Post new topic Reply to topic  [ 100 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
Zoanthropes & Spore Mines
 Post subject: Zoanthropes & Spore Mines
PostPosted: Fri Mar 30, 2007 1:48 pm
For zoanthrope how about just 5+ MW, FF5+ MW?  As you say in 40k they can blast through armour nicely (if they hit which is usually the problem...). (BTW remember that the template is blast not ordinance, which makes it unlikely it will kill more than 1-2 models (unless they are clumped due to teleporting or something).)
I'd go with an AP attack at range because the S5 attack is longer-ranged than the S10 attack.
Spores come 2 frag, 2 acid, 2 toxin to a pack...
Not if you know which pack to purchase...
PostPosted: Fri Mar 30, 2007 2:25 pm
I think those are both pretty good ideas, but standardize the ranges.
I like the MWFF5+, 30cm AP4+ for the Zoa.
The trick with the spores will be balancing them because they're just a bit weird.
How would you handle unit type and movement?  Should AT fire be able to set off the chain reaction (so they are LVs)?  Dangerous terrain?  LoS issues?  Surely the idea of cover mods and terrain saves for balloons high enough to foul aircraft is odd?
In short, it seems you're still into special rules unless you want your balloons taking cover behind buildings.
At 5cm move, they would always move cautiously, so I suppose dangerous terrain is not a big deal.  After all, it's always possible that the tails would get fouled in tree branches or on building spires and such.  A 1/36 chance of them being rendered ineffective doesn't seem unreasonable.
PostPosted: Fri Mar 30, 2007 2:32 pm
Seems perfect to me.
I'd make them LV's.
As the LOS issues, I hadn't thought of that.
I can't see a way around it without a 'note'.
However, it would just be one note, rather than the whole bunch of special rules that the DTT-type Spores entail.
PostPosted: Fri Mar 30, 2007 2:40 pm
(Evil and Chaos @ Mar. 30 2007,14:32)
Well, the "Support Craft" rule would seem to be appropriate in this case... *laugh*  If only it was a "general" rule.
And I do like the way the Zoanthrope discussion is going.
PostPosted: Fri Mar 30, 2007 2:48 pm
(Chroma @ Mar. 30 2007,14:40)
I 100% agree with that.
PostPosted: Fri Mar 30, 2007 3:07 pm
Ok will test these on Sunday, hurray up and sort the spores out by then, and remember I'm 12 hours ahead of you guys... :)
Re Spores - hey you can't even buy mixed packs anymore!! :O
PostPosted: Fri Mar 30, 2007 3:08 pm
Wouldn't spore mines have a pretty good CC as well?  After all, they are intended to spew caustic material over a huge area when they die/explode.  Hacking them with chainswords would seem to be an extraordinarily dangerous activity...
LV, 5cm, 5+ (due to size?), 4+, 6+
15cm AA6+
Small Arms Ignore Cover
Notes:  Always has LoS to everything on the board and vice versa
Independent Brood, 6 for 125?
(fairly expensive for what they do but still a very cheap activation)
PostPosted: Fri Mar 30, 2007 3:17 pm
(nealhunt @ Mar. 30 2007,14:08)
Lol, good point.
Only concern with that LOS thing and those stats is that those sure are easy targets...
PostPosted: Fri Mar 30, 2007 3:21 pm
Aye, CC 4+ seems sensible, as does armour save 5+.
In other words, I agree. :)
PostPosted: Fri Mar 30, 2007 3:29 pm
(Markconz @ Mar. 30 2007,15:17)
That's the thing, they *are* easy targets... and they tend to chain react when heavily targeted.
And if an opponent is wasting activations to take them out, well, then other stuff isn't getting shot at.  *laugh*
I'm still not 100% convinced to this approach, but I would like to see some playtesting of it.
And, if not "Support Craft", shouldn't they be skimmer?
PostPosted: Fri Mar 30, 2007 3:30 pm
With 6 of them, I'd guess the normal distribution would be something like:
--*-5cm-*-5cm-*--
~4cm gap
------*5cm-*-5cm-*
Staggered and spread, that covers an area roughly 45x35cm.  At 3 casualties, it's still 40x25cm.  It takes reducing them below 3 units to significantly impact their coverage, which is modest to begin with.  With a 5+ save, that means 4-5 hits.
Why would most people bother?  The payoff on firing at them is not good.  The only way to really sweep them off the board would be assaults.
I think the biggest problem would be striking a balance between cheap activations and their modest coverage area.
PostPosted: Sat Mar 31, 2007 1:24 pm
I love ideas of spores as AA units (like I said here),
so I'll test play it if balanced data born from this topic.
About  the Zoanthrope...
I have no idea how powerful their attacks should be.
But anyone have an opinion about they may be Synapse Creature in 40k game?
Synapse Zoans are sometimes important in 40k.
I imagine it may be characterize them in epic.
(For example, zoans counts as synapse creatures when measuring 15cm synapse range only, no respawn ability etc?)
Oh but it needs new special rule... may be bad idea :confuse:
