Post new topic Reply to topic  [ 89 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
[Lists] Proposed Tyranid Armylist WIP
 Post subject: [Lists] Proposed Tyranid Armylist WIP
PostPosted: Tue Nov 15, 2005 11:13 pm
I'm not sure about making tyranid warriors LV.  They will be wilted by AT fire.  Unless an excessive amount of AV uncommon brood creatures are used, which is too expensive.
I don't like the concept that I will need ti get 150pts plus of uncommon AV brood creatures to guard my 150pts synpase creatures.  If I'm going to do that then I might as well  replace them with a tyrant and another 50pt AV brood creature.
Tyranid air marshal
PostPosted: Tue Nov 15, 2005 11:15 pm
Dang it!  I thought I'd caught all the armour changes.  I'll post up a repaired version in a few moments.
As to Warriors being LVs, well I see it for things like Lictors and 'Thropes because, usually, they're off floating by themselves.  For Warriors to become LVs gives them a serious disadvantage when leading an infantry swarm... of course, with Ravener LVs and such, maybe it's not so bad...  and they *are* lascannon targets, even if they don't get insta-killed!  *laugh*
Yeah, lets try them as LVs... I might suggest a special rule for them under "Xenobiology", something like "Mobility" - All Tyranid light vehicles are treated as infantry for terrain effects.
PostPosted: Tue Nov 15, 2005 11:23 pm
Quote (Chroma @ 15 Nov. 2005 (21:15))
Why not just give them walker like IG sentinels?
Or do you mean they should get infantry cover saves as well?
PostPosted: Tue Nov 15, 2005 11:26 pm
Quote (ragnarok @ 15 Nov. 2005 (22:13))
I'm not sure about making tyranid warriors LV. ?They will be wilted by AT fire. ?Unless an excessive amount of AV uncommon brood creatures are used, which is too expensive.
I don't like the concept that I will need ti get 150pts plus of uncommon AV brood creatures to guard my 150pts synpase creatures. ?If I'm going to do that then I might as well ?replace them with a tyrant and another 50pt AV brood creature.
I'm leary of it too ragnarok, but if Raveners are LV as well, that gives them some screening.
Try it either way, I'd say!
PostPosted: Tue Nov 15, 2005 11:27 pm
Quote (ragnarok @ 15 Nov. 2005 (21:13))
1 unlucky hit can kill a tyrant and there goes your synapse. It takes at least 3 hits to kill the warriors - and they still have decent AV at 4+.
PostPosted: Tue Nov 15, 2005 11:28 pm
Quote (Markconz @ 15 Nov. 2005 (22:23))
I mean I hate the idea of a Warrior dying cuz he bumped into a tree in the woods or is unable to enter jungle terrain... *laugh*
WIP 5.6.1 is up!
PostPosted: Tue Nov 15, 2005 11:55 pm
Quote (Chroma @ 15 Nov. 2005 (22:26))
I've only got 6 stands of raveners of an average of 2 to 3 warrior broods.  that mean 2 to 3 per swarm.  Not enough of a shield. compared to the 14 odd units they are normally deployed with.
Tyranid air marshal
PostPosted: Tue Nov 15, 2005 11:57 pm
Quote (ragnarok @ 15 Nov. 2005 (22:55))
I've only got 6 stands of raveners of an average of 2 to 3 warrior broods. ?that mean 2 to 3 per swarm. ?Not enough of a shield. compared to the 14 odd units they are normally deployed with.
I'm in the same boat, but I'm gonna see how it floats.
I suppose Warriors being infantry could be explained away by the "no instant kill" rule in 40K.  Synapse range in E:A is quite a bit further than in 40K so it's possible for other LV-class creatures to still get killed.  And it's volleys of lascannon fire in E:A!  *laugh*
PostPosted: Wed Nov 16, 2005 9:56 am
Quote (Hena @ 16 Nov. 2005 (05:41))
I'm not sure about the the Tyranid Warriors either. I really think we need some infantry synapse. I wouldn't want to fill my brood swarms with raveners or AVs just to protect the Warriors.
Yes this is a real problem, and something that has prevented the move to LV class for warriors and others for a long time.
In short I am not sure about it either.
PostPosted: Wed Nov 16, 2005 11:00 am
Quote (Markconz @ 15 Nov. 2005 (22:27))
My normal set up is with at lest 5 or 6 carnies or other bio tank with my tyrant, with them between it and the enemies guns.  Thus they need at least 6 hits to hit the tyrant once and 12 to hit it twice.  So there only being one isn't much of a problem.
However warriors as LV will only have 2 to 4 AV units in the same formation, so it take less hits to get to them and they have a lesser save and more can be hit in the same attack, since it will go critter, critter, critter, warrior, warrior, warrior.
I dread to think what an armoured company could do to warriors if they were LVs.
Tyranid air marshal
PostPosted: Wed Nov 16, 2005 4:45 pm
Still reviewing the list ...what is the most recent version ? ???
PostPosted: Wed Nov 16, 2005 4:47 pm
Quote (Legion 4 @ 16 Nov. 2005 (15:45))
The most recent WIP version I've been posting is WIP 5.6.1 and can be found here:
http://home.cogeco.ca/~kpetker/
PostPosted: Wed Nov 16, 2005 4:56 pm
Thanks, "C" !  I'll check it out ! :D
