Synapse Coherency Repair Thread
 Post subject: Synapse Coherency Repair Thread
PostPosted: Fri May 05, 2006 6:24 pm
Quote (Hena @ 05 May 2006 (18:22))
I'm don't understand the reason for not changing the swarm. If the rule is based on the fact that the brood will continue charging after the enemy as the synapse is not there. Then why does this happen when there infact is synapse? It does not make any sense.
I think the main reason is to prevent any kind of "leap-frogging", such as: "I'll use these Raveners to engage here... then move them to this other Swarm and engage again..."
PostPosted: Fri May 05, 2006 6:34 pm
Hena,
Its all hypothetical and is fiction. Its really down to Jaldon's vision...
That said, you can justify anything.
First, there's 1.40 which establishes SWARM is determined at the beginning of a turn. Don't leave your swarm coherency.
Exception is that: if you want to leave it - here's a very special circumstance, but you better get back in coherency within the parameters given - lest you run off into no mans land.
Third, this is representative of lots of stuff happening simultaneously. Thus - a snapshot (beginning of turn) is used to determine Swarms. Everything in the course of a turn must remain within a given Synapse's control to reflect the relative influences of actions for that slice of time - i.e. turn.
So the easiest thing to do is to say - you can't leave synapse control - period within a turn. The exception shouldn't necessarily afford further exceptions lest you create a chain of exceptions from within the rules.
In Jaldon's defense, what he's afforded the tyranid player is a manner in which bugs become fluid but only determined from a specific point in time - beginning of turn. He then affords an exception for tactical flexability. He puts constraints on that exception by forcing the player to get back into Swarm formation lest there be a penalty for not doing so. Perhaps this is a mechanism to keep the player from blindly over extending himself. Thus the exception must be used wisely.
If he was to further offer another exeception for a bug player to use another synapse groups control, he's essentially eleviating the penalty for over extending.
If you are looking for just a fluff reason to make 'fictional' sense of it all...
What if the 'fleeing' enemy (that the 'rogue bug' is chasing off) sees a really large bug formation "over there" and decides that he's not going to run that way into more danger... instead, he runs off into the wild blue horizon... and so followed the mindless bugs whom which have lost synapse control as they follow in pursuit.
Thus, Jaldon says - this is "represented" by bugs that don't get back into coherency with the originating Swarm's Synapse Coherency.
Very justifiable and reasonable to me - *if* that's his vision.
Rob
PostPosted: Fri May 05, 2006 11:10 pm
And simple brood creatures such as myself will follow (almost) mindlessly where the magus will lead
LOL, well, I'm sure Jaldon will shed some light on the path ahead soon enough.
Cheers, :)
Rob
PostPosted: Sat May 06, 2006 3:13 am
"The mind is like a mirror that reflects all that it experiences and collects it for the one whom holds it."
Reply
"You cannot hold onto anything. You don't experience things, things happen. The mind isn't a mirror that reflects anything. And the only thing a mirror collects is dust."
Reply
"You can't have some light, it is either present or not. You can't shed light, you either have it or you don't. Nothing can ever happen soon, it always happens exactly when it happens. And there is no path ahead only a big sign that says YOU ARE HERE."
 :o0
But seriously......................... :D
Here is a re-write of what you wrote Tactica.
(1)The only exception to this is when a swarm is carrying out an Engage Action.(1)
(2) During the Engage Action all of a swarm's brood creature units can move out of both synapse coherency and normal coherency of the swarm's synapse creature group, however these same brood creature units must maintain coherency with each other,(2)
(3)and all of the brood creature units from the swarm must be committed to the Engage Action.(3)
(4) At the end of the Engage Action, both the synapse creature group controlling the swarm and any remaining brood creature units from the swarm must attempt to get back into normal coherency if the combat was a Tyranid victory.(4)
(5) Alternatively, both the synapse creature group controlling the swarm and any remaining brood creature units from the swarm may withdraw as normal if the combat was a Tyranid loss, again returning to normal coherency with each other during that withdrawl.(5)
(6)After any consolidation or withdrawal moves have been made, any brood creature units from the swarm that still remain outside of synapse coherency, of any synapse creature(s) from the swarm, they are removed from the table. It's assumed they have pursued fleeing enemy survivors so far away as to be well beyond the hive minds control for th etime being.(6)
(1) It clearly states that the only exception to this rule is an Engage Action.
(2) That, for this action, the swarm can be temporarily split into two distinct groupings, one containing the Swarm's Brood Creatures, and one containing the Swarm's Synapse Creatures.
(3) And that all of the Swarm's Brood Creatures must be comitted to the assault, some of them MAY NOT stay behind with the Swarm's Synapse Creatures.
(4) That these two seperate groups must attempt to get back into coherency with each other by the end of the Engage Action.
(5) The same as 4 if they lose the assault, but again only with each other.
(6) That, after a consolidation/withdrawl move if any brood creatures that remain out of synapse range of any synapse creatures from the swarm they are part of then they are removed from the table.
This removal isn't occurring because they are out of anybody's synapse range, it is occurring for a different reason, and that reason is given. It is explained that way so players would realize that true synapse control had nothing to do with that removal. Consider it a feeding frenzie thing and other synapse control spheres have nothing to do with it.
I prefer to change the engage back to old way (synapse range can be broken, coherency cannot). And consider the nodes as a separate problem. Or then allow other synapses to save the critters. But it's Jaldons call as always.
This is how this whole mess got started, trying to make exceptions for the Nodes. I am not treading down that path again, the rule either covers the entire army, or we don't use it.
Also allowing other synapse to 'save the critters' is just asking for a whole host of problems with players 'splitting off' brood creatures to be scooped up by another swarm. This would then be quickly followed by the question can I activate them 'again' as they are now part of the new swarm, right? I do not want splitting, or hand offs, etc...
I want both the Nodes and the Swarms to be able to send their brood creatures out of Synapse Coherency/Normal Coherency of their controlling Synapse Creatures during an Engage Action.
This is only so the Nodes can send off 'suicide' assaults, and so the Swarm's brood creatures to fully exploit their infiltrate double move.
I find that this kind of attack would fit into the Nid Background.
The reason for the heavy penalty for not being able to return to coherency is to prevent players attempting to exploit the rule, and to make them think hard about it's possible use.
In practice, and we have used it this way, Swarms can send their infiltrators deeper into the enemy formation, Hormagaunts mostly, but most of the rest of the swarm's brood creatures are place where they can easily get back into coherency in a consolidation move. As most of the  hits that will be scored in the assault will fall on the extended Hormagaunts they being out of returning to coherency becomes almost moot.
Again, in practice, the Nodes become mostly reserve spawning points used by swarms to gather up extra bugs, and using this rule they are forced to operate closer to the front. Once the battle lines move well out of the Nodes area it becomes useless to the army. So place them well. They have also been used as deep strikes that once placed each turn send off suicide bugs to wear the enemy down from behind.
Now if it continues to cause problems like formation splitting, etc. instead of creating its intended goal of allowing the nodes/swarms a bit more flexibility then it would be better to just scrap the entire idea and force the Nids to stay under strict synapse and normal coherency.
Yes this is an exception to the normal rules, it even says so at the start of the paragraph, but it has very narrow criterion for its use so that players don't start using their imaginations to start including it to do a whole host of things it was never intended for. Again, if I cannot get it to fit and stay within this very narrow band of criterion it would be better to scrap the entire idea.
Thanks All...................
Jaldon :p
PostPosted: Sat May 06, 2006 3:30 am
Now to answer specific questions................
Yes. But normally they aren't removed from table within turn either. Since this creates an exception to that rule, I'm thinking that this should create the same exception to everywhere (which means that they would change "owners" within a turn). As the reason of the special rule would warrant it.
No, it isn't an exception to the rule as the reason for the removal of the brood creatures isn't because they have fallen out of synapse range, it is because they have gone on a feeding frenzie and fallen out of the temporary control of not only nearby synapse creatures but also the hive mind. It is stated as such in the rule that the reason is different.
So - Either Jaldon wants to include an option for these bugs to change synapse ownership - or he doesn't. The way it currently reads - its just a risk of assaulting outside of your controlling synapse groups control... Which may be a bit risky perhaps.
Yes, exactly.
I'm not talking about changing Synapse groups, I'm talking about a Brood swarm that has lost all its Synapse creatures during an engage.
Then the entire swarm is removed, so be careful when using this type of engage move. However, think about it for a moment. If the Brood Creatures have assaulted well beyond synapse coherency, 25+cms away from the nearest synapse creature from their swarm after they have moved, just what do you think the odds are that all the synapse creatures are going to be KIA'd in the assault, if any?
don't know. I feel like the new system was made to accommodate both synapse nodes and the leaving for engage. It just feels wrong that the brood creatures are removed no matter how much synapse creatures are around them.
Synapse Range of the originating swarms synapse creatures is only the vehicle being used to reflect what is being covered by the rule. It isn't the focus. That focus is given above, in the rule. Other Synapse Creatures influence has no effect because what is occurring is a feeding frenzy/pursuit, not a direct loss of synapse, it is a total loss of control by the hive mind.
Hope all of this helps us move further forward on this
Jaldon :p
PostPosted: Mon May 08, 2006 4:10 pm
Jaldon,
Thank you. Very helpful.
PS - looks like you are missing an "if" in the first sentence, last paragraph of your rewrite.
EXAMPLE:
After any consolidation or withdrawal moves have been made, if any...
Cheers for the in depth reply.
PS - if you cannot shed light, what does a light filter do... and how do you reduce the power of a laser beam which has already been created? :p
Rob
PostPosted: Tue May 09, 2006 4:46 am
By closing your eyes and then denying the lasers exsistance :(8:
Jaldon :p
PostPosted: Tue May 09, 2006 3:29 pm
LMAO :)
Rob
