Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2, 3  Next
[Lists] Call me stupid, but.......
 Post subject: [Lists] Call me stupid, but.......
PostPosted: Thu Dec 22, 2005 5:37 pm
That's wrong.  Objectives must be placed 30cm from the board edge and 30cm from each other.
6.1.4, second paragraph:The remaining two objectives must be set up in
their opponent?s half of the table, at least 30cm away from the
opponent?s table edge and 30cm away from any other
objectives that have already been placed.
The farthest back it could be placed would be straight back towards the Nid corner, 30cm from each edge.  That would put it ~55cm from the center line.  The other would have to be closer, but not by much.
I think this is something I'll address in the next WIP: that Common and Uncommon broods have to be set up within Synapse range; it really makes no sense that they could start "out" of it at all, and I've just been doing it by default.
I think this is still not very effective, only stripping 10-15cm distance.  The back edge of the swarm is still 15cm from the objective.  The front edge can then be 45cm from the objective (using the T-style setup you referenced earlier).  That's within 10cm of midboard at best, probably less, so even with the radius cutting off some distance, it's not more than 15cm for the body of the swarm.  It also won't work at all with a swarm that has multiple synapse creatures synapse because they can stretch out a lot farther.
Any Nid garrison will effectively start on the centerline, near mid-board, and a corner deployment allows them to close off the enemy to ~1/3 of the board or less on Turn 1.
PostPosted: Thu Dec 22, 2005 5:45 pm
Quote (nealhunt @ 22 Dec. 2005 (16:37))
That's wrong. ?Objectives must be placed 30cm from the board edge and 30cm from each other.
6.1.4, second paragraph:The remaining two objectives must be set up in their opponent?s half of the table, at least 30cm away from the opponent?s table edge and 30cm away from any other objectives that have already been placed.
The "opponent's table edge" in a corner deployment only goes half-way up each side of the table, the rest is "no-bug's-land" and is available for objective placement and objectives have to be placed "at least 30cm away"...
Whoa :80: ... I just re-read that... I think we've got a FAQ question!
Everywhere I've played that second "30cm" has been read with an implied "at least", not as a fixed 30cm! ?Wow, that makes a huge difference in game setup if that's the case! ?I really don't think objectives always have to be placed in a 31cm sided triangle though...
By strict reading that's the case though... You place your Blitz, then the enemy places theirs, then you must place a Take-n-Hold objective 30cm away from their Blitz, and then they place one 30cm from your Blitz or the T-n-H you just placed... essentially linking objectives in 30cm chains... I really don't think that's the case, is it?!
PostPosted: Thu Dec 22, 2005 6:06 pm
Hmm...  we've always played that it was both sides, but I think you are probably correct.  In any case, I still don't think it appreciably restricts the Nids from garrisoning the majority of their force almost on the midline.
And it should be read as
"...at least [30cm away from the opponent?s table edge and 30cm away from any other objectives]..."
not
"...[at least 30cm away from the opponent?s table edge] and 30cm away from any other objectives..."
PostPosted: Thu Dec 22, 2005 6:11 pm
Quote (nealhunt @ 22 Dec. 2005 (17:06))
We've always read it as:
"...at least 30cm away from the opponent?s table edge and at least 30cm away from any other objectives..."
PostPosted: Thu Dec 22, 2005 6:25 pm
But a lot of armies can do that. ?Garrisoned Stormboy Mobs and Stompa Mobs are a nightmare to face, and don't even start on Siegemasters! ?They're garrisoning tanks! ?*laugh* ?(Hmmm... I'd like to see a fight of 'Nids vs Seigemasters, I wonder how the barbed wire would do...)
Sure, Tyranids are going to try and get the "jump" on the enemy by starting close up, but if they're all deployed right away, the enemy has free reign to setup in a more defensive arrangement to try and counter that. ?
With Jaldon's "Carnifex Terror" army there's few activations, and T-formation garrisons on the corner deployment are still going to be fairly bunched up for artillery strikes. ?And every action spent spawning back the broods is one less Engage taken. ?Yes, it's a very evil army, and I look forward to seeing how it performs on the table. ?Against my Tau opponent I see it getting chewed apart by massed Hammerheads though...
PostPosted: Thu Dec 22, 2005 8:34 pm
One point that I agree with Jaldon on is the speed of the bio tanks.  Exocrines, or both flavours should be speed 15 or even 10.  They are designed to nest somewhere cozy and destroy the enemy with volley fire, not outrun a carnifex assault organisum!
In my game against N0-1 H3r3 the reason I managed to win was because I doubled my artillery brood back from the center line to confront his monolith on my blitz.  Breaking it then sustaining on the warrior phallanx the next turn.
A reduced speed would make them more of a "fixed" placement.  Something that needs to be planned.
Tyranid air marshal
PostPosted: Fri Dec 23, 2005 3:43 am
The objective placements in given example are incorrect, both Take & Holds are within 30cms of a table edge, and within 30cms of each other.
"The remaining two objectives must be set up in their opponents table half, at least 30cms away from the opponent's table edge and 30cms away from any other objectives that have already been placed."
In all of the battles played the opponents set their objectives as far into one flank as humanly possible, within the dictates of the rules, and it didn't change the Nid ability to cover over 3/4s of the table with bugs.
The two Bug Swarms were set up with all creatures in Synapse range, but as they are no longer required to remain within 5cms of each other, they can be spread all over the place within that same swarm. Consider a single Tyranid Warrior has an actual Synapse Range of 30cms (15cms behind him and 15cms in front of him) and you will quickly realize this really isn't that hard to do.
Heck, a single Tyranid Warrior Formation of three Tyranid Warriors can cover 102cms of frontage and/or depth and keep all of it's Bug Warriors in synapse range! (30cms per Tyranid Warrior +4cms for the stand it is sitting on times three equals 102cms)
As for Agility, this only became a needed item when the Nid army started suddenly becoming full of units that are LV, which to some extent I believe has gone just a bit too far.
As I stated at the begining, I am really not trying to slam the entire list as I do see an awful lot of real good ideas in it. But what has been done has had some effects that I believe weren't anticipated. Which is why we playtest!
Again Thanks For your time Chroma.
Jaldon :p
PostPosted: Fri Dec 23, 2005 5:46 am
Quote (Jaldon @ 23 Dec. 2005 (02:43))
In corner deployment the opponent's "table edge" only goes half-way up either side of the board so the remaining "no bug's land" should be legitimate areas for objective placement.
The objectives in the example picture should be at least 31.5cm away from each other and from the enemy deployment edge, as that's how I plotted them in Campaign Cartographer, it may have gotten futz up a bit when I converted to a .jpeg.
PostPosted: Fri Dec 23, 2005 5:56 am
Okay, there's just one thing I need to get straight here Jaldon:
Are you saying the take-n-hold objectives need to be placed exactly 30cm apart, no more, no less?  (I agree on the no less part, certainly!)  So that basically the placement of the first one dictates a, somewhat tuncated, 30cm arc in which the second one must be placed?
PostPosted: Fri Dec 23, 2005 6:05 am
Actually, I felt the need for something more than walker the first time one of my Hive Tyrants got killed by a tree. ?*laugh* ?And then I discovered the HT couldn't lead a swarm into the jungle either!
The conversion of more units to LV status was a manifestation of two things: 1) Making certain units more vulnerable to fire, as I felt it more likely enemy troops would be firing both their small arms *and* their heavy weapons at the floating brain bug or the stalking mantis bug, not just one or the other. ?
And 2), the modelling aspect. ?I really didn't want to have to re-base my biovores from 1 on a base to a minimum of three. ?The stats of most of the LV-ed creatures seems more likely to represent the capabilities of an individual creature or two, not 3-5 of them all together.
Agility seemed to address the needs of skittery-spidery bio-titans, walking tanks, and lithe hunters better than just walker.
PostPosted: Fri Dec 23, 2005 6:29 am
Quote (ragnarok @ 22 Dec. 2005 (19:34))
One point that I agree with Jaldon on is the speed of the bio tanks. ?Exocrines, or both flavours should be speed 15 or even 10. ?They are designed to nest somewhere cozy and destroy the enemy with volley fire, not outrun a carnifex assault organisum!
This is probably a good change to look into.  Can you try it and see how it works out?
PostPosted: Fri Dec 23, 2005 9:08 am
Quote (Honda @ 22 Dec. 2005 (16:12))
Even if the 1-garrison-per-objective rule under discussion is adopted, that won't stop the Nids from closing off a corner deployment in the first turn.
Where is this being discussed?
Thanx!
Hi, it?s a semi-official Rule beeing up to be Official at the SG Forums.IIRC.
Steele
Quid pro Quo
PostPosted: Sat Dec 24, 2005 2:20 am
They cannot be within 30cms of another objective, but are not required to be within 30cms of any other objective. So any distance from 31cms up. So yes no less.
Yes, the second view taken from the SG site was much clearer to me on my ancient laptop, and is correct.
However, it doesn't change anything as the Blitz is used for the opposite flank deployment in a corner set up anyways.
Players here most often choose not to use a corner deployment as it is handing larger armies an easier way to flank and hem in smaller armies, and often those small armies are the ones  with the higher strategy rating.
And 2), the modelling aspect.  I really didn't want to have to re-base my biovores from 1 on a base to a minimum of three.  The stats of most of the LV-ed creatures seems more likely to represent the capabilities of an individual creature or two, not 3-5 of them all together.
I understand your reasoning behind it, I just believe it is having a negative effect on the army list as a whole, and itself is creating many more problems rather then solving any. This is, however, just my opinion and I can easily live with disagreement on opinions.
More importantly, I do firmly believe you would find JJ giving the axe to most of the things, pointed out as such, in my original post. That isn't furthering the list, rather it is a step backwards as then things would have to be re-done and playtested all over again.
Again this is just my opinion based upon my experiences working with JJ from the start on the entire Epic-A project and the Nid army specifically.
Thanks for your time Chroma, and Merry Christmas.
Jaldon :p
PostPosted: Sat Dec 24, 2005 4:28 am
Quote (Jaldon @ 24 Dec. 2005 (01:20))
And a Merry Christmas to you too Jaldon!
My biggest (EPIC) Christmas wish would just to have Maksim hear from Jervis as to what's going to happen with the Tyranid list. ?I've got one more revision to the WIP that I'll probably release around the New Year and then I'm going to wait until we've heard from the Big Man himself.
Thanks for your input and discussion!
PostPosted: Tue Dec 27, 2005 6:15 pm
Chroma - I'll try to get the slow art bug army playtested in the new year.  Though I'm trying to focus on the flappy bugs (why does work get in the way of fun?)
Jaldon - I'm wondering why you think that raveners make good shields for carnie broods?
Since you've mentioned it everyone seems to be nodding their heads and saying "good point", but I can't see why it is a good idea.  Maybe it is the cool weather slowing down my thinking, maybe it is my normal missing the obvious result, but I just don't see raveners being used to stop incoming fire.
I would just pay 20pts more and get another carni.  a 4+ RA is much better than a 5+ normal save.  Also carnies get extra attacks, either as MW CC or range attacks, the ravener doesn't.
True the ravener has agility, but that just means it can go where the carnie doesn't, and infiltrate, which lets it get out of formation with the slower carnies on an engage.
So plase enlighten me as to the bonus adding ravener to a carnie brood .
I just don't get it  :(
Tyranid air marshal
Users browsing this forum: No registered users and 83 guests
