Warriors always walk in units of 3-9 Warriors and never alone, where Lictiors are purchased 0-3 as a single (and only) entry but operate alone.
PostPosted: Sun Oct 28, 2007 8:43 pm
Operating alone in a W40k game just means they are in a single formation with the scouts special rule in Epic. :D
PostPosted: Sun Oct 28, 2007 8:59 pm
Yes it is :)
So Tyranid Warriors have their own version of Scout because the individual models of the unit are dispersed up to 5cm from each other? :D
Then you should allow up to 9 stands of Tyranid Warriors per swarm, because Tyranid Warrior broods can be 3-9 models. :)
PostPosted: Sun Oct 28, 2007 9:06 pm
I tend to ignore the 'large tyranid infantry' rule as just another example of the lack of models amongst playtesters influencing the army list's development.
As in I literally ignore the rule, and base my 'large' infantry 3 to a base, as is allowed in the standard rules.
PostPosted: Sun Oct 28, 2007 9:28 pm
(Hena @ Oct. 28 2007,20:12)
I would think that it's also because all older Tyranid players have Lictors based singly :).
They are foolish and weak.
PostPosted: Sun Oct 28, 2007 9:30 pm
I would have no problem with Lictors being Light Vehilces but a fitting armour value. Then all Tyranids should ignore Dangerous Terrain tests too :) They are living vehicles. They are born to fit all types of terrain.
PostPosted: Sun Oct 28, 2007 9:45 pm
Actually that's a good point.
Any Tyranid that doesn't already have the walker special rule should immediately gain it.
PostPosted: Sun Oct 28, 2007 9:56 pm
Not walker. They shouldn't have to roll for dangerous terrain at all. All Tyranids should treat terrain as if they where Infantry for movement purposes, but AV, LV and WE don't gain cover saves.
PostPosted: Sun Oct 28, 2007 9:57 pm
That's against the Tyranid background, where they make maximum use of camouflage and terrain.
